Old 05-11-2010, 09:18 PM   #127
Palmer812
Drives: 2010 Meteorite Metallic LB
Another troll?
Palmer812 is offline   Reply With Quote
Old 05-19-2010, 04:58 PM   #128
kac
kac's Avatar
Drives: 2009 Meteorite 3dr
This DIY helped a lot. Thanks!
Old 05-19-2010, 08:49 PM   #129
bst82551
bst82551's Avatar
Drives: 2008 Flint Mica Yaris Sedan
I did this earlier this week as well and it turned out better than I'd imagined. The DIY guide helped A LOT. One definite issue I had was getting the adapter off of the negative battery cable. I ended up sawing it off, but not before slicing my knuckles a few times trying to get it off with a wrench. This install was very easy and would've only taken about 45 minutes if it weren't for that pesky adapter on the battery cable.
Anyway, as far as results go, I can't say for sure that it's all based on the new groundwire kit, but my car definitely rides smoother and accelerates better, particularly in the mid-range RPMs. I also feel smoother shifts from my automatic transmission.
However, I absolutely have to note that part of this may be due to the fact that I had the battery disconnected for about an hour, which reset every electrical component in the vehicle (including the engine control unit). So, I would've experienced a smoother ride either way from simply resetting the ECU, but I've reset it before and don't believe the results were this drastic in the past. I haven't had a chance to see any difference in fuel efficiency yet, but it certainly wouldn't surprise me to see an extra 1 or 2 mpg.
-Brian
P.S. Kac, is your air filter just laying out or do you have some strange new intake I've never seen before? I see your sig says you have a modified air intake box. Is there a DIY guide or any more info about it?
bst82551 is offline   Reply With Quote
Old 05-19-2010, 11:05 PM   #130
kac
kac's Avatar
Blacksandiegovits did it first. i just modified the stock air box.
I got the info on how to do it from another thread... don't have a link for ya sorry. search around.
Old 08-17-2010, 12:54 PM   #131
Revsson
Hey kac!
Was this an ebay item or did you make it yourself?
Looks nice.
Old 09-01-2010, 03:32 AM   #132
birdman
Drives: '08 Blazing Blue Yaris LB
Will the grounding kit be the solution for those nasty static shocks I keep getting every time I close my door?
birdman is offline   Reply With Quote
Old 09-01-2010, 03:21 PM   #133
wsladaritz
Y4R1Z
wsladaritz's Avatar
Drives: Yaris LB
No birdman, it will not solve that problem :( I've had a grounding kit on for 2 years or so now I think and I still get those nasty static shocks occasionally. Not always, but when it happens IT HAPPENS. I have no idea what causes it though...
wsladaritz is offline   Reply With Quote
Old 09-06-2010, 01:59 AM   #134
birdman
Thanks!
For Sale: Lexus GS Parts - L-Tuned Body Kit, TRD Strut Tower bar, 18"StaggeredWheels. TRD_Yaris Items for Sale by private party 6 05-06-2010 06:43 PM
Is aftermarket HID kit legal (in NJ)? Jfoofoo Cosmetic Modifications (Exterior/Interior) 25 03-19-2009 02:05 PM
DIY KEYLESS ENTRY on Power Liftback? TC-LIFTBACK DIY / Maintenance / Service 0 08-23-2006 09:57 AM
Any front bumper/ hood stone chip issues? Where could I get Clear Bra kit? tifosi360 General Yaris / Vitz Discussion 9 08-07-2006 02:43 PM
