#145 |
![]() Drives: 2008 Flint Mica Yaris Sedan Join Date: Jan 2010
I did this earlier this week as well and it turned out better than I'd imagined. The DIY guide helped A LOT. One definite issue I had was getting the adapter off of the negative battery cable. I ended up sawing it off, but not before slicing my knuckles a few times trying to get it off with a wrench. This install was very easy and would've only taken about 45 minutes if it weren't for that pesky adapter on the battery cable.
Anyway, as far as results go, I can't say for sure that it's all based on the new groundwire kit, but my car definitely rides smoother and accelerates better, particularly in the mid-range RPMs. I also feel smoother shifts from my automatic transmission. However, I absolutely have to note that part of this may be due to the fact that I had the battery disconnected for about an hour, which reset every electrical component in the vehicle (including the engine control unit). So, I would've experienced a smoother ride either way from simply resetting the ECU, but I've reset it before and don't believe the results were this drastic in the past. I haven't had a chance to see any difference in fuel efficiency yet, but it certainly wouldn't surprise me to see an extra 1 or 2 mpg. -Brian P.S. Kac, is your air filter just laying out or do you have some strange new intake I've never seen before? I see your sig says you have a modified air intake box. Is there a DIY guide or any more info about it? |
#146 |
![]() ![]() ![]() ![]() Drives: 2009 Meteorite 3dr Join Date: Jul 2009
Blacksandiegovits did it first. i just modified the stock air box.
I got the info on how to do it from another thread... don't have a link for ya sorry. search around.
Touchscreen DVD Navigation - 10" Bazooka Subwoofer - Kenwood Speakers - Toyota Premium Horn set AFE Pro Dry Air Filter - modified air intake box - 1ZZ-FE Throttle Body - Ultra Racing Rear Sway Bar & Front Strut Bar NST in cabin & engine bay SSK's - TWM shifter base bushings & cable bushings - Megan Racing C-Pillar Brace Last edited by kac; 05-20-2010 at 03:23 AM. |
#147 |
![]() ![]() ![]() ![]() Drives: 2009 Meteorite Metallic LB MT Join Date: Oct 2008
#148 |
![]() ![]() ![]() Drives: '08 Blazing Blue Yaris LB Join Date: Sep 2009
Will the grounding kit be the solution for those nasty static shocks I keep getting every time I close my door?
#149 |
Y4R1Z
No birdman, it will not solve that problem :( I've had a grounding kit on for 2 years or so now I think and I still get those nasty static shocks occasionally. Not always, but when it happens IT HAPPENS. I have no idea what causes it though...
#150 |
Thanks!
| For Sale: Lexus GS Parts - L-Tuned Body Kit, TRD Strut Tower bar, 18"StaggeredWheels. | TRD_Yaris | Items for Sale by private party | 6 | 05-06-2010 07:43 PM |
| Bluetooth Kit Info | so40 | In Car Entertainment + Electronics (audio / video / alarm) | 13 | 07-12-2009 06:13 PM |
| Is aftermarket HID kit legal (in NJ)? | Jfoofoo | Cosmetic Modifications (Exterior/Interior) | 25 | 03-19-2009 03:05 PM |
| DIY KEYLESS ENTRY on Power Liftback? | TC-LIFTBACK | DIY / Maintenance / Service | 0 | 08-23-2006 10:57 AM |
| Any front bumper/ hood stone chip issues? Where could I get Clear Bra kit? | tifosi360 | General Yaris / Vitz Discussion | 9 | 08-07-2006 03:43 PM |
