Old 01-11-2007, 02:45 PM   #1
Doc Zaius
Lurker supreme!
Doc Zaius's Avatar
Drives: old and boosted!
Torquing those Lug Nuts...
Hey everybody... quick question... bought a 1/2" torque wrench last week, and rotated my tires, front to back, and tightened everything to the factory spec 76 ft.lbs. I've been told that its a good idea to re-torque all your lug nuts after 100 km or so just to make sure everything is still snug. Now, in the instruction manual for the wrench, they say you should never try to torque an already tight nut... its best to loosen it, and then re-torque for an accurate reading.
My question is this... should I just ensure each nut is still tight with the wrench, or should I loosen each nut individually and re-torque, possibly undo-ing the last 100 km "settling-into-place" phase...?
Thanks!
2006 Red Blitzed RS 5-door
Old 01-11-2007, 03:34 PM   #2
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
Thanks!
Don't loosen it. Just apply smooth even pressure until the torque wrench clicks, then stop.
Old 01-12-2007, 12:21 AM   #3
johnnyfive
johnnyfive's Avatar
the only reason the manual says to losen it first, is so you know the nut is not over tight. if you put them on with the wrench in the first place, you can be sure that they are not over tight. and re-tightening your lug nuts is more to make sure they are still tight, more often than retightening them :)
johnnyfive is offline   Reply With Quote
Old 01-12-2007, 12:31 AM   #4
ChinoCharles
Drives: LB
I'm going to go out on a limb and guess that he didn't get a clicking torque wrench.
DID I WIN DID I WIN?
Old 01-12-2007, 01:04 AM   #5
mikeukrainetz
mikeukrainetz's Avatar
Drives: 2006 Toyota Yaris
my new rims and lugs needed re-tightening shortly after installing them.
torqued them down once with a half inch torque wrench then again just after.
they had loosened off slightly.
I highly recommend doing it twice.
mikeukrainetz is offline   Reply With Quote
Old 01-12-2007, 12:09 PM   #6
Doc Zaius
Lurker supreme!
Doc Zaius's Avatar
Charles... sorry! You lose!
I bought a clicking-style torque wrench. Its pretty sweet... never used one before. But ya, the idea of loosening them first to ensure they're not over-tightened makes perfect sense.
Thanks all who replied!
Old 01-12-2007, 03:18 PM   #7
ChinoCharles
Drives: LB
Aw shit.
Old 07-13-2007, 12:52 PM   #8
Charles FTL
Old 07-13-2007, 01:19 PM   #9
brickhardmeat
Lonesome Cowboy
brickhardmeat's Avatar
Drives: 2007 WHITE HATCHBACK
one click
SPONSORED BY
Will S Sedan Alloys Fit on A Liftback? MrMondayNite Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 11-05-2006 02:39 PM
5 lug adapter? funkstrong Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 10-21-2006 05:49 PM
Lug Nuts for Konig Helium Wheels? OK Yaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 09-19-2006 06:58 PM
