Old 06-16-2010, 12:55 PM   #307
BEAST!
Old 07-19-2010, 08:59 PM   #308
Jason@SportsCar
Got the rest of our body work, it is getting painted this week. Hopefully the head comes back this week as well.
Also got the new engine management.
Hopefully it will be back to life within the next ten days.
Old 07-22-2010, 03:27 PM   #309
Jason@SportsCar
Got a call from our engine guy... He was not happy with the first set of valve springs he received, so a new set is on the way. Should get the finished product on Monday now. Can't wait to see what it does on the dyno with head work and new cams.
Freshly painted fenders, hood and bumper just got dropped off. Time to get out of here and go install them.
Old 07-22-2010, 06:04 PM   #310
power band should be very interesting now.
I'm doing even stronger springs now as well.
Old 07-22-2010, 06:08 PM   #311
rob323
Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car
I'd be curious to know what seat pressure you guys end up with with the stronger springs.
rob323 is offline   Reply With Quote
Old 07-23-2010, 04:12 PM   #312
Jason@SportsCar
Core support, radiator and front fenders are in.
And just when I had given up all hope of ever seeing our custom 13" wheels, I even bought another set of 15"s, a box full of wheels shows up. 8lbs 5oz of dead sexy aluminum.
Old 07-23-2010, 06:13 PM   #313
Did you have any issues at all swapping in the final drive and output shaft from an xB? -- I think that's the way I recall you doing it.
Old 07-23-2010, 08:39 PM   #314
Jason@SportsCar
I did not install the parts myself, I just dropped off the trans and the parts, but I was told it was a perfect fit. However, the car has not moved under its own power with those gears, so the real test will come next week. But we have no reason to think there will be an issue.
Now do the math on converting to a 4.30 gear with a 20" tall tire. It should move now. Being under 1900lbs wont hurt either.
Best news... Just did a test fit with one of our custom three-piece wheels, and they clear the brakes. But I do need to get a set of longer studs, the centers are a little thick on these wheels.
Old 07-25-2010, 04:10 PM   #315
Jason@SportsCar
New dash and cluster. Still have a few wires to tie up.
Old 07-25-2010, 07:26 PM   #316
I think "skeletonized" describes your interior.
Old 07-25-2010, 09:58 PM   #317
rob323
What dash is that?
Old 07-25-2010, 10:03 PM   #318
rob323
Garm, what code is your current box (eg, C154) and what code is the XB box?
Old 07-26-2010, 01:22 AM   #319
Jason@SportsCar
Originally Posted by rob323 View Post
What dash is that?
AiM, will pull data directly from our new ECU.
http://www.aimsports.com/products/mxl-chooser.html
Old 07-26-2010, 01:24 AM   #320
Jason@SportsCar
The USDM Yaris and early xB are both a C50. The outside of the case is different, so a complete swap is not in the cards, but the guts can be changed.
Old 07-26-2010, 01:24 AM   #321
rob323
Nice, very jealous.
Old 07-26-2010, 01:36 AM   #322
rob323
In that case, anything from a C50, C52 or C56 should swap around without too much drama, maybe a different bearing here and there but that's about it.
Old 07-26-2010, 03:42 AM   #323
Correct, and now I have one of each, thanks to Jason playing guinea pig for us.
Old 07-26-2010, 12:58 PM   #324
knowmercy
knowmercy's Avatar
Drives: Blk 3door
Needs moar pictures!!
knowmercy is offline   Reply With Quote
Hood Stay (lift) Instal 1NZYaris1 DIY / Maintenance / Service 31 09-22-2016 08:56 PM
The opposite sex can't stay away with ssk POORSHA DIY / Maintenance / Service 20 08-19-2009 11:41 AM
eTiMaGo Stay safe Bob_VT Off-topic / Other Cars / Everything else Discussions 20 12-02-2008 06:31 PM
Tuned a DBW Toyota yesterday Turbo&Auto Performance Modifications 17 08-17-2007 01:04 AM
why am I always here?! wtf...i cant stay away.. Blenjar Off-topic / Other Cars / Everything else Discussions 5 02-26-2007 11:51 AM
