Old 06-16-2010, 10:11 AM   #1
longlivekel
Drives: Rover Mini S
What Wheel Offset and Back Spacing
Hey guys.
I believe this is my first true post..
I bought a 2009 yaris last week and I am wanting to put diff wheels on it and lower it using TRD springs.
I have noticed that the wheel offset for a yaris is best between 40-42mm or at least most common.
As for back spacing.. is there a minimum/maximum distance?
Thanks
Kel
longlivekel is offline   Reply With Quote
Old 06-16-2010, 10:29 AM   #2
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Originally Posted by longlivekel View Post
Hey guys.
Thanks
Kel
Sorry, what do you mean by "back spacing" ? are you reffering to the distance between the back of the rim and the strut or axle?
Old 06-18-2010, 02:58 PM   #3
longlivekel
got it figured out on backspacing.
Wa is best for backspacing?
Old 06-19-2010, 04:23 PM   #4
Bluevitz-rs
I give up.
Old 06-19-2010, 04:59 PM   #5
sickpuppy1
Drives: 2010 Yaris Sedan
http://www.customtacos.com/tech/index.php?article=40
Old 06-20-2010, 06:07 AM   #6
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
I don't know what you mean either, but if you purchase wheels and decide to go on 15" or 16" x 7" wide, most wheels will have offset included in the specs (in your case +40mm or +42mm). Rarely does a wheel company include backspacing in their specs. If you do decide then a good minimum/maximum range for offset is between +35mm to +45mm on the safe side.
Old 06-21-2010, 12:56 PM   #7
longlivekel
Backspacing.. Scratch that.. Offset was what i was looking for.
And thanks for the 35mm -45mm offset for safe ride.
Offset and lowering on 205/45/16s driver centric Wheels, Tires and Suspension Forum sponsored by The Tire Rack 22 08-13-2016 11:09 AM
Installed 10mm PG spacers on a 15x7 +25 wheel kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 08-27-2009 08:10 PM
PLEASE HELP! 15x8 wheels contraband831 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 76 06-30-2007 11:34 AM
need 17inch rim guidence chino_potato Wheels, Tires and Suspension Forum sponsored by The Tire Rack 46 04-09-2007 01:09 PM
Wheel Offsets bigsky2 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 03-08-2007 02:55 AM
