Old 06-19-2010, 08:05 PM   #1
jon@swoveland.com
Drives: 2007 Yaris HB
Red face Did I just fry my flasher relay?
Hi all...this is my first post to this forum, but likely wont be my last .
I just bought a small utility trailer (4'x5') to use for camping and such - already had a hitch installed for a bike rack, but I need to install a trailer wiring harness. In attempting to save some cash by doing this myself, I think I may have fried my flasher relay. Here's what happened...
On the rear-light circuit board (the board with the reverse lamp and turn indicator lamp mounted) there are what appear to be 2 male spade connector receptacles next to each of the lamps - I figured this would be perfect for wiring up the harness. To be sure these connectors were wired into the lamps, I got out my circuit tester - I first tried the spade connectors next to the reverse lamp, bingo - worked as I thought. Next I tried spade connector next to the turn signal, and this is where things went sideways...I must have been a tad careless with the tester probe tip and shorted the circuit (there was a faint spark). After that the turns signals / hazards don't work at all, no clicking from the relay, no indicators on the dash, nothin'. I've checked all the fuses, and they're all good...so the only thing I can think of is that the flasher relay itself is blown. Anybody have thoughts on this?
Thanks for reading!
Jon
jon@swoveland.com is offline   Reply With Quote
Old 06-19-2010, 10:09 PM   #2
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
I haven't looked under my dash, but if the Yaris uses a standard flasher a new one will only set you back a couple of bucks or so.
Old 06-19-2010, 10:26 PM   #3
jon@swoveland.com
Unfortunately it doesn't use a standard flasher relay. It's an overly complex component with integrated circuits and who-knows what... Toyota dealer is so far the only source I've found, and they want...sit down... $107 for it!!!
And this thing isn't fuse protected!
Old 06-19-2010, 10:45 PM   #4
Check the 10A HAZ fuse. It feeds the flash relay.
The HAZ fuse is in the fuse panel under the hood by the way.
Old 06-19-2010, 11:40 PM   #5
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
I have a spare yaris flasher you can have $40.00, but it would take 6-8 days to get to you .
As i have a lexus LED flasher in mine now
Old 06-19-2010, 11:53 PM   #6
Yaris Hilton
Oh, that's awful!
Old 06-20-2010, 12:09 AM   #7
jon@swoveland.com
Thanks so much for the offer 1NYaris1, unfortunately that would be cutting things pretty close...going away early for the long weekend, and I still need to get the wiring harness done, which won't happen until the signals work again...
Old 06-20-2010, 12:18 AM   #8
Did you check the fuse yet?
If the relay assembly is truly fried, I have an extra as well, that I can ship from Connecticut, which might get there a bit faster.
Old 06-20-2010, 12:26 AM   #9
jon@swoveland.com
CTScott - I thought for sure I had checked that fuse with my fuse tester, anyhow, this time I pulled it, and sure-enough it was blown. I put in a spare and .... flashers still didn't work! Then I realized I hadn't put the relay module back in. Plug'd her back in and voila...signals!
CTScott, I definitely owe you a cold one!
Thank-you everyone who posted, what a fabulous forum!
Need fog light switch and relay Jrilla DIY / Maintenance / Service 23 07-01-2011 12:12 PM
Indicator relay removal Yariscoyne DIY / Maintenance / Service 9 01-07-2011 04:42 PM
Horn Relay? MGargano DIY / Maintenance / Service 7 11-14-2009 07:01 PM
Request for help: diagramming a relay BailOut In Car Entertainment + Electronics (audio / video / alarm) 25 07-12-2009 01:59 PM
Relay Question Liu997 DIY / Maintenance / Service 8 04-25-2009 11:58 AM
