Old 06-21-2010, 12:19 AM   #1
09box
Drives: 09 grey Yaris hatch
Jackhammer noise?
Probably about a week ago, a jackhammer noise started to appear on the left front drivers side of the car. At first, it was softer and has gradually gotten to very loud as of now. The tires, wheels, brakes, and hubs have all been checked. Has anyone had a similar problem or can diagnose it? My friend and I checked a few things out and have it narrowed down to either being axle or transmisson related.
09box is offline   Reply With Quote
Old 06-21-2010, 12:54 AM   #2
Lucas13
Drives: 07 Yaris LB
Is it when braking?
Lucas13 is offline   Reply With Quote
Old 06-21-2010, 01:44 AM   #3
ddongbap
I think ur shock is blown.
Old 06-21-2010, 07:32 AM   #4
09box
It is at lower speeds and when I get off of the gas..
Old 06-21-2010, 09:52 AM   #5
1stToyota
1stToyota's Avatar
Inboard CV joint?
Reason being I had a VW that failed within a year due to not enough grease in the inboard joint. Made lots of noise and caused vibration some times. Happened while driving on the freeway, in a straight line, never while turning.
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
Old 06-21-2010, 11:38 AM   #6
YarisSedan
Drives: 08 Yaris Sedan
First things first double check the wheel bearings. With the car up in the air or on jack stands grab the top and bottom of the wheel and wiggle it up and down there should be no play. And spin the wheel it should turn freely. If everything checks out okay more than likely you have a blown cv joint.
A blown cv joint will sound like a very loud cliking sound which could be interpereted as a jackhammer. Best way to check it is to drive it on a rack while someone is under the car listening and looking. Easiest way is to hold a long prybar against the chassy and against your ear on each side and find the one that the sound is coming from. Then check for play where the axle goes into the transmission. If there is no play, its safe to say just a bad cv joint.
Another easy way to check if its extremly worn is to take sharp left and right turns. Usually it will make sound very prominent on the side thats failing under load.
Very loud noise from the engine Stiv DIY / Maintenance / Service 27 10-27-2009 10:09 AM
strange noise before the car stops dani1983 DIY / Maintenance / Service 14 08-15-2009 11:56 AM
Random tire thumping noise Tonavi DIY / Maintenance / Service 6 06-06-2009 02:27 PM
Noise from the drums.... Lafiro General Yaris / Vitz Discussion 18 05-22-2009 09:49 AM
Radio noise.. need help TinyGiant In Car Entertainment + Electronics (audio / video / alarm) 13 12-06-2008 04:21 PM
