Old 01-15-2007, 05:07 PM   #1
chickmagnet8301
Drives: 2007 yaris
oil change question
What oil is everyone using and what filter? I am looking at the trd filter but I am unsure what oil to go with. I need to not void my factory warranty. Thanks for all help in advance.
chickmagnet8301 is offline   Reply With Quote
Old 01-15-2007, 05:46 PM   #2
i used NAPA oil with their Gold oil filter. a lot of people here use Amsoil oil and Wix oil filters (same as NAPA filters). they say stay away from Fram products. try doing a search for topics to get more info.
Old 01-15-2007, 06:20 PM   #3
chickmagnet8301
Drives: 2007 yaris
Has anyone noticedany fuel gain going syntheic and has anyone used the trd filter?
Old 01-15-2007, 06:29 PM   #4
just remember to not to switch to synthetic until 7k or later.
Old 01-15-2007, 08:27 PM   #5
Pars
Drives: 07 Yaris Liftback
Im my old Civic that had gigantic gearing and I tended to cruise around 1000rpm and get 5l/100KM (47 US MPG) and in that situation, the synthetic oil was a factor. It's not possible to do the same type of driving in my Yaris (cause engine is at home at higher rpms and the car has shorter gearings), so it's doubtful there'll be any noticeable gains from synthetic oil on fuel consumption. You'd have to really be pushing the limits to see any noticeable difference.
Pars is offline   Reply With Quote
Old 01-15-2007, 11:56 PM   #6
60 Somethings
Old Folks
60 Somethings's Avatar
Drives: 2007 Yaris LB, 2006 4Runner V8
Running 5W-30 Mobil 1 with Toyota filters. Local dealer willing to let me bring in my own oil and they deduct normal oil charge from the cost of the oil change.
We are the proud owners YARI -
He's a loaded Silver LB with ATTITUDE!
60 Somethings is offline   Reply With Quote
Old 01-16-2007, 05:43 PM   #7
chickmagnet8301
Drives: 2007 yaris
Well it looks like I may go with mobil 1 semisyn and the trd filter. Thanks for all the help and keep it coming I still have time before the change needs done.
Old 01-17-2007, 12:53 PM   #8
07WYarisRS
HardlyDangerous
07WYarisRS's Avatar
Drives: 09 Yaris LE, H/B, auto
Wix/NAPA oil filters
Amsoil 0w-30 engine oil
Amsoil ATF
Yes the synthetic makes a difference but to really notice it you need to change both engine and trans oil. With my truck I saw an easy 3mpg difference buy switching coolant (evans NPG) Amsoil 0w-30, Amsoil ATF, Amsoil 75w-90 severe gear oil in the differential.
With the yaris I'm getting 50+mpg.
And that was not changing 100% of the automatic transfluid either, I just drained the pan, measuered what I took out and replced it with Amsoil ATF. Come spring i'll do it again, each time you do that it adds more Synthetic to the mix.
The early bird gets the worm, but the second mouse gets the cheese.
07WYarisRS is offline   Reply With Quote
Old 01-21-2007, 03:13 PM   #9
mikeukrainetz
mikeukrainetz's Avatar
Drives: 2006 Toyota Yaris
I used trick-shift auto tranny fluid in my old camaro and the stuff worked awsome, kept the heat down, shifted better and didnt aerate.
Im changing the oil in the Yaris today to mobil 1 full syn.(provided I can get a filter)
mikeukrainetz is offline   Reply With Quote
Help with oil change specs autophile DIY / Maintenance / Service 31 04-25-2011 10:22 PM
My first oil change RogueYaris DIY / Maintenance / Service 41 02-07-2007 08:41 AM
Oil change question: asa805 DIY / Maintenance / Service 5 11-29-2006 10:54 PM
Oil change question Ryu DIY / Maintenance / Service 22 03-08-2006 12:21 AM
