Old 07-09-2010, 12:47 AM   #37
Hershey
Originally Posted by 2007yariz View Post
Wow that is a good deal on the oil filter, where did you buy it?? i paid $6.20 for a Toyota oil filter(Made in Thailand) from the dealer.
The TOYOTA parts department . Some are cheaper than others . Sometimes they'll match other parts department prices . Can do it over the phone . One time they gave us free washers with the oil filters at $3.50 each . Depends on what kind of day they had or whom waits on you . Good Luck .
Old 07-09-2010, 12:51 AM   #38
Hershey
2008 YARIS sedan : 3 qts. and 22 ounces of SHELL conventional and new TOYO oil filter on 7/03 . Decided to pour the used oil from the pan and oil filter into empty 4 quart oil jug . There was little over 3 quarts in it . Figure around 3/4 quart of oil remains in the engine .
Old 07-09-2010, 12:59 AM   #39
Hershey
2010 3 door : 3 qts. + 22 ounces SHELL 5w-30 dino and new TOYO oil filter on 7/04 .
Old 07-09-2010, 02:20 AM   #40
Qmobile
that's right I went there
Qmobile's Avatar
Drives: '08 Blazin' Blue,'10 Dark Red
Mobile 1 full synthetic 5w30 and a genuine Toyota filter. Oh and I get 2 filters for $10
Mods: 15" SSC rims, TRD Exhaust, TRD Sway bar, TRD oil filler, TRD rad. cap, TYC tails, Debadged, Painted engine cover, Stock spoiler, Stock mud gaurds, OBX pedals.
suggestions always welcome
Qmobile is offline   Reply With Quote
Old 07-09-2010, 03:37 AM   #41
BailOut
Steals terrorist's lunch
BailOut's Avatar
Mobil1 5W-30 Extended Performance and a K&N Gold oil filter for another 15k mile drain interval. Nothing on the magnetic drain plug.
Also changed the transmission fluid for the 2nd time, again with Redline MT-90. Good for another 50k miles.
- Brian
Share the Road
Old 07-10-2010, 12:17 AM   #42
2007yariz
Drives: Yaris sedan
Ahh i think i saw this post somewhere else, are you a BITOG member?
2007yariz is offline   Reply With Quote
Old 07-10-2010, 01:24 AM   #43
yarrr
Drives: 07 sedan
Ya, I gave up on trying to guess how much I burn/left in the engine from looking at the leftovers. Too much sticks to the pan/filter/funnel/jugs and spills to get anywhere close to accurate.
yarrr is offline   Reply With Quote
Old 07-10-2010, 01:44 PM   #44
Hershey
yup .
Old 07-10-2010, 04:58 PM   #45
frog13
Tw200--excellent!
Drives: 2010 yaris..absolutely red.
[QUOTE=Ryude;489025]Toyota recently released a press note saying that over the next year they will start to recommend 0w-20 synthetic oil across several models, due to lower emissions and higher efficiency. I wonder if the yaris will be one of them?[/QUOTE
They can recommend all they want!...my manuel and oil cap states 5w-30 and thats exactly what will go into the little dude!.Sounds as if the illusterious EPA is at it again with their rediculous standards.0w-20,please....more efficient,less emissions!.Gee,all that crap THEY have been mandating for decades apparently isn't working if we still have "problems".They should be putting regs on Volcanos,their private jets etc,etc,etc,
frog13 is offline   Reply With Quote
Old 07-10-2010, 09:43 PM   #46
goliath1812
goliath1812's Avatar
Drives: 2010 Prius, 2007 Yaris Sedan
hey, if toyota can recommend 0w-20, i don't see anything wrong with putting it in my yaris. if there's an added benefit for fuel economy and emissions, so be it. that's what i'm going to be using.
goliath1812 is offline   Reply With Quote
Old 07-11-2010, 12:06 AM   #47
Hershey
we picked up 4 TOYOTA ( Denso ) oil filters at $3.50 each excluding tax . Didn't give us free washers this time .
Old 07-11-2010, 08:25 PM   #48
frog13
Tw200--excellent!
Don't believe everything they print 1812.....it isn't beneficial to your engine.
Old 07-11-2010, 08:52 PM   #49
2007yariz
Drives: Yaris sedan
Washers? i think my oil pan drain plug already has a washer made into it, well since i didn't do the first OC on the car, i don't really know if it came with a washer. Does washers make it seal better?
http://inlinethumb62.webshots.com/43...600x600Q85.jpg
from the picture i provided above, my plug looks like that except without that silver washer...
Old 07-11-2010, 11:16 PM   #50
Hershey
yes , there's a washer needed for a better seal and easier removal of the drain plug . There are plastic and paper like washers available . I've been using the pressed paper washers . Can be used a few times .
preformance air filter and oil change? JapRulezz DIY / Maintenance / Service 10 12-14-2009 09:24 AM
service maintance light io3 Yaris TS Talk 11 09-22-2009 04:03 PM
Oil change time intervals PaidTimeOff DIY / Maintenance / Service 17 01-29-2009 08:14 PM
How often do I need to change my synthetic oil? hans_fh DIY / Maintenance / Service 21 08-20-2007 06:08 PM
Oil change question Ryu DIY / Maintenance / Service 22 03-08-2006 12:21 AM
