Old 06-12-2010, 12:48 AM   #19
ricepower
ricepower's Avatar
Drives: Yaris Y Sedan
Send a message via MSN to ricepower Send a message via Yahoo to ricepower
Thumbs up
Moderators, pls have this thread sticky! please ...
89661-52F10
89661-52F11
89661-52F11
89661-52G30
89661-52G50
89661-52G50
89661-52G51
89661-52F01
89661-52G40
89661-52G40
89661-52G30
89661-52G41
89661-52E90
89661-52E91
89661-52J50
89661-52J40
89661-52J30
ricepower is offline   Reply With Quote
Old 07-06-2010, 12:21 PM   #20
Saggio
Top Notch!
Saggio's Avatar
Drives: 2008
Who has done this on an 08 USDM Liftback and it worked?
Blah, Blah, Blah, Blah
Saggio is offline   Reply With Quote
Old 07-21-2010, 06:06 AM   #21
johnliu38
Drives: 2010 Yaris
I wodner if I can do the same trick on my Taiwanese version of 2010 Yaris Hatch Back because I heard its ECM has built-in cruise control function, but got locked. Some people charge US$250 for hacking the ECM and enable the CC function... Not sure if it's really locked or not... Is there anyway I can do to identify the CC function of my Yaris?
johnliu38 is offline   Reply With Quote
Old 07-21-2010, 07:38 AM   #22
Check to see if you have the two wires on the steering column for cruise (and the two cruise control icons on the cluster). If they are there, then you can do a real quick test by grounding the blue wire (with the ignition on) and the cruise control on icon should light up. If the wires aren't there, then you can check the voltage on the ECM pin 40. If there's 12V on that pin with the ignition on, then cruise is enabled, but just the wiring needs to be run.
Old 07-21-2010, 07:53 AM   #23
WolfWings
WolfWings's Avatar
Did it on my 5-speed '07 USDM Liftback, had to run the wire to/from pin 40 on the ECM, swiped the other parts from a 5-speed '09 USDM Liftback and everything worked 'out of the box' without issue.
I ran the wire for pin 40 inside the dash along the existing cable harness across to the cabin air filter tray, the elbow joint above that is a flexible coupling gasket-ed on both sides without any locking tabs so I just ran the wire through the cabin fresh-air intake. It has some flanges on the sides in the engine bay for water drainage/catching that I routed the wire out of and over to the ECU. Take off both windshield wipers and the trim bezels all the way across.
Old 07-26-2010, 10:47 PM   #24
tforkner
Drives: 08 liftback 5 speed
Saggio- I put the two-switch DIY type on my '08 LB. I ran the wires from the clutch switch and ECM in through the AC drain grommet. I superglued a roller switch from Radio Shack onto the metal bracket beside the clutch pedal for use as a clutch switch. Everything works fine.
tforkner is offline   Reply With Quote
Old 08-09-2010, 01:03 AM   #25
Lucas13
Drives: 07 Yaris LB
I did on mine the 2 Button and works perfectly, I bought the resistors and switches from radio shack and the OEM clutch switch.
This is one of the est mods it also gives a nice touch of comfort to the yaris, Thank to CtScott that made this possible
here are some pics
Lucas13 is offline   Reply With Quote
Old 08-09-2010, 04:03 PM   #26
Revsson
Nice clean install ^
Old 08-10-2010, 01:18 AM   #27
Lucas13
Drives: 07 Yaris LB
Thanks Revsson!
I try to keep it clean as possible especially for the warranty, you never know!!!
Old 10-13-2010, 08:15 PM   #28
magnum23
Drives: Blue,Sedan
Hi, to everybody, In from Puerto Rico, Im glad that I found this great forum, full of great and interesting info about Yaris. I recently bought a used 2009 Toyota Yaris Sedan, and Im doing some great mods that I have found here in the forum, after reading for a while I decided to do the DIY Cruise Control mod on my sedan, it have oem power locks and power windows, all the wiring is in place, and the cluster have the CC symbols, I installed the oem stalk and wire, but when I tried to turn the Cruise control on, nothings happens. I swapped the stalk with the one in my wifes rav-4 and it didnt worked also, but the one I bought worked in the Rav-4, so the problem is not the stalk, or the wire. Is there any optional procedure or relay that I need to install?
Thanks in advance for your help, looking forward to see my Yaris with cruise.
magnum23 is offline   Reply With Quote
Old 10-13-2010, 08:48 PM   #29
Does it have an auto or manual transmission?
Old 10-13-2010, 08:55 PM   #30
magnum23
Drives: Blue,Sedan
It have an Auto transmission.
Old 10-13-2010, 08:59 PM   #31
OK. I just noticed that you said that you have a 2009 Sedan and the wiring was in place. So, you had the blue and brown wires, not just the black horn wire on connector D3 (the one on the bottom of the steering column)?
Old 10-13-2010, 09:09 PM   #32
magnum23
Drives: Blue,Sedan
Yes just double checked and it have the 3 wires in place.
Old 10-13-2010, 09:21 PM   #33
OK - Just to triple check - We're talking about the connector next to the yellow one on the left side of this picture?
If that's good, look at the part number on the ECM (The silver box on the passenger side of the firewall) and post it. I don't know if anyone from PR has tried the cruise mod, and I think that you might get a different version of the ECM, from what we get here.
Old 10-13-2010, 09:32 PM   #34
magnum23
Drives: Blue,Sedan
Yes that is good, mine is exactly as the picture you posted, where exactly is this part, (The silver box on the passenger side of the firewall)?
Old 10-13-2010, 09:35 PM   #35
Pop the hood and look to the left:
Old 10-13-2010, 09:41 PM   #36
magnum23
Drives: Blue,Sedan
Mine is 89661-52J50
