BOV... recirculating or vent to atmosphere?
I've read that while using a MAF for airflow metering, you should be using a recirculating BOV. If that's the case, do you want the MAF to be on the intake or discharge of the turbo?
I can see a venting BOV to be a problem if the MAF is before the turbo as you'd be expelling metered air and would run crazy rich when you let off the throttle. Those with turbos, what's your setup? |
I have the Turbonetics kit in my tC, it has a recirculationg BOV. I think many bolt-on kits work that way for the reasons you mention.
on the Yaris, my BOV is installed right on the intercooler.
#3 | |
![]() ![]() Drives: Yaris RS 2009 5DR Join Date: Jul 2009
but on your yaris is the bov exhaust air in the piping ? or atmospheric ?
Megan Racing Coilovers - HID 6000K - Fog Light 12 000K Blue - 50/70/90 Tinted WINDOWS - Short Shifter TWM - Rota Sliptream 16x7 Direzza StarSpec 205/50r16 - Injen CAI - R1 Concept Slotted Rotors - Carbotech Brake Pads XP8 - SS Lines - Sparco Steering Wheel - 23MM Rear Sway Bar - Ultra Racing rear, under and fender brace - Borla Axelback |
やりすぎだ~
If you install a recirculating BOV, the discharge end of the BOV should lead back to the intake - anywhere between the MAF and inlet of the turbo. T
#5 | |
But Cali's Yaris is running a MAP sensor. Right?
^ correct. but it was also vented to atmosphere when I first ran the turbo at 8 psi on the ECU.
And you didn't have any stalling issues from the system going rich when you let off the throttle?
C'est la vie
Drives: 2009 2 door hatchback Join Date: Aug 2009
I vent to atmosphere. My BOV is adjusted a little tight. Once in a while I will dye out if I stab the gas in first and then shift to neutral and let idle. This will cause that very rich idle condition. But during all other normal shifting and full throttle driving its just fine. I was thinking of recirculating just to see how the car reacts.
#10 | |
| air vent control | nazier | DIY / Maintenance / Service | 0 | 07-05-2010 04:58 AM |
| Installed hood deflector, in-channel vent visors and hood seal. | IsLNdbOi | Cosmetic Modifications (Exterior/Interior) | 16 | 12-20-2008 09:36 AM |
| FS: NIB AutoventShade In-Channel Vent Visors + Like NIB TYC Tail Lights. | IsLNdbOi | Items for Sale by private party | 14 | 12-11-2008 03:27 PM |
