![]() Drives: Toyota Blade Join Date: Jul 2010
More cruise control
Hi all
I have read all I can find about installing cruise control but nowhere have I been able to find any info on installing extra pins on the clock spring. Let me explain. The car has all that is required for the install e.g. dash light, hole in side of steering wheel. The problem is, there is a plug hole next to the airbag plug on the clock spring but it doesn't have the two pins required for the switch to connect to. My question is, is it possible to install the two pins? I know I can get the pins from Toyota as "spiral connector repair terminal 82998 12870. |
It is possible to install the extra pins in the spiral cable connector (the white 4 pin connector, that currently just has one pin for the horn).
Spiral Cable Connector - Insert Pins.JPG |
Thanks for that. Does it not affect the horn and are there wires in situ on the ECM side of the spiral connector?
Hi CTScott
I have read your help articles with great interest. They are fantastic. With reguard to my situation, I forgot to mention this cruise control is not for a Yaris. It's for a Toyota Blade which is very similar to the Auris or Corolla Hatch. The part numbers are identicle. If you go to the supplied link http://www.toyotaownersclub.com/foru...howtopic=86751 you will notice that there are three plugs. My problem is that in my case. the right hand plug exists but there are no pins inside. Do you know whether it is possible to add them. As I explained earlier, the instrument panel has the "cruise" light but at this stage I am not sure if the cable from the back of the clock spring to the ECM exists or if it's possible to add it. |
#5 | |
Thanks for the info. You are right with reguard to the EWD. Trouble is, I cant locate one for the 2007 Blade or Auris. Any suggestions.
#7 | |
http://www.toyota-tech.eu/ |
| Cruise control install 2009 Yaris 3 door | PeteZNY | DIY / Maintenance / Service | 125 | 03-31-2024 09:22 AM |
| DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag | CTScott | DIY / Maintenance / Service | 307 | 04-04-2023 03:43 AM |
| OEM Steering wheel with cruise control? | suckerface | Cosmetic Modifications (Exterior/Interior) | 9 | 07-25-2010 08:40 PM |
| Cruise Control - Again! | CB900F2 | DIY / Maintenance / Service | 47 | 06-17-2010 06:29 PM |
| Cruise control vs MPG | YarisOwnersDad | Fuel Economy Forum | 15 | 05-29-2009 03:55 PM |
