Old 08-01-2010, 08:10 PM   #271
CB900F2
Drives: 08 Sedan
Good news for CND 2008 Sedan owners.. The wiring is there to the ECN. I will assume all the wiring in the steering wheel is also present..
Not sure about the US version of 2008 Sedan and if the wiring to the ECN is there..
Here is a photo I took of the ECN connector..
On your 08 sedan, I am pretty sure that you will need to run the wire from the other end of the clockspring to the ECM, as all 08 liftbacks require that wire to be run.
CB900F2 is offline   Reply With Quote
Old 08-02-2010, 07:46 PM   #272
Yarisduder
Yarisduder's Avatar
Drives: 2007 4dr Sedan Silver Streak
I have that blue wire but the one connecting that blue wire to D3 is absent. So you should take off the three screws holding the bottom of the column cover on to check. It doesn't even take 5 minutes.
Yarisduder is offline   Reply With Quote
Old 08-02-2010, 08:46 PM   #273
CB900F2
Drives: 08 Sedan
Hi Yarisduder.. Well... you are right!... pulled off the cover and the CC wires are not there!.. GOD DAM!!!..
Old 08-03-2010, 05:16 PM   #274
Bluffnaked
Drives: 2007 Toyota Yaris
Before I make any modifications, can anyone confirm if I in fact have the CC wires. I've been looking at my wires for a while and the DYI guide, and it's hard for me to tell if I do or don't.
http://www.thecnz.com
Bluffnaked is offline   Reply With Quote
Old 08-03-2010, 05:34 PM   #275
You do not. See the white connector with the one black wire - That would have a brown and blue as well if you did.
Old 08-03-2010, 06:18 PM   #276
Bluffnaked
Thank you CT, I didn't even notice that one until you pointed it out lol.
And success, installed and working like a charm. Thx to CT for the indication box, and the PDF. Although I think the DIY PDF reads wrong about the location of A21.
"4. Run the positive wire (red wire on last page pictures) to pin 40 of ECM connector A21. This connector is the one on the right plugged into the ECM (left side of the engine bay if you are standing in front of the car). You must first cut the ziptie, push the clips (I used a small screwdriver) and undo the hooks to remove the cover as shown by nickhjort in the following picture. Then you push the little rubber that is in the pin40 out with a pin and get your wire through. I suggest that you skin the wire on 1-2 cm, twist it and then cut it as close as possible to the connector after you pulled
it from the other side."
On my car A21 is the right side of the ecm when I'm standing in front of the car, it's the smaller one of the two. When you read the above paragraph from the DYI PDF, it starts to say right side, then goes to say "left side of engine bay if you are standing in front of the car". This threw me off, so I wrestled with the other connection which is a lot harder to get off for a while, till I realized I had the wrong one. LOL anyway just wanted to point that out. And of course I do appreciate the DYI, because I was close to having the dealer install it for me for the tune of $500 big ones.
Old 08-07-2010, 11:48 PM   #277
drunix
Drives: 2010 Yaris 3D LB
I just finished a 1000 mile trip with the 2 button cruise control and I liked it so much that I upgraded to a variation on the 4 button version. While on the road I picked up a MOMENTARY-OFF-MOMENTARY toggle switch (at HSC Electronics in California, $1.49). I now have Up=RES/+ and Down=SET/- on the switch, a low profile Microswitch push button for On/Off and a C&K white pushbutton for Cancel.
By using 3 differently shaped controls, I can feel the difference, so I don't need to be able to see them. I had the push buttons in my stash.
The toggle switch is similar to this: http://search.digikey.com/scripts/Dk...name=EG2388-ND
Note also this is a 2010 Yaris automatic, stripped down (no power package), and it had the cruise control wiring in place.
drunix is offline   Reply With Quote
Old 08-08-2010, 02:29 PM   #278
sheraz2000
sheraz2000's Avatar
Drives: Vitz 2006
Send a message via MSN to sheraz2000
i have one question here.
My yaris D3 connector has one cable (black). When i remove this connector, the horn stops working. is it the horn connector ? what kind of power does this cable provide. Negative or positive ? also the pin 40 on the ECM doesnt contain any sort of power when i check it with a power meter. Is it supposed to have any pulse or something? i am just a little worried to not damage the ECM by doing this sort of a setup. Is it safe ?? 100% ?? :p
---- its fun to be in a vitz!
sheraz2000 is offline   Reply With Quote
Old 08-08-2010, 04:23 PM   #279
CB900F2
Drives: 08 Sedan
Scott... It appears for my 08 CND Sedan, the wire run from the ECU to AD4 is there, and what is missing is the wire run from AD4 to D3..
Since AD4 is tucked way in the top left side of the inner dash, not sure if you have ever taken apart your Yaris's top dash, and if you have noticed if both ends of AD4 have the light blue wire.. I am really hoping Toyota has the wire run from AD4 to D3, but only decided to tuck away the run from AD4 to D3 some where.
I would find it odd that all of the other wiring is there as even the clutch switch is there, but they manufactured the wire harness with only missing the run from AD4 to D3
What do you think?
Old 08-08-2010, 10:00 PM   #280
I don't believe that Yaris for your area have the cruise functionality. Besides that, the black wire is the horn. There are two additional wires that get added to D3 for cruise control.
Check out this thread for more info:
http://www.yarisworld.com/forums/sho...ght=faq+cruise
Old 08-08-2010, 10:02 PM   #281
What do you think?
Getting to AD4 requires removing the top of the dash. The wire from AD4 to D3 is definitely not tucked, as it would be part of the harness that also contains the horn wire.
Old 08-09-2010, 12:40 AM   #282
sheraz2000
sheraz2000's Avatar
Drives: Vitz 2006
In my area YARIS is not available, so i had to buy it from JAPAN. Does it work with JAPANESE models ??
Old 08-09-2010, 12:43 AM   #283
sheraz2000
sheraz2000's Avatar
Drives: Vitz 2006
also i have got a Yaris sedan (BELTA in japan) . got 3 wires in D3 connector. Got it also from JAPAN. can i do the CC with both these cars ??
Old 08-09-2010, 08:51 AM   #284
If the Belta has blue and brown as the other two wires in D3, then it should work. If it has the cruise control indicator in the cluster, then to test it just jump the blue to the brown with the ignition on and the CC indicator should light.
For the other, which just has the black wire, the best quick test is to measure the voltage on the ECM pin (A21-Pin 40) with the ignition on. If CC is active on the ECM, then that pin will have 12V on it.
Old 08-12-2010, 04:32 PM   #285
Daren
Drives: 08 Black Liftback S
Hello!
I have a question, I hope you all don't mind....
I have an 08 liftback, MT, without wiring. I've installed the buttons and the wiring to ground and ECM. I don't have a harness for the clutch switch, so I need to rig the switch to go into the fuse box in the engine bay. (If this is wrong please correct me)
The clutch switch has two contacts, so I assume I run two wires off of those contacts into the fuse box. My question is which wire goes where? Looking at the picture on the top of the 4th page of the pdf, I'm not entirely sure.
Daren is offline   Reply With Quote
Old 08-12-2010, 06:11 PM   #286
r0chin
Drives: Sedan 2009 Automatic
Would this work on a 2009 Sedan?
r0chin is offline   Reply With Quote
Old 08-12-2010, 08:39 PM   #287
firemachine69
School'er of hard knocks
Drives: Silver Yaris 4dr. HB
Got my cruise stuff, now I'm just waiting for a day off to go get it installed.
Old 08-12-2010, 09:12 PM   #288
Yes:
Cruise Control Available for 06/07 Yaris TOYOTaejien General Yaris / Vitz Discussion 8 08-27-2010 12:58 PM
