Old 07-21-2010, 10:04 AM   #1
STC
"LibertyRides!"
STC's Avatar
Broke 50 MPG
Hi Everyone:
Well, it's been two months since I first broke the 50 MPG barrier. Just filled up my tank early this morning and the calculation came out to 51.542... I filled-up at the 7th Bar (1/4 Tank).
I have been using the same hypermiling techniques that I've learned from this great Fuel Economy Forum! The only difference in driving this time rather than in May is that it involved a shorter trip (200mi), changing the tire pressure from 38 psi to 42 psi, and me using my A/C 1/2 the time of the trip.
I have noticed with the vehicle that when the weather is hot the engine really likes the heat! Using the A/C more than usual for me seems to not have any effect on gas mileage? Has anyone experienced the same? I have increases my tire pressure. It's been in the upper 80's and low 90's in PA. The trip was during the height of the heat wave in the Northeast.
I'm going to be taking another short trip at the end of this week and in the beginning of August. It would be nice to get two consecutive +50 MPG on this tank?
Cheers!
Gas Tank mile increments (non-ethanol gas used):
1st Bar drop (8/8) > 102 mi (102)
2nd Bar drop (7/8) > 86 mi (188)
3rd Bar drop (3/4) > 50 mi (238)
4th Bar drop (5/8) > 62 mi (300)
5th Bar drop (1/2) > 74 mi (374)
6th Bar drop (3/8) > 72 mi (446)
7th Bar drop (1/4) > 52 mi (498)
8th Bar drop (1/8) > 0
Tank total : 498 miles
Fuel used: 9.662 gallons
MPG: 51.542
~ Mark ~
Old 07-21-2010, 11:45 AM   #2
R2D2
Crazy Oil Sniffer
R2D2's Avatar
Nice work my friend! That's awesome economy. I too have noticed the Yaris LOVES heat to the point it helps to offset the use of AC. I just got two of my best tanks ever (46.2 and 45.4 mpg-5dr LB auto) in humid 80-90 deg weather with almost constant AC use.
R2
-The Fitful One
Old 07-21-2010, 12:05 PM   #3
KrazyDawg
KrazyDawg's Avatar
Drives: 08 3dr LB AT
Congratulations. So when are you going to get that Ecometer or Scangauge to post some higher numbers ;)
KrazyDawg is offline   Reply With Quote
Old 07-21-2010, 02:44 PM   #4
STC
"LibertyRides!"
STC's Avatar
R2
Thanks...
I'm very pleased with the car's FE! It is exciting everytime I fill-up and wait for the pump to "click'...
For once I don't mind going to the gas station!
Cheers!
~ Mark ~
Old 07-21-2010, 02:54 PM   #5
STC
"LibertyRides!"
STC's Avatar
Thanks...
Funny thing you ask! I've been eyeing the Ecometer or Scanguage for some time now. Don't know which one to get?
In August, I'm purchasing from Garm a rear sway bar. I found out he also sells the Ecometer for $59.95... that's a good price! I may just be placing an order now for two items...
Cheers!
~ Mark ~
Old 07-21-2010, 07:28 PM   #6
KrazyDawg
KrazyDawg's Avatar
Originally Posted by STC View Post
Thanks...
Cheers!
That's where I ordered mine from. He price matched with free shipping. I should be getting mine tomorrow.
Old 07-22-2010, 01:14 AM   #7
R2D2
Crazy Oil Sniffer
R2D2's Avatar
Thanks...
Cheers!
I couldn't agree more-fill ups are "events" for me as well.
-The Fitful One
Old 07-22-2010, 01:26 AM   #8
bkrownd
bkrownd's Avatar
Drives: 2010 Yaris "5-door"
I'm stuck hovering around 44 MPG. I need to start riding my bike to work again to eliminate all those 2-5 mile MPG-killing commutes. Then I will join the "50 Club" as well...
I'm surprised about the heat effect, since I always thought colder/denser air in the intake would give a bit more power? My car won't get any "heat assist" here, anyhow.
bkrownd is offline   Reply With Quote
Old 07-22-2010, 03:51 AM   #9
firemachine69
School'er of hard knocks
Drives: Silver Yaris 4dr. HB
Cold/dense air requires more fuel to combust, hence the increase in power.
However, more fuel is detrimental to FE.
Hence why hot air will benefit the Yaris in your quest for FE.
Old 07-22-2010, 03:50 PM   #10
bkrownd
bkrownd's Avatar
If there was excess power you'd be accelerating. To maintain speed you'd respond by reducing throttle to eliminate the excess power and it would balance out to the same FE. There has to be another or more specific explanation, like a decrease in power output per unit fuel flow rate for colder intake air.
To take it to the limit, your arguement suggests that the thinner the air gets the higher the fuel efficiency will be. It obviously isn't that simple.
Old 07-23-2010, 02:06 AM   #11
firemachine69
No, it really is that simple, that's the basics behind the "CAI", or "Cold Air Intake".
Old 08-04-2010, 11:47 AM   #12
STC
"LibertyRides!"
STC's Avatar
Update: Broke 50 MPG... again
Hi Everyone:
Just the other day, I was able to reach consecutively 50+ MPG... this time 52.166 MPG.
No different techniques then last month... and the same tire pressure. The only difference is I took two trips (200mi and 100mi) instead of one.
It has been very hot and muggy! The Yaris loves the heat and highway trips...
I'm using the A/C still about 1/2 the time of my driving. It seems that using the A/C has not had any affect on fuel consumption...
Hopefully, I can make three consecutive 50+ MPG tanks? The cooler weather will be coming soon, the Yaris does not perform as well in FE for the PA Winter Season.
Cheers!
1st Bar drop (8/8) > 112 mi (112)
2nd Bar drop (7/8) > 85 mi (197)
3rd Bar drop (3/4) > 40 mi (237)
4th Bar drop (5/8) > 73 mi (310)
5th Bar drop (1/2) > 83 mi (393)
6th Bar drop (3/8) > 60 mi (453)
7th Bar drop (1/4) > 55 mi (508)
Tank total : 508 miles
Fuel used: 9.738 gallons
MPG: 52.166
~ Mark ~
Old 08-04-2010, 12:52 PM   #13
BailOut
Steals terrorist's lunch
BailOut's Avatar
Well done!
- Brian
Share the Road
Old 08-04-2010, 04:49 PM   #14
RED87
Drives: 2010 Yaris 5 Door Liftback
Wow your getting better mileage than I am in my 2010 5 Door LB auto What state do you live in? I live in UTAH and I average 36-40 miles per gallon...
RED87 is offline   Reply With Quote
Old 08-04-2010, 06:35 PM   #15
KrazyDawg
KrazyDawg's Avatar
Hi Everyone:
Cheers!
MPG: 52.166
What's the low and the high in your area?
Old 08-05-2010, 05:37 PM   #16
STC
"LibertyRides!"
STC's Avatar
What do you mean? Is this something you gather from Ecometer or SGII?
Cheers!
~ Mark ~
Old 08-06-2010, 12:40 PM   #17
KrazyDawg
KrazyDawg's Avatar
Cheers!
Sorry, I meant the temperatures. I'm trying to figure out what's the optimal temp for the Yaris to run in.
Old 08-08-2010, 12:46 PM   #18
STC
"LibertyRides!"
STC's Avatar
Both trips I traveled in the late morning into afternoon. The outside temperature was at around 90-92 degrees with high humidity... very sticky. I used A/C over half of the time.
Cheers!
~ Mark ~
3000 mi Summer Trip Log...MPG included! slothman86 Fuel Economy Forum 14 07-20-2010 12:15 PM
Finally broke 40 mpg brg88tx Fuel Economy Forum 5 07-16-2010 08:34 AM
Better MPG in the City vs. Hwy Loren Fuel Economy Forum 21 01-29-2010 11:49 AM
My progression into hypermiling BailOut General Yaris / Vitz Discussion 8 10-13-2009 06:31 PM
Anyone from Missouri? MPG problems inside 4MPG Fuel Economy Forum 31 12-17-2008 05:48 PM
