Old 08-09-2010, 03:47 AM   #1
Parmas
Parmas's Avatar
Drives: Vitz RS Turbo
I need Help on Idle Control
I have a problem regarding the IDLE control connection. Do anyone knows where I can find a diagram showing the idle control connector and it's terminal connections.
The connector is 3 wire : Red/Black - Yellow/Black - Brown
I need this to connect it to the standalone ecu.
Please note that I am referring to the 99up yaris idle control where the throttle is by cable and not electronic.
Thanks
Parmas is offline   Reply With Quote
Old 08-09-2010, 10:16 AM   #2
Here you go:
ENGINE CONTROL.pdf
Old 08-10-2010, 07:19 AM   #3
Parmas
Parmas's Avatar
Here you go:
Attachment 35800
Thanks for the pdf but I am still not understanding the diagram exactly.
If you can help me identify which of the wires are positive and neutral and signal would be good
I only found this related ( see attachment)
Thanks
Old 08-10-2010, 08:01 AM   #4
From the PDF:
Brown is ground
Red/black is the signal
Yellow/Black is +12
Old 08-11-2010, 07:00 AM   #5
Parmas
Parmas's Avatar
Thanks CTScott I appreciate your help
From where can I get the full manual of this?
Or at least do you have the page where it mention duty cycle and frequency or any related information on the Idle control signal specification?
Old 08-11-2010, 09:35 AM   #6
PM me your email and I'll send you what I have for your vintage of Yaris.
Warning - Broken control arm bolt! CB900F2 DIY / Maintenance / Service 460 08-23-2020 05:54 PM
Cruise Control - Again! CB900F2 DIY / Maintenance / Service 47 06-17-2010 06:29 PM
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 03:55 PM
