Old 08-31-2010, 12:09 PM   #1
chrisj
Hooch Brewer-Shine Sipper
chrisj's Avatar
Drives: 2009 5-dr LB
Getting Rid of That Space!
I recently put on some 17-inch rims, but hate all that gap between the tire and the wheel well. I have a question about it.
Would it be possible to get a different tire size for the rim that would help take up all that slack space without looking ridiculous? That would be my alternative to lowering the car on the tires. Is something like that possible, and what would it look like?
chrisj is offline   Reply With Quote
Old 08-31-2010, 12:21 PM   #2
DeathBeard
DeathBeard's Avatar
Drives: 2010 Yaris S
what tire size are you running right now?
"In his heart a man plans his course, but the Lord determines his steps."
Proverbs 16:9
DeathBeard is offline   Reply With Quote
Old 08-31-2010, 01:01 PM   #3
Klink10
Klink10's Avatar
I'm in the same boat you are except I'm dealing with 16's. Trying to keep the same wheel diameter that was with my previous wheel package. It appears you might be running 30's or 40's. You could always go up (45/50/55/60) as far as tires go or just plan on some kind of lowering with either a spring/damper kit or coilovers. I wouldn't know about the look as far as the tire wheel combo but those seem to be the only solutions to your dilema as far as decreasing gap that I can see.
Old 08-31-2010, 01:51 PM   #4
33OH
Drives: '08 Yaris
It is possible to fill it more with a larger profile but it will not eliminate the wheel gap and it will also raise your car.
I would just lower it.
Old 08-31-2010, 02:29 PM   #5
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
What he said.
Also using different size tires could mess up your speedo and odometer, and will of course change how your car handles as well.
With the MI springs being so inexpensive, they are a natural fit.MI springs.
Colin Chapman disciple
Old 08-31-2010, 04:15 PM   #6
chrisj
chrisj's Avatar
Thanks for the info. Idiot me thought when I changed from the stock 14's to the 17's that the tire would fill in that gap. Of course, with a low-profile tire that doesn't happen.
I will check into those springs. Another ? How much to lower safely? I had been reading 1.5 inches or 2 inches. What about load? If I get 4 people in the car, are the tires gonna rub?
Old 08-31-2010, 04:16 PM   #7
chrisj
chrisj's Avatar
Okay, sorry. I clicked the springs link and saw it was 1.75 inches. But still, how about load? Obviously I have never done these things to a car before.
Old 08-31-2010, 04:45 PM   #8
33OH
Drives: '08 Yaris
Most of that depends on the width and offset of your wheels, and also tire size.
  • The back of the rim will say ETxx (xx being a 2 digit number) - that is your offset.
  • Your wheel will also say 17 x ? JJ (the ? being the width in inches).
  • And tire size? 205/40/17 (just an example - 205 is width in mm, 40 is profile, 17 is rim size)
If you let us know these, we can let you know if you will rub or not.
Old 08-31-2010, 07:28 PM   #9
kimona
kimona's Avatar
Drives: 2014 White VITZ
You haven't indicated your current tyre size.
Old 08-31-2010, 09:14 PM   #10
chrisj
chrisj's Avatar
Sorry again, they are 205/40R17
Old 08-31-2010, 09:34 PM   #11
Klink10
Klink10's Avatar
My bad on the profile thought as I didn't think about what happens on top also occurs at the bottom. Ding.
What 330H said, offset is an important number to know I found out.
Old 08-31-2010, 10:37 PM   #12
kimona
kimona's Avatar
On stock suspension, 205/40's look ridiculously short. Toyota OEM 17's are 205/45's.
Many people install 205/40's when upgrading because they are dirt cheap compared to 205/45's... and they fit quite well with a significant drop. But, with a mild to moderate drop, I think 205/40's are still too short.
In Japan, Vitz enthusiasts sometimes install 205/50/17's on stock suspension... and although they are a bit tall, they look good and apparently work well unloaded.
Old 08-31-2010, 10:59 PM   #13
sleey0
Drives: 2008 Yaris LB
205/40's work well on 17's with any drop, from 1.1" to 2.0".
sleey0 is offline   Reply With Quote
Old 08-31-2010, 11:56 PM   #14
chrisj
chrisj's Avatar
Thanks for the responses.
So, if I go with 205/50/17's then I won't need to lower? And if I do go that 1.75" lower the 205/40/17's I have now will look okay?
Old 09-01-2010, 10:23 AM   #15
33OH
Drives: '08 Yaris
You'll still have wheel gap. Only way to get rid of it is to go lower.
Here are 205/50/17's on a stock Yaris sedan.
Old 09-01-2010, 10:43 AM   #16
chrisj
chrisj's Avatar
Thanks for the pics. I see with the 50's there is more sidewall, right? Okay.
Old 09-01-2010, 11:38 AM   #17
DeathBeard
DeathBeard's Avatar
lol, double confirmation
Proverbs 16:9
Old 09-01-2010, 12:08 PM   #18
MUSKOKA800
MUSKOKA800's Avatar
Lowering is your best resolution.
Taller than stock tires may fill the gap however IMO the negatives are considerable.
More overall wheel weight brings slower accelleration, decreased brake effect and a raised are never handles as well.
On the good side those tall speed bumps will be less of an issue.
Ooopps... new space propulsion method GeneW Off-topic / Other Cars / Everything else Discussions 2 04-18-2009 12:06 AM
Get rid of the vertigo stock susp. w/out lowering much regal Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 03-13-2009 02:31 PM
DIY: Crosspost of how to get rid of DBW Lag! Nexus1155 DIY / Maintenance / Service 7 09-14-2007 02:26 AM
Toyota Auris space concept Fer.pa Central and South America 9 06-26-2007 03:45 PM
Enough Space? soros151 Performance Modifications 24 07-21-2006 03:43 AM
