Old 09-14-2010, 05:59 PM   #1
vwtech
Drives: 09 jetta tdi dsg
clutch replacement
Just wondering how long a clutch replacement usually takes on a yaris I'm changing mine on saturday due to my input shaft seal leaking and soaking my clutch. Also once you get the subframe out of the way how much room do you have to work? I'll be working on a rack with a trans jack so it should make it a little easier.
vwtech is offline   Reply With Quote
Old 09-14-2010, 06:11 PM   #2
Kal-El
Kal-El's Avatar
Doubt anyone's changed theirs. Most members with high mileage report no problems. Even the member with over 400,000 miles. How many miles on yours?
Old 09-14-2010, 06:11 PM   #3
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
you might want to PM Cali_Yaris (Garm). He has had plenty of experience as I believe he may have upgraded his a couple times.
Old 09-14-2010, 06:27 PM   #4
vwtech
75k and the oldest one is only 3 years old so that could be the lack of clutch replacement. I'm going with an aftermarket sachs I hate the stock clutch it engages within like 3mm its like an on off switch.
Old 09-14-2010, 07:08 PM   #5
eazyace
Drives: Toyota Yaris 3dr
Just curious but do any of you have problems when shifting to reverse? Sometimes I get a weird noise when shifting to reverse and sometimes it's harder than other times even though the clutch is pressed all the way. Any inputs?
eazyace is offline   Reply With Quote
Old 09-14-2010, 07:13 PM   #6
fnkngrv
fnkngrv's Avatar
^ there are a few threads on this...many people have "upgraded" their tranny fluid in their manual Yarii to a synthetic like Redline 90MT or another 75-90 weight Synth. If you perform a search for it you will possibly find what you are talking about. I ordered the Redline fluid yesterday.
Old 09-14-2010, 07:50 PM   #7
eazyace
Thanks! I will search for the upgrade fluid. I hope it helps cause getting tired of that
Old 09-14-2010, 09:04 PM   #8
sleey0
Drives: 2008 Yaris LB
I did the MT90 "upgrade" a couple of weeks ago and it makes shifting easier and much smoother, but the reverse issue is still there sometimes.
I have found that putting it into 2nd before Reverse helps A LOT. I only struggle with reverse occasionally know after figuring that out. lol
sleey0 is offline   Reply With Quote
Old 09-14-2010, 11:10 PM   #9
eazyace
yeah shifting is not a problem its just reverse. idk if its when the car is cold or what?
Old 09-15-2010, 09:47 AM   #10
DebbyM46227
DebbyM46227's Avatar
Drives: 2017 Yaris IA, Pulse Red, Auto
I can't find the thread now, but when mine was brand new I heard & felt a strange noise sometimes after the car had sat overnight, when I first tried to put the gear in reverse. Now I move the gear to first gear, then reverse and I've not heard it since.
Here it is, it's the CLUNK!
http://www.yarisworld.com/forums/sho...ission+reverse
DebbyM46227 is offline   Reply With Quote
Old 09-15-2010, 11:32 AM   #11
eazyace
^ yeah that's feeling I get. I guess it's normal it's just I hope down the line it doesn't screw my gears.
Old 09-15-2010, 01:15 PM   #12
swidd
Drives: Yaris HB
I believe the manual says that if the reverse is hard to get into, you should let the clutch out quickly and momentarily and let it move the gears, then try again.
swidd is offline   Reply With Quote
Old 09-15-2010, 02:08 PM   #13
sleey0
Yeah, I just think that reverse is closer in than we are used to as well.
If you place the shifter in reverse, try to place it very close to 4th. If you swing it to far out, that is when I have the most issues getting it in.
And I am sure it not having synchros has something to do with it not engaging fully down, but it still goes into reverse most times. Occassionaly I will get a grind.
Old 09-15-2010, 07:53 PM   #14
eazyace
Yeah same here with the grid. I just hate that feeling. I have never had that in a car before.
Old 09-15-2010, 08:24 PM   #15
sleey0
I had the grinding issue for maybe my first week with the car.
Once I figured out where and when it likes to be shifted, I no longer have that problem.
Old 09-15-2010, 08:42 PM   #16
Tamago
Tamago's Avatar
Drives: UZJ100
the clutch swap shouldn't take more than a couple hours with a lift and tranny jack. i've dropped the clutch without dropping the subframe (but on an NCP61) it's almost easier to pull the whole engine and do the clutch on a bench, but that's my opinion of course.
Old 09-15-2010, 09:09 PM   #17
sleey0
So, no one knows the approx labor hours for a clutch swap?
Old 09-15-2010, 09:10 PM   #18
Tamago
Tamago's Avatar
Drives: UZJ100
official is probably 5-6
Clutch shudder when setting off in 1st gear BuildCode DIY / Maintenance / Service 87 06-17-2015 07:14 AM
Help Me Find The Right Clutch RacerFreakXXX Performance Modifications 18 10-20-2010 05:20 PM
TRD Clutch put in: Break-in noise? Thirty-Nine Performance Modifications 12 02-11-2010 08:16 PM
Restarting car after popping the clutch... PaidTimeOff General Yaris / Vitz Discussion 21 02-26-2009 01:40 PM
Having clutch issues ? hystria DIY / Maintenance / Service 10 08-22-2007 11:34 AM
