Old 01-25-2007, 11:12 PM   #37
TrancosRt
TrancosRt's Avatar
Drives: 07 Silver HB Yaris
I'll post pics of the cabling once I clean it up. Frankly, that area is a mess right now!!! I cared to get it working, not to make it pretty.
I didn't use a switch. If I need to open it, just roll one lock and the other one will follow. The nice thing about the A1 keyless unit is that about 5s after contact, the doors unlock themselves, and once you turn off the car, they unlock automatically. It's a nice feature really
TrancosRt is offline   Reply With Quote
Old 01-26-2007, 09:37 AM   #38
Treyz
~ ambient one ~
Treyz's Avatar
Sweet W.A.S.P.! Looking to get it in a few months. If I run into problems, you're a local guy ha!
AMBIENTLIFESTYLE
Tri-State Sport Compact EZine
Micro Image
Store - Network - Online
Old 02-01-2007, 07:45 PM   #39
Batmang
Drives: 2007 Yaris LB Black
Originally Posted by rnd243 View Post
I would advise against the switches if you're just doing locks. I mean, the ones in the picture look great, but you don't need them. The locks work fine without them, and there is enough work to install them without extra switches.
Yah, good call, I didn't realize until I researched more that the pre-existing lock switches will lock/unlock both doors at once.
Can any of you guys who have done this install post a quick list of what tools are needed or that you used? I'm pretty new to DIY stuff, so I'm still learning.
Batmang is offline   Reply With Quote
Old 02-01-2007, 08:17 PM   #40
rnd243
Drives: 2007 Yaris Sedan
A tool for popping the door panels and a tool for pushing the ring off the window crank would be nice, but not completely necessary.
A drill
Various screwdrivers
Wire strippers and cutters and stuff
I can't think of much else. You don't need anything you don't have in the garage. The pros solder the wires when they splice into the electrical system. I use those tap connecters. Not quite as permanent, but easier.
rnd243 is offline   Reply With Quote
Old 05-24-2009, 12:41 AM   #41
Taiyaki
アキバ製
Taiyaki's Avatar
I have the same power window kit, but cant find a power source and illumination source to tap to that wont blow fuses. any help?
Old 05-24-2009, 11:53 AM   #42
Liu997
Drives: 2008 Red Yaris LB
Is it possible to get the switches in the panel near the e-brake?
Liu997 is offline   Reply With Quote
Old 05-24-2009, 04:16 PM   #43
squall_x
squall_x's Avatar
Drives: '07 M&M LB
I have a question what is this part I have on red called or where can I buy it? I am reffering to the piece to hold the door cable and the metal piece from actuator thank you.
squall_x is offline   Reply With Quote
Old 05-24-2009, 04:24 PM   #44
squall_x
squall_x's Avatar
Drives: '07 M&M LB
You could potentially put the switches where ever you want. You just need to run more cable to make it happen.
Old 07-28-2009, 06:49 PM   #45
BrianS
Drives: 2007 Yaris 3DR LB
Just Ordered
Hi all! I just ordered the keyless entry/power locks kit below. This thread should come in very handy while I try to install it. I'll try to take pictures of my install as I progress. Thanks!
http://www.a1electric.com/Merchant2/...Code=W01C-712T
BrianS is offline   Reply With Quote
Old 07-28-2009, 11:15 PM   #46
TickleTimeTim
Free Mustache Rides
TickleTimeTim's Avatar
Drives: 2007 Yaris HB
are they both universal kits? would love to have some power windows. and a key faub would be nice too.
Club SHIFT
Old 07-29-2009, 06:04 AM   #47
BrianS
The keyless entry/power locks kit? Yes, it's universal and here is a link to a power window kit on there that some have installed in the Yaris. I actually prefer manual windows, so I won't be doing that upgrade. LOL!
http://www.a1electric.com/Merchant2/...ct_Code=Master
Old 08-28-2009, 01:24 PM   #48
lilriki509
Drives: Yaris
how long does the install take for the door locks and windows?
lilriki509 is offline   Reply With Quote
Old 08-30-2009, 04:27 AM   #49
BrianS
It took me about 4 hrs to install power locks on both doors and the trunk. I'm sure it could be done faster but I work at a leisurely pace. LOL! I did not do the windows, as I like having the manual cranks.
Old 11-24-2009, 12:51 AM   #50
toyota_lover
Drives: Toyota Matrix
How are the motors / locks holding up? Another question, are the power window motors noisy and slower than OEM standards?
toyota_lover is offline   Reply With Quote
Old 11-25-2009, 12:08 AM   #51
yaris prime
Yes- I fit in it.
yaris prime's Avatar
Drives: 2007 Yaris liftback, MT
I put mine in in April... So far no problems.
I'm surprised it doesn't have a pull-start !
yaris prime is offline   Reply With Quote
Old 11-25-2009, 12:34 AM   #52
az_saguaro
What to Mod Next?
Drives: 2008 3Dr HB, Bayou Blue
I have had mine in for over a year without problems. With the exception that I had to readjust one of the lock actuators. As far as the noise is concerned, I would say that both are about equal to that of OEM motors and locks. Initially I didn't hook the horn circuit to the locks, but couldn't hear them engage so I added that wire along with the lighting circuit to flash. The window motors are quiet and smooth and just as fast as oem, but it took me about 3 weeks to stop reaching for the window crank.
az_saguaro is offline   Reply With Quote
Old 08-11-2011, 12:04 PM   #53
keona
Drives: 2008 2 door hatchback
Hi witch kit did you use for your trunk?
keona is offline   Reply With Quote
Old 08-11-2011, 01:53 PM   #54
PROX4x4
1.5 or 2.5 both=0-60 in 8
Drives: 08 Toyota Yaris
Why didn't i see this thread before i did my locks? it took me a long time to figure out the actuator location.
Mine was installed in 5 hours 2 doors only and with a budget of around $40 only. Keyless entry.
PROX4x4 is offline   Reply With Quote
Questions and advice required about power upgrading(windows & locks) W.A.S.P DIY / Maintenance / Service 10 07-22-2009 03:59 AM
Need Help - Electrical (finding Power) Ayka DIY / Maintenance / Service 7 10-12-2006 12:51 PM
The power upgrade thread ChinoCharles DIY / Maintenance / Service 19 09-27-2006 04:14 PM
Custom Sub Enclosure (inc sub, power cap, amp) wado Items for Sale by private party 3 09-18-2006 12:53 PM
