Drives: 09 jetta tdi dsg Join Date: May 2010
clutch replacement
Just wondering how long a clutch replacement usually takes on a yaris I'm changing mine on saturday due to my input shaft seal leaking and soaking my clutch. Also once you get the subframe out of the way how much room do you have to work? I'll be working on a rack with a trans jack so it should make it a little easier.
![]() ![]() ![]() ![]() ![]() Drives: 07 Yaris S Sedan 5-Speed Join Date: Oct 2008
Doubt anyone's changed theirs. Most members with high mileage report no problems. Even the member with over 400,000 miles. How many miles on yours?
Mr. 155 and climbing
you might want to PM Cali_Yaris (Garm). He has had plenty of experience as I believe he may have upgraded his a couple times.
75k and the oldest one is only 3 years old so that could be the lack of clutch replacement. I'm going with an aftermarket sachs I hate the stock clutch it engages within like 3mm its like an on off switch.
![]() Drives: Toyota Yaris 3dr Join Date: Aug 2010
Just curious but do any of you have problems when shifting to reverse? Sometimes I get a weird noise when shifting to reverse and sometimes it's harder than other times even though the clutch is pressed all the way. Any inputs?
^ there are a few threads on this...many people have "upgraded" their tranny fluid in their manual Yarii to a synthetic like Redline 90MT or another 75-90 weight Synth. If you perform a search for it you will possibly find what you are talking about. I ordered the Redline fluid yesterday.
#7 | |
![]() ![]() ![]() ![]() Drives: 2008 Yaris LB Join Date: Jul 2010
I did the MT90 "upgrade" a couple of weeks ago and it makes shifting easier and much smoother, but the reverse issue is still there sometimes.
I have found that putting it into 2nd before Reverse helps A LOT. I only struggle with reverse occasionally know after figuring that out. lol |
yeah shifting is not a problem its just reverse. idk if its when the car is cold or what?
#10 | |
![]() ![]() ![]() ![]() Drives: 2017 Yaris IA, Pulse Red, Auto Join Date: Jun 2010
Here it is, it's the CLUNK! http://www.yarisworld.com/forums/sho...ission+reverse Last edited by DebbyM46227; 09-15-2010 at 10:50 AM. Reason: added a thread |
^ yeah that's feeling I get. I guess it's normal it's just I hope down the line it doesn't screw my gears.
![]() ![]() ![]() ![]() Drives: Yaris HB Join Date: Jul 2007
I believe the manual says that if the reverse is hard to get into, you should let the clutch out quickly and momentarily and let it move the gears, then try again.
Yeah, I just think that reverse is closer in than we are used to as well.
If you place the shifter in reverse, try to place it very close to 4th. If you swing it to far out, that is when I have the most issues getting it in. And I am sure it not having synchros has something to do with it not engaging fully down, but it still goes into reverse most times. Occassionaly I will get a grind. |
#14 |
Yeah same here with the grid. I just hate that feeling. I have never had that in a car before.
#15 |
I had the grinding issue for maybe my first week with the car.
Once I figured out where and when it likes to be shifted, I no longer have that problem. |
#16 |
the clutch swap shouldn't take more than a couple hours with a lift and tranny jack. i've dropped the clutch without dropping the subframe (but on an NCP61) it's almost easier to pull the whole engine and do the clutch on a bench, but that's my opinion of course.
#17 |
So, no one knows the approx labor hours for a clutch swap?
#18 |
official is probably 5-6
| Clutch shudder when setting off in 1st gear | BuildCode | DIY / Maintenance / Service | 87 | 06-17-2015 08:14 AM |
| Help Me Find The Right Clutch | RacerFreakXXX | Performance Modifications | 18 | 10-20-2010 06:20 PM |
| TRD Clutch put in: Break-in noise? | Thirty-Nine | Performance Modifications | 12 | 02-11-2010 09:16 PM |
| Restarting car after popping the clutch... | PaidTimeOff | General Yaris / Vitz Discussion | 21 | 02-26-2009 02:40 PM |
| Having clutch issues ? | hystria | DIY / Maintenance / Service | 10 | 08-22-2007 12:34 PM |
