winter prep....
okay, i know its early but i need to start preparing for winter. im not in a situation to make my car a sleeper (parked all winter) so i need to prepare to drive it in snow. currently its sitting on the ground with stock rims and tires.
my main question is what is better for the winter (if it matters at all), raise the coilovers all the way up or put the stock suspension back in the car? my original thought was to just raise it up on the coilovers but after reading info about lowering kits and the pros and cons to springs vs. coilovers (if u lower ur car with springs and dont change shocks they will work at bottom end and wreck them), i was wondering if the same applied to the higher end of the coilover shocks....... also i know a big thing too is to change to winter tires, i will see how the first snowfall goes and decide from there. also how important is it to change to stock intake? i have also been considering that. we have lots of time before winter becomes a reality so any input is appreciated.
thx for quick reply. the adjustment issue im not too worried about, when i put the kit in i coated it with ani-seize. im more concerned about the shock wearing due to over extension of the shock
Drives: '10 Yaris5drHB+99 4runner LTD Join Date: Sep 2009
winter tires and as much lift as possible
I can tell you winter tires were like night and day. Everything on my Yaris is stock and I think it generally does fine in the snow. Not fabulous like on ice or that freshly fallen slushy stuff, but it's not bad. I have never been stuck.
i have only been stuck once and really it was cuz i went where no yaris should go.... and that was snow a foot deep with a hard surface on it..... when the wheels broke it....omg.... 2 hours later iu was free. lol. dont think winter tires would have helped me.
has anyone ever driven a lowered yaris in the winter? how bad could it be.....
#6 | |
3,300+ at one point.. >:(
Drives: 2010 Hatchback RS Join Date: Aug 2007
![]() ![]() ![]() ![]() Drives: 2008 Yaris LB Join Date: Jul 2010
This will be my first winter in my yaris. I just installed tokicos and nf210s sono going back now. I will just try my best to keep everything cleaned at least once per week.
My injen intake will stay on as I doubt it will hurt anything. I will say that winter tires are an absolute must, at least where I live. |
Only Happy When it Rains
driving a low car in snow is not fun. I had a Saab Viggen, and my front lip was used as a snow plow many times. By the end of my time with it my front bumper was attached by wire, because it always hit something, and constantly fell off. It was a ton cheaper using wire every 6 months or so than replacing clips.
just to show how low it was.(not my car or pic. i wish i could take pics like that.)
Colin Chapman disciple |
Well, I will be parking in plowed areas whenever possible. If I have to walk a bit so be it;)
Guess it is a good thing I went with NF210's instead of the MI springs lol. |
Steals terrorist's lunch
Drives: 2007 Yaris Liftback Join Date: Mar 2007
I live in an area of higher elevation that sees 300-400 inches of snow each year. I just run an all season tire year round (right now I'm on Kumho Solus KR-21s) and keep Spikes Spiders handy for the deep stuff.
- Brian Share the Road I often carry 2 carpool passengers and mountain bikes or snowboards/skis over a 4,500 foot elevation difference. Click the graphic above to see my detailed mileage logs. |
what are spike spiders?
Snows a lot.here and with cheap winterforce tires i never needed any studs or spikes.
lol I live in a pretty damn snowy area but you'd have to be in the Rocky mountains to need those! hahahah |
The Rockies, or in my case the Sierra Nevada mountains.
DWEED
Drives: 3DR 2008 Metorite Metalic Join Date: Oct 2008
I always try to get a coat of wax before the snow falls.
Making a decision without following it with an action is still a fantasy. |
do those count as "chains" on tires?
Oil spraying the whole car is a good idea at this time of year,as oil spraying seems to be a Quebec/Ontario phenomenon you are in luck as i'm sure theres a Krown outlet or something similar somewhere close by..
http://www.krown.com/#process/ |
| Winter Gas Causing Drop in MPG? | MadMax | Fuel Economy Forum | 66 | 03-21-2010 04:46 PM |
| Do you get about 4 MPG less during winter ? | paraganek | Fuel Economy Forum | 24 | 05-18-2009 09:52 AM |
| Winter tire width | Ironphil | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 6 | 04-21-2009 01:47 AM |
| Official "CASTREX" WINTER THREAD | CASTREX | Off-topic / Other Cars / Everything else Discussions | 13 | 10-24-2008 08:19 AM |
