#37 |
![]() ![]() Drives: 2009 3 door Liftback Join Date: Jul 2009
So, who makes a good floor jack with enough lift but is still easy on the wallet?
Thanks, Jon |
#38 |
I like Torin and Arcan jacks for reasonably priced ($150-$250 range) jacks with good reputations. Sears carries a few Craftsman models that would work, but if you read the reviews on them, they seem to very problematic.
#39 |
Joey
Drives: '14 Scion xD 5-speed Join Date: Oct 2008
Damn wish I had checked this thread this morning. I just rotated my tires and in the process put a giant hole in the frame where one of those big rubber tabs used to be
. The plus side is that the tab fits snugly on the contact point of the floor jack for future use, so it hasn't gone to waste.You can get a 2.5 ton Duralast at AutoZone for only $50. Been using one with 2-ton stands for 7 months and still no problems.
Formerly owned Met-Met. '07 Yaris LB 5-speed. A forum post should be like a skirt: Long enough to cover the subject but short enough to keep things interesting. "I don't have an anger problem. I have an idiot problem." -Hank Hill |
#40 |
Tw200--excellent!
Drives: 2010 yaris..absolutely red. Join Date: Jun 2010
Is the Duralast stand "Made in China"?
#41 | |
![]() ![]() ![]() Drives: 2009 yaris 2 door Join Date: Feb 2013
Duralast
#42 |
EDIT* posted this in th wrong thread, i'll re post. Wow...thread necro...
I finally got around to modifying modifying hockey push with an angle grinder. I'm lowered so I cannot aces the front lift point. I usually jack my car up about twice a month so the pinch welds are not adequate for that. I now lift at the pinch welds using a puck and then place my jack stands under my control arms for the front (, close to the subframe , possible). For the rear I place the axle on jack stands this way there is no weight on the pinch welds. Worked well this past weekend with no issues.
| Is MP3 AUX Jack Grounded properly? | iseraph7 | In Car Entertainment + Electronics (audio / video / alarm) | 17 | 07-16-2009 05:51 PM |
| Factory AUX Jack | ojo | In Car Entertainment + Electronics (audio / video / alarm) | 1 | 06-06-2007 09:41 PM |
| aux jack | SurfBabe900 | New YARIS Purchase Forum | 12 | 06-04-2007 02:06 PM |
| New Floor Jack | blacksan | Off-topic / Other Cars / Everything else Discussions | 5 | 05-16-2007 02:32 PM |
| Positions for Jack Stands? | bigsky2 | DIY / Maintenance / Service | 2 | 11-03-2006 01:24 AM |
