Machinist
Drives: Yaris sedan 2010 Join Date: Sep 2010
Rear Sway Bar?
Does a rear sway bar make a real difference? What doest it bring actually?
Absolutly!
It is the bigest bang for the buck you can do for a Yaris' suspension. While it wont make it hande llike a Porche, it does completely transform the handeling. Much has been written about it so do a search here for a wealth of info. |
Modded Moderator
As I've said before, it should come from the factory that way. It's also nice that unlike coilovers or springs, it doesn't modify ride height or comfort level, and is pretty easy to install DIY style. I'm using the TRD bar on mine.
![]() ![]() ![]() ![]() ![]() Drives: . Join Date: Apr 2007
Modded Moderator
I installed mine the same time I did springs and the GT Spec lower strut brace, I didn't notice this. Dunno if its because of the other two mods. Which bar are you using? Any other suspension mods?
Hooch Brewer-Shine Sipper
The TRD is on my short list of things to do.
Tigertec Springs, Tokico Blues, UR 23mm Rear sway bar, V rated tires, I've almost lost it a few times in the rain and on some off ramps
I can feel the difference just feels like It's redy to go ass first into a ditch |
![]() ![]() ![]() ![]() ![]() Drives: 2008 Polar White LB Auto Join Date: Oct 2008
TigerTecs and you think your car has major oversteer? You should try some Teins
or another spring where it's softer in the front and stiffer in the rear, then let's see what you think of oversteer ;) hah I've pushed the car pretty hard myself with the Teins, blues and 23mm ur bar but yet to have the rear kick out on me. For the poster, you cannot go wrong with a 19 or 23mm rear sway bar. It takes 5 minutes to install and a worlds difference in handling and feel. Trust me it's one of, if not the most drastic change you could do to your Yaris in terms of handling aside from full coilover installation. Install a rear sway bar, you won't be disappointed and it doesn't hurt the car one bit. Nothing to lose but alot to gain.
I live my life a quarter pounder at a time. And for those 500 calories or more, I'm free. I need FRIES! Two of them. The big ones. Oh, and I need them tonight. You're lucky the double shot of BBQ sauce didn't blow the seam on your nugget box. There she is, 2 pounds of pure beef. My dad ate it in 9.0 seconds flat. Check it out, it's like this. If I lose, winner takes my happy meal. But if I win, I take the burger and the toy. To some people, that's more important. |
OK........
A rear sway bar will firmly plant the rear end on the road and enable one to take corners faster with little body roll. It goes without saying that if you push a car to the limits of you tire's grip you will kick the rear end out. On reason maufactures build in understeer (eliminate a rear sway bar,etc) is to keep inexperienced drivers out of trouble. An experienced driver knows the limitations of his car/ suspension/tires and does not push it past that point. Having said that, a rear sway bar will reveal a bad tire's limitations. So, good tires will enable more of a rear sway bar's full potential. BTW, an experienced driver is always more careful in the rain no matter what they are driving. Personally, I felt rather unsafe driving the Yaris. After installing the sway bar, I now feel much more safer and secure driving it in all situations.
I've never had the rear end come loose yet, and I've pushed it hard on an on ramp before. I have Tein S.Tech springs, TRD shocks, Tanabe front strut bar, TRD rear sway bar, and a GT Spec rear sway link brace.
You may have lost it a few times because of your tires??? Both the rear sway bar and link brace has actually made my ride more comfortable. Not sure why, may be someone else can explain it. |
#11 | |
#12 | |
![]() EDIT: BTW, here's C&P that should clear things up for some. "Definitions: "Understeer", also known as "push", and "dammit, why won't the car turn?", happens when a vehicle doesn't turn as quickly as the angle of the front wheels would suggest. Turning the steering wheel further just makes the tires slip more. An understeering vehicle wants to point to the outside of a turn, plowing ahead instead of where the wheels are aimed. "Oversteer", AKA "loose", or "OH S*&T!", is when the vehicle wants to turn too far, with the back end sliding around and, in extreme cases, trying to pass the front. An oversteering vehicle feels like it's about to spin, and frequently does if the driver isn't skilled enough to "catch" it. An easy way to remember the difference is that Understeer is when you see what you're about to hit through the windshield, but Oversteer means you see it in the mirrors... A little theory: There are a lot of different dynamics that cause under- or oversteer; the front-to-rear weight bias of the car, the presence or absence of anti-sway bar(s), which wheels are doing the work of accelerating the car, and even the size and type of tires. Most cars come from the factory with a bias towards understeer. That's because it's generally thought that understeer is easier for the average driver to cope with than oversteer, which is probably true. The instinctual reaction for a driver in a sliding car is to lift off the throttle and hit the brakes, which will transfer weight to the front end and increase traction there, helping an understeering car to recover control. Doing the same thing in a car that's oversteering will usually make the situation worse by unloading the rear tires and further reducing their traction. For this reason, you'll almost never see a factory-stock car with a rear anti-roll bar, but no bar on the front. Without getting into a lot of advanced car dynamics, I'll just say that putting a "swaybar" or anti-roll bar on one end of the car (or replacing an existing one with a stiffer bar) will tend to give the opposite end of the car more traction. Thus, most cars come equipped with a front bar but none in the rear, or if they have both, the front bar will be considerably stiffer. This preserves the tendency to "safely" understeer once the limits of handling are reached. It's possible for a vehicle to exhibit both understeer and oversteer at different times. A classic example of this is the first-generation Porsche 911 Turbo. With the weight of the engine over the back axle, a big tire size difference front-to-rear, and an engine that produces a sudden hit of power when the turbo spools up, the old 911 Turbos were notorious for their evil handling characteristics, going from power-off understeer to power-on oversteer at the speed of thought. Porsche has managed to breed these traits out of the newer 911's through careful chassis tuning, redistribution of weight, and the adoption of an all-wheel-drive system for the newest Turbos" It should be ponted out that Toyota sells a rear sway bar for the Yaris (it is overpriced) but, I doubt that they think it's unsafe. Last edited by RedRide; 09-29-2010 at 04:12 PM. |
#13 | |
![]() Drives: Toyota Yaris 3dr Join Date: Aug 2010
^ x 1000000000 That is the main reason why I had a sway bar struts and springs installed. Much better!!!!! Ride quality isnt even that bad. |
never felt that issue at all, and beat my car a good amount. i had a very similar setup except the sway bar being trd for a while, but now i have beatrush center and front brace/c-one struts..stiffen up the rest of the car a tad bit, or something...
Has anyone ever oversteered to the point of almost spinning out? Or do most people just 'feel' the rear end start to step out?
ヤリスワールド
Drives: 2008 HB Join Date: May 2010
Iinstall the rear sway, they work well on these cars.
I installed a rear sway and then hit my favorite corner that i test my cars on and picked up a safe 10-15mph more on the corner and another 5mph with the strut bar...some say the upper front strut bars dont work but it did for me. |
![]() ![]() ![]() Drives: 2010 NCP91 5spd Join Date: Nov 2009
That can happen. . . especially when the inside rear tire lifts off the ground. Snap oversteer is a result of stiff rear suspension (and for me, I prefer it over understeer). I find the transition to be very predictable and very controllable. As long as I can get the car rotated, I can just gun and shoot in the direction that I want to go. However, all this is still a symptom of going into the corner too hot and/or picking the wrong line. Conversely, if this were to happen and understeer were to occur, I'd just hang on and wait for when (and hope that) traction comes back, all while doing my best to unload the outside front tire.
^ They key to driving this car hard is to be to be smooth and slow (in transitions). The short wheel base can quickly load up the wrong tire. If you drive like a typical teenage kid, darting from lane to lane, and jerking the wheel, you'll end up in a lot of trouble. Be smooth, and you'll find that the Yaris has far more cornering grip available than it seems.
The high seating point makes it kinda scary, as it creates greater movement (the higher you are from the center of gravity), just because you have a higher vantage point. However, this can be a benefit, as it also amplifies communication to the driver in terms of how the car's weight is shifting. |
| DIY - rear sway bar [pics] | cali yaris | DIY / Maintenance / Service | 199 | 07-28-2022 05:25 AM |
| Which rear sway bar? | IsLNdbOi | Performance Modifications | 46 | 11-05-2009 06:07 AM |
| Ultra Racing 23mm Rear Stabilizer Bar | Loren | Performance Modifications | 62 | 05-18-2009 07:20 PM |
| Rear Sway Bar Instructions - Additional Pics | SeaYa | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 10 | 02-26-2009 01:05 PM |
| solid torsion bar bushings... the best rear anti roll upgrade | turboyaris | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 28 | 12-05-2008 11:37 PM |
