![]() ![]() ![]() Drives: 2004 Echo HB Join Date: Oct 2008
Chicken lift
Is there an easy way to cure the back end from coming around. I am not sure if it's as simple as carreing to much speed into the corner or if it me lifting once the car starts to push. Any pointers would be great.
Thanks again |
You have oversteer?
What is your suspension set up? Late braking into the corner, or even lifting after starting your turn can cause that. Trying doing ALL of your braking before you turn the wheel, and see how that feels.
Eibach pro kit strut tower brace rear sway bar. 195/50/15 tires. It was on an oval got about a third of the way through the corner before the back end let go.
Are you lifting off the gas when you feel the back end coming around?
Not sure that's the problem. The whole chicken or the egg thing. I think it starts to go then I lift.
What tires, exactly? And what tire pressure were you running when this happened?
#7 | |
I've had the back end pushed out nearly 90 degrees while racing and still recovered. I was at full lock in the direction I needed to go and had my foot to the floor. |
![]() ![]() ![]() Drives: Yaris Join Date: Oct 2008
I'd play with tire pressure, you can do more then you'd think.
Falken 912s 38 in the front 40 in the rear.
If your loosing it a third of the way through the corner. it sounds like you went into it too hot. I dont race, just a watcher, but I'd always heard you slow just as you approach the corner, and back into the gas the second half of it, past the apex.
And I could be full of it too! |
#11 | |
http://www.youtube.com/watch?v=gPCGn...eature=related
#12 | |
Only Happy When it Rains
Colin Chapman disciple |
That was basically what I experienced, but on ice LOL.
#14 | |
well that concludes this thread from the champ himself when in doubt, power through out. |
Wow that's what I thought but the concrete wall were a little intimidating.
| 2010 Yaris lift | eric81 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 17 | 10-13-2015 09:57 AM |
| Sedan Trunk Lift | eggyolk808 | DIY / Maintenance / Service | 9 | 09-11-2013 07:19 PM |
| Finally bought a lift | CTScott | DIY / Maintenance / Service | 26 | 09-28-2010 10:09 AM |
| hood lift? | Qmobile | Cosmetic Modifications (Exterior/Interior) | 19 | 08-14-2010 10:35 PM |
| WeSellCarParts.com // Redline Tuning Hood Lift! | WeSellCarParts | WeSellCarParts | 45 | 12-18-2008 08:12 PM |
