Old 10-06-2010, 09:10 PM   #73
Nexus1155
Bathroom + Laptop = <3
Drives: Audi
Where do you order from that lets you keep cancelling!
Remember, you are going to lose most fluids when doing an engine pull. You really should not have to pull the engine just to do a turbo kit, but if you do, remember to stock up on oil coolant power steering fluid and brake fluid.
You also might not want to pull engine depending on wall clearance, might make it harder to get back in.
Old 10-06-2010, 09:34 PM   #74
sleey0
Drives: 2008 Yaris LB
Well, oif course I aint't pulling that small bastard to just pu the kit on.
I am getting CP 75mm pistons and Crower rods.
"And that goes for any of you, never get put down from someone who gets jealous of you; build it and prove them wrong. There will always be haters and naysayers but those are also the ones who's cars are worth less than my seats."
xbgod - 9/23/2010
sleey0 is offline   Reply With Quote
Old 10-06-2010, 09:37 PM   #75
Nexus1155
Drives: Audi
Still think it would be easier just to remove the head alone and not risk things/fluids too. Also make sure you get some head studs. You cannot reuse stock head studs, most of them now a days are all stretch bolts and thats a no no on reuseability. Same with flywheel bolts.
Old 10-06-2010, 09:43 PM   #76
sleey0
Where can I get 1NZFE head studs?
xbgod - 9/23/2010
Old 10-06-2010, 10:01 PM   #77
Nexus1155
Drives: Audi
Garm got them custom, but Toyota has them for sure i bet at like $5 per stud. Also another way to lower your compression to push more boost is to get a thicker head gasket. I don't know how much your pistons will lower them, but the headgasket is good for another .5 of a drop
Old 10-06-2010, 11:50 PM   #78
Morgan
Morgan's Avatar
Drives: 07 MM LB
Originally Posted by Focus_Sh1ft View Post
Used for power or to stave off detonation? Gimme numbers pleeeeease
How long have you been running the SC and meth?
She did, and it cured detonation problems. Meth injection can be used for more mild purposes, guys, not just big power.
I had a Blitz supercharger and the AEM progressive water/meth set up (the one you have pictured). Worked nicely. I mounted the tank to the back of the "40" seat (of the 60/40 rear bench) in the hatch. The regular washer take is 1.1 qts and you'll burn through that quickly enough. Run the lines through the car, they aren't under pressure until after they pass through the pump.
Since I live in Florida and I installed the kit in May of last year, it was hot, well over 95+ most summer days and the methanol kit was to help with pre-detonation. Yes, you can run 100% methanol or yes, you can run 100% water. I never noticed a huge difference, usually I ran tap water with about 30% by volume of methanol.
If you choose to run straight methanol, it can be very expensive for not a lot of return in power - just save yourself the money, the real power is not found (for this car) in adding water/methanol injection. But it is a lot safer to run in hot weather ESPECIALLY since I didn't have an intercooler.
Cooler intake temperatures are never a bad thing.
Good luck, read my archaic posts if you feel like you'd like to waste 20 mins on my ramblings.... or just PM me
ps I knew from the get go that I was going to have water/meth, so I installed it simultaneously with the supercharger... it is a very nice kit, well worth the $400 - just make sure you get refrigerator tubing for the lines from the tank to pump and pump to injector, the ones in the kit are very thin and will break if you run anything higher than a 30% mixture
Old 10-07-2010, 12:54 AM   #79
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
Not true. The meth actually lasts quite awhile. Depends on how you drive of course. Since I am maxing out at about 8-9lbs of boost, i have my meth kick in at 2lbs of boost. I also buy HEET to use as my meth, and it's only a couple bucks a bottle at WAL-MART. Takes about maybe 8-9 bottles to fill the entire meth kit? A full tank of meth can last me about a month with my driving. However, I don't street race and go into boost every chance I get....
ps: I wouldn't have even gotten the meth kit if i wasn't going to tune with it.
Not true. I am running 99.9999% meth and my stock hose lines haven't broke....
Old 10-07-2010, 02:07 AM   #80
I run 50/50, and I will also disagree with this.
Where exactly did the 30% come from?
Old 10-07-2010, 02:10 AM   #81
He says it will take about 1 hour to get the engine out and about 2-3 hours to install pistons/rods and anothe hour to put it back
That would be the fastest swap I've ever seen. I will keep my healthy skepticism on this detail.
Old 10-07-2010, 02:11 AM   #82
What compression? If not stock, I'm guessing you'll be in trouble with the ECU and a piggyback.
Old 10-07-2010, 05:00 AM   #83
xbgod
Drives: "Burning It Down GTX2860RS XB"
Your engine builder is full of shit, will take a few hours to pull the motor correctly. And if your gonna do some piston changes that change compression and or CC you may have some trouble with that piggy back ECU.
Your engine builder is working in dream land and your in for a wake-up call on this whole thing.
My self and Garm got more time under the hood of these cars than your engine builder probably has in his whole career.
Your whole situation is unrealistic and there is a world of issues headed your way.
A few hours to put new pistons and rods in.
Not if you have file fit rings and you want to check everything. Not to mention you need to knoch the block for the Crower rods to clear.
Also there is no ARP head stud kit for this car. You have to go custom like me and Garm. And untill you go big like him and I you don't even warrent them.
Good Luck with this disaster
XBG
xbgod is offline   Reply With Quote
Old 10-07-2010, 05:18 AM   #84
advocate
Drives: car
don't we have electronic power steering?
Old 10-07-2010, 11:37 AM   #85
The Pauter rods were the same for me.
Old 10-07-2010, 12:54 PM   #86
Nexus1155
Drives: Audi
I dunno, never looked into it. Just saying what you'd need for general motor pulls
Old 10-07-2010, 01:09 PM   #87
Yaris = Electronic power assisted steering
Old 10-07-2010, 01:34 PM   #88
Focus_Sh1ft
Focus_Sh1ft's Avatar
Drives: 08 Yaris Turbo; 06 tC Turbo
Kinda surprised no one has said this yet but uh...
How about you just put the turbo in and deal with pistons/rods/meth/everything else later. It's like you're trying to do brain surgery, file your taxes, build a time machine, and create a dog/cat fusion all at once. What's the rush?
Focus_Sh1ft is offline   Reply With Quote
Old 10-07-2010, 01:47 PM   #89
advocate
Drives: car
I'm guessing he doesn't want to disassemble the turbo once it's on in order to get the new pistons in and sleeve the block if he wants?
Old 10-07-2010, 01:52 PM   #90
Focus_Sh1ft
Gonna be pretty hard to trouble shoot...
But that's probably exactly what the installers want to have happen.
Zage Turbo Kit Install - Toyota Yaris Focus_Sh1ft Forced Induction Forum 160 02-06-2022 09:14 PM
Turbo Project Yaris TS 1.8L CASTREX Yaris TS Talk 40 08-21-2009 11:24 AM
HKS turbo timer type 1 Tamago Performance Modifications 3 07-21-2009 12:59 PM
Turbo Kit - trade for stock parts! crankyelbow Items for Sale by private party 62 02-03-2009 01:30 PM
delayed turbo project... joey1320 Forced Induction Forum 8 09-27-2007 12:18 AM
