#73 |
![]() ![]() ![]() ![]() Drives: Yaris Sedan 5MT Join Date: Oct 2008
While at MI yesterday I got to see a set and saw the instructions. The instructions looked very thorough. Seems some patience, time, and finger/arm dexterity would be needed. Definitely a DIY job.
#74 |
Mr. 155 and climbing
Well after much frustration, sweat, and tears my covers arrived. They are finally installed and for clarification they fit the S Sedans just fine! Thanks go to JBougie (Jinni Lynn) for her assistance with a lot of the job. Total time for install was around 10 hours. This was due to being sidetracked several times as well as making a few mistakes along the way. I took before photos along with a couple photos of the tools used to include beer.
The front seats pretty much went without a hitch after we decided to pull the seats out of the car. I did make a mistake and used a 10mm 6 point socket to remove the seat bolts rather than a Torx socket however we did run to AutoZone and picked up a 4 piece Torx set to put them back in. You pretty much are going to strip the bolts if you use a regular socket so BEWARE! Other than that on the passenger side the removal of the Airbag Circuit Board was a PITA. We ended up unscrewing it from the housing and removing that way. The rear seats were the real challenge. Jinni and I tried 50 different ways from Sunday to pull the bench, but ultimately after much sweat and cussing we called it quits. I stopped by a local upholstery shop and the guy popped the bench in under 10 seconds much to my chagrin. I would actually recommend doing the same if you have the opportunity to do so because it is easy to ruin the bench cushion. That stupid piece of foam will set you back 500 bucks if you have to replace it. Another item of note is that I did have to make a small incision at the slit point for the c bracket that secures the seat in the upright position for the passenger side of the rear seat. No matter how I manipulated the cover I could not get the hole to line up correctly from top to bottom. The slit was also not wide enough for the bracket. I make the incision with an exacto knife and then used 3m tape to tape the flap I created inside the cover. Really even with the seat down you can't notice, but I still had to do it. The whole for the pull knob on the driver's side rear seat section seemed to be too small so it took me almost 10 minutes to get it to seat correctly just by itself. Other than that the only thing that I could really comment on would be fitment on the main cover for the passenger side rear seat back around the pivot bar for the arm rest could have been better. All in All I give the whole experience a 4 out of 5. The covers are magnificent however the actual install process is a bit stressful. If you have the money and the inclination I would have a shop install them to be liable if there is any tearing around the different mounting holes because if you have little patience then you will most likely tear them as others have noted. Thanks Garm for working so hard to ensure that I had the right product in the end! Last item is that I also did the initial install of my heated seat kits. They are ready to be wired in once I get my climate control bezel back from being CF wrapped by Brian. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
#75 |
Drives: 2010 Yaris LB (Prev: 07 Sedan) Join Date: Mar 2009
Here is my editorial contribution to the thread ... he had to test them out before they went back in the car, of course
#76 |
noob-toob
Drives: 2007 yaris 4dr sedan Join Date: Sep 2010
this is a little off topic..
hey fnkngrv, where did you get your mats? or are they DIY? they're looking really good :) PLUS your new seat covers are amazing!
|| "it's a tough job, but somebody has got to do it" ||
#77 |
![]() ![]() ![]() ![]() Drives: 2010 Yaris Sedan Join Date: Oct 2010
#78 |
i want some... def will have to wait til beginning of 2011 though
#79 | |
I don't believe that they are made for the deeper seats, but not 100%. When I bought mine I took a 400 dollar risk and it paid off luckily since we were all worried that they would not work for the S model Sedan. They do and nicely.
#80 |
![]() Drives: 2008 Yaris hatchback Join Date: Dec 2010
Where did you get the Clazzio covers?
| Test drove: Yaris sedan 5spd, Fit base auto, Civic LX 2dr 5spd | Bounty Hunter | General Yaris / Vitz Discussion | 7 | 07-11-2007 07:40 AM |
| yaris Advance Sedan | Rudeshady | Central and South America | 14 | 06-25-2007 01:50 AM |
| Official Toyota Thailand accessories for Yaris Hatch & Sedan | eTiMaGo | Cosmetic Modifications (Exterior/Interior) | 85 | 04-18-2007 07:53 AM |
