![]() ![]() ![]() ![]() ![]() ![]() Drives: Yaris Sedan 2010 "shadow" Join Date: Mar 2010
tires squealing when turning
guys, i noticed when i'm turning at aroung 55ish km/hr my front tires are squeling, i have an aftermarket rims and 195x55xR15 tires,32psi front 30psi rear and on stock suspension, do i need to get an alignment? but when driving straight at around 100km/hr it is not wiggling or something.,is it my tires that's losing it's grip? any ideas
![]() thanks Last edited by syntax; 10-14-2010 at 04:57 AM. |
you're losing traction.
jesus, has it come to this?
![]() ![]() ![]() ![]() ![]() Drives: Scion FRS RS2, ‘21 Crosstrek Join Date: Oct 2008
Understeer / plowing / pushing... all common issues with front-wheel drive cars including the Yaris in OEM suspension trim. It could also be a tire pressure issue or poor quality rubber. Try adjusting your front tire pressure.
Adding a rear anti-sway bar will help reduce understeer with zero negative effect on ride quality. Every Yaris should have one. If for nothing else but safetys sake. The car is much more stable after one is bolted on. And they're inexpensive.
TRD Upgrades: 18" Wheels wrapped in 215/35/18 PZero's, Sportivo Shocks/Struts, Lowering Springs, Swaybar, Axle-Back Exhaust, Oil Cap, Rad Cap, Signage. Aftermarket Goodies: Piggies SS, K&N Drop-In, Blitz S/C, DC Header, NST Pulley) Toyota Options/Accessories: Sport Pedal Covers, Sport Shift Knob, Ipod Interface, Summer Mats, Winter Mats, Cruise Control, Auto-Dim Mirror, Echo steelies with winter boots.
Drives: yw calls me douche and racist. Join Date: Aug 2007
![]() Drives: 2007 Liftback Join Date: Jun 2007
Poor quality rubber in my experience. Sorry. Open differential, alignment good, not a whole lot else it could be.
Joey
Drives: '14 Scion xD 5-speed Join Date: Oct 2008
Ease way off the accelerator while cornering. Pinning it in a FWD car won't make you corner any faster. Matter of fact it's more of the opposite.
Formerly owned Met-Met. '07 Yaris LB 5-speed. A forum post should be like a skirt: Long enough to cover the subject but short enough to keep things interesting. "I don't have an anger problem. I have an idiot problem." -Hank Hill |
![]() ![]() ![]() Drives: 2010 NCP91 5spd Join Date: Nov 2009
If you're driving hard, try raising your tire pressure for a free mod. I would push it to 38-42 all around. But yeah, a sway bar (or full suspension setup) will help to take some of the load off of that outside tire. And last but most importantly, the quality of the rubber will make a HUGE impact. But IMO, even with 55 series tire, the stock Yaris suspension has a huge propensity to really push the outside tire to roll onto it's edge, likely because of the massive body roll and high center of gravity. Pumping up the tires to max inflation does wonders, and above all else, a sway bar will give you more than enough useable traction for street use.
Joey
^Raising tire pressure in the front would reduce grip and cause more understeer. It's happened to me in past Auto-X events when I forgot to let out a little bit of air before my first run.
Whatever the OP decides on, the front should have a lower PSI than the rear, unless he likes feeling like he's driving on butter lol And I agree with the swaybar comments 100%. Should've been an OEM part
Yes, I agree for most cases. But 32/30 F/R on 195/55r15 (essentially the same sidewalk height as stock) is very low, IMO, for aggressive driving. When ever I did a shoe polish test on the sidewalls below 38, I'd get significant roll over on the fronts. But yes, rear pressure should be higher than front for most cases.
Only Happy When it Rains
It had to be said. I mean come on, doesn't slow down come to everyone's mind first after they read that? Is it really that hard a thought?
Colin Chapman disciple |
#13 | |
The last thing we need is all the "hardcore" auto junkies coming here to insult people who have a genuine question no matter how silly some may think that question is. |
#14 |
lol! hardcore? not sure anyone truly hard core would take the time away from wrenching to post on a message board, but that may just be me.
| Best all-season tires for the Yaris? | Rahxephon | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 33 | 03-17-2013 06:40 PM |
| tire noob question..what's the widest tire size can run on stock 15"s? | detroiter | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 22 | 12-06-2011 09:44 AM |
| Newly installed 15" tires feel 'weird' | kristan | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 20 | 04-24-2010 06:58 PM |
| 2007 Yaris bad tires | weaver615 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 17 | 03-27-2010 07:21 AM |
| Brown Tires and Squealing Brakes | captainm27 | General Yaris / Vitz Discussion | 14 | 10-22-2009 12:18 PM |
