![]() Drives: '09 Yaris Sedan Join Date: Oct 2010
Raising Idle speed?
I have a '09 Yaris sedan and want to adjust my idle speed. Is that impossible because of a computer the car runs off of? I just want a little more rpm at idle.
Thanks |
![]() ![]() Drives: '09 Yaris Sedan Join Date: Mar 2010
Same here
Pioneer
Ascendant Audio Sundown Audio DC Power Engineering Knukoncepts Fosgate Stinger |
Your mom goes to college
Drives: 08 Vitz Join Date: Oct 2008
You can adjust the idle screw on the throttle body . Its on the top and its uses a very small allen wrench to adjust it . Im pretty sure you want turn in clockwise to raise the idle rpm . Also you have to adjust with the engine off .
Garm is permanently high because he is the king of smokin' deals! |
![]() ![]() ![]() ![]() ![]() Drives: 2008 Polar White LB Auto Join Date: Oct 2008
I looked myself for this screw and didn't find it. I did see a screw that was encased in glue or epoxy, that you couldn't get to though.
I live my life a quarter pounder at a time. And for those 500 calories or more, I'm free. I need FRIES! Two of them. The big ones. Oh, and I need them tonight. You're lucky the double shot of BBQ sauce didn't blow the seam on your nugget box. There she is, 2 pounds of pure beef. My dad ate it in 9.0 seconds flat. Check it out, it's like this. If I lose, winner takes my happy meal. But if I win, I take the burger and the toy. To some people, that's more important. |
Modded Moderator
That's it, you need to get the epoxy off. Just make sure to adjust your idle when the car is OFF.
Can i ask what reason their is to adjust the idle speed or what would cause it to lower? Since it's epoxied in, I just wonder how it could happen and why you would want to change it.
For me, im running a very large sound system and I need to give my aftermarket alternator 1 - 200 more rpm at idle
Pioneer
oh yeah thanks for helping us find that adjusting screw
Pioneer
Not quite a noob
Can somebody please post a picture of where ti is located? I can't for the life of me find it.
Modded Moderator
It's located here, although this member replaced his idle screw because he stripped his out I believe. The stock screw is recessed, behind some yellowed epoxy. It's in the same area though, hope this helps.
Clockwise or Counter-clockwise to raise the RPM? Thanks again for the help!
Pioneer
Modded Moderator
Oh that pic is at the wrong angle, just tip your monitor/laptop on the right side and you'll see exactly where it is
Not quite a noob
yeah based on this picture I can tell, thanks! I'll give it a shot tomorrow maybe
I found everything and successfully upped my rpm to ~800 + or - maybe. The sound sysytem seems to be liking it 1,000,000 times better.
I took pics of the whole thing so i'll get those up soon. Thanks to everybody that new what they were talking about!
Pioneer
![]() Drives: yaris 2008 Join Date: Oct 2011
idle problem
My car have also problem with idle and idle is going very slow and car is giving vibration if i change this setting which is covered with epoxy ,will it damage the
throttle body and why company is secure with epoxy? Thanks????????????????????? QUOTE=Incillio1;523229]I have a '09 Yaris sedan and want to adjust my idle speed. Is that impossible because of a computer the car runs off of? I just want a little more rpm at idle. Thanks[/QUOTE] |
throttle body and why company is secure with epoxy? Thanks????????????????????? |
It's "expoxied" simply so it wont move due to vibrations and it usually does not go out of adjustment.
However, since it is a mechanical adjustment, it can be prone to some wear that can throw it out of spec just like a standard cable actuated throttle. So, keep in mind that even though it was set at the factory, it stiil may have to to be readjusted depending on conditions. Last edited by RedRide; 10-19-2011 at 04:51 PM. |
turn on your A/C
| DIY - 1.8L 1ZZ-FE TB Connector Chip Swap | Yaris T-Sport | DIY / Maintenance / Service | 332 | 04-03-2022 01:39 AM |
| Cold Idle Speed Question... | cpnnz | DIY / Maintenance / Service | 9 | 11-04-2009 05:31 PM |
| what is the idle speed on stock 09 HB | ezhacker1 | General Yaris / Vitz Discussion | 5 | 05-17-2009 08:49 AM |
| Help with low idle from Venezuela | Yarisvene | DIY / Maintenance / Service | 5 | 06-23-2007 08:23 AM |
| Low idle speed | gonzo452001 | DIY / Maintenance / Service | 9 | 02-21-2007 08:41 PM |
