Old 10-23-2010, 12:45 PM   #37
2009BBPliftback
2009BBPliftback's Avatar
I used to own a stick first gen xb, and that is one thing i loved about it was the gearing. nice to know i can now have that in my yaris monster..
2009BBPliftback is offline   Reply With Quote
Old 10-23-2010, 01:20 PM   #38
Tamago
Tamago's Avatar
Drives: UZJ100
Originally Posted by Niner View Post
If anyone's interested, I've got a Scion xA and want to do the reverse swap - put a Yaris final drive in it. I'm more interested in gas than speed. Used to have a Yaris but lost it in a garage fire (and just discovered I still have a login here).
Not sure how we'd work out the swap (I have a truck, but driving that for very long defeats the purpose of saving fuel). Any takers in Michigan near Lansing or Detroit would be a much better option, or anyone that has the engine out already and don't need the shaft back immediately (with escrow cash or whatever needed so I don't sit on my butt too long.)
Henry
buy an echo transmission, direct swap into the xA.
i know, because i've done it personally.
Old 10-23-2010, 07:42 PM   #39
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
I have a Echo transmission for sale. It's parts only though as it has a C160 bell housing bolted onto it to keep it all together. It's basically the leftovers from my 6 speed conversion. But there'd be no problem with swapping the guts into the xA transmission.
PM me if you're interested. Only asking $150CND plus shipping.
Old 08-07-2011, 09:48 AM   #40
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
So after a read-through of the transmission repair manual, this is NOT something that a weekend DIY-er like myself should mess with--unless the have access to a large number of specialty tools and/or can afford to have their daily driver out of service for several days. I had contemplated buying a used tranny and pulling it apart, but the sheer number of SST's involved is intimidating.
In addition, the cheapest ones I can find locally are in the $350-400 range. It would almost seem to be more cost effective to just buy the new OEM output shaft and gear ring and have a shop put them on. By cost effective, I'm referring to the fact that you would then have a mostly useless transmission housing that won't fit on your engine. You could probably rebuild the donor tranny, but you would have to replace all of the seals and even then you'd be stuck with a final drive ratio that you didn't want in the first place.
Old 09-06-2012, 01:31 PM   #41
Jason@SportsCar
xB final drive swap
Just bumping this with the latest part numbers, the output shaft was updated.
Old 09-06-2012, 01:51 PM   #42
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
This thread is a nice one to chew on, but leaves more confusion for me with this car as well as my unique goals especially when the OEM rev limiter is not actually allowing you to reach that tipping point where you "run out of gear".
Old 09-06-2012, 02:24 PM   #43
Jason@SportsCar
Then you need to fix your problem, and get past the OEM rev limiter. How can you make a serious attempt at power gains without ECU control? It is not cheap, but there are solutions, and power to be had.
Old 09-06-2012, 03:54 PM   #44
Flipper_1938
Flipper_1938's Avatar
Drives: 2010 Yaris Sedan
What's the best way to do that?
Old 09-06-2012, 03:57 PM   #45
^ It's in his quote. ECU control.
Old 09-06-2012, 04:04 PM   #46
Flipper_1938
That's what I'm asking....what is the best way to control the ECU? Can the stock ECU be hacked with some sort of tuner? or do you need a stand alone ECU?
Old 09-06-2012, 04:06 PM   #47
fnkngrv
fnkngrv's Avatar
That's part of the plan, but I wouldn't dare to run up the rev limiter on a stock bottom end anyway at the speeds that I am attempting.
Old 09-06-2012, 04:26 PM   #48
Standalone.
Old 09-06-2012, 05:07 PM   #49
Jason@SportsCar
I am 7300 all day long on a stock bottom end (rods/crank/pistons even valve springs).
Old 09-06-2012, 05:09 PM   #50
Jason@SportsCar
AEM EMS series 2, piggy-backed to the stock ECU (stock ECU does start up/idle/DBW, the AEM does the rest including VVT control).
Old 09-06-2012, 07:21 PM   #51
Jeff@MicroImage
"Know it all"
Jeff@MicroImage's Avatar
Drives: Lancia Delta Integrale
+1 That's the setups we've been working on.
www.microimageonline.com
Jeff@MicroImage is offline   Reply With Quote
Old 09-06-2012, 07:34 PM   #52
packetrace
packetrace's Avatar
Drives: Yaris Sedan 2009
would you make a plug n play kit ?
Interior:ALL red, black roof
Old 09-06-2012, 07:39 PM   #53
Jason@SportsCar
They should be able to. I have a PNP in the 2007 car, but at the time we built it the connectors were not available for the 2012, so it is hardwired.
Old 09-06-2012, 09:12 PM   #54
Jeff@MicroImage
"Know it all"
Yes, we have the PnP harness on order with Boomslang, just waiting on the final parts.
Yaris Motor Swap Thread *Read before posting swap threads* Sabretooth Performance Modifications 219 06-10-2025 02:58 PM
TRD final drive hare Performance Modifications 10 01-15-2010 12:19 PM
Final Drive t0m4s Performance Modifications 17 04-11-2009 03:16 PM
Final Drive t0m4s Central and South America 0 04-07-2009 06:06 PM
final drive rx100 Performance Modifications 2 08-21-2007 01:26 AM
