Old 09-04-2010, 05:52 PM   #181
Rongasm
Drives: 2008 Black Yaris LB
2008 Yaris hatch 92,000 miles on the odo and still going strong. I have done all the major maintenance. Oil i've been using was castrol gtx syntec BLEND. I simply cant afford the fully synthetic. especially since i change my oil every other month or so. I've now switched to castrol gtx high mileage oil. I'm worried about my 100,000 mile maintenance though. Do i need to just drain and fill my coolant, or do a flush? I'd like to try doing it myself so yah. I was hoping anyone had some info to DIYs particular on the yaris on how to drain and fill or flush the cooling system.
Anyway, this little car of mine looks like it'll last for a very loooooong time. I hope to keep it till it dies. = )
Rongasm is offline   Reply With Quote
Old 09-04-2010, 06:02 PM   #182
sickpuppy1
Drives: 2010 Yaris Sedan
I just saw Advanced Auto is now selling a house brand fully synthetic for 3.49 a quart! Dont know anything about it yet, but sure is tempting......
I'd do a flush too myself, but thats just me. Factory stuff is good, but I think a mild flush couldnt hurt. And as far as that goes, when you drain it, take a look down in the radiator. I know its not absolute, but if you see scale or other build up there, its in other areas too.
Old 09-14-2010, 11:36 AM   #183
mkaresh
Drives: Mazda Protege5
We have updated results for the Yaris to include owner experiences through June 30, 2010. Other sources of car reliability information won't cover the more recent months until the summer or even fall of next year. Repair frequencies, in terms of repair trips per 100 cars per year:
2010: no repairs reported yet, 14 participants
2009: 7
2008: 7
2007: 15
All are very low, and much better than average.
We have two additional statistics, "Nada-odds" and "Lemon-odds," to indicate the percentage of cars with no repairs in the past year and those that required 3+ trips to the repair shop.
In the case of the Yaris, the percentage with no repairs is about 88 for the 2007 and 92 for the 2008, and the percentage of lemons is less than one for both years.
Thank you, once again, everyone who has been helping. We'll have further updates in November and February. With more participants, we could provide more precise information and provide all three stats for all model years.
To see how competitors compare, and to sign up to help improve this information:
Toyota Yaris reliability comparisons
truedelta.com
Vehicle reliability, fuel economy, price comparisons
mkaresh is offline   Reply With Quote
Old 09-14-2010, 12:30 PM   #184
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
43k on my 07 S and I brought it to the dealer for the door pillar insulation recall. Other than that smooth sailing. I upgraded to 100 Synth Oil at 7k and haven't looked back. I am going to be upgrading the tranny fluid to Redline 90MT this month...oil is on order. I had the HAVC odor issue however that has gone away 100% since I started using cabin air filtration 3 months ago. I did not act on the TSB...no way I was going to let the dealership tear my dash down and screw up my baby.
Old 10-23-2010, 06:31 AM   #185
mkaresh
Updated reliability stats next month.
As always, the more owners participate, the better the information we can provide to everyone.
Car reliability research
truedelta.com
Old 10-23-2010, 11:01 AM   #186
Hershey
Not too reliable . Head gasket oil leaks of the # 1 cylinder for a 2008 sedan and 2010 3 door . 2008 head gasket replaced under warranty with no leak as of yet and 2010 with same oil leak from the head gasket that's due to go under the wrench in the near future . An acquaintance that owns a 2010 3 door has the same oil leak as well . All were bought new . I would think there are other YARIS out there with the same issue . Could be some of you . It's very well hidden and easy to miss .
Old 10-23-2010, 11:15 AM   #187
krolos
Drives: 2008 yaris sedan
Originally Posted by Hershey View Post
Not to reliable . Head gasket oil leaks for a 2008 sedan and 2010 3 door . 2008 head gasket replaced under warranty with no leak as of yet and 2010 with same oil leak from the head gasket that's due to go under the wrench in the near future . An acquaintance that owns a 2010 3 door has the same oil leak as well . All were bought new . I would think that there are other YARIS out there with the same issue . Could be some of you . It's very well hidden and easy to miss .
It seems you and your friend got some freaky bad luck, I have been
checking mine for those leaks and I check really good
and I know where to check, nothing so far, also by now alot of owners
have read your original thread on your oil leak problem and have checked their cars and
there has not been any new complaints regarding this that I am aware of.
The survey and high number of people on here with good reliability result is very
good indicator that in fact the Yaris is a very reliable little car.
I hope you and your friend get everything fixed good.
krolos is offline   Reply With Quote
Old 10-23-2010, 03:25 PM   #188
wooverstone8
wooverstone8's Avatar
At 16k miles I had to get the water pump and water pump belt replaced.
Old 10-23-2010, 03:49 PM   #189
2007yariz
Drives: Yaris sedan
Where is that and how did you know it need to be replaced?
25k here, just oil changes, fuels, and once i added some coolant when i noticed it was a little low.
Great little Car!
2007yariz is offline   Reply With Quote
Old 10-23-2010, 04:28 PM   #190
wooverstone8
Old 10-23-2010, 05:30 PM   #191
eric81
eric81's Avatar
Drives: Toyota Salesman
I bought a 2003 Echo with 316K miles on it, and it still has all it's original parts. I am replacing the cable and cage bushings now, I have a set of lowering springs in the trunk, and I have the synthetic tranny fluid in the trunk as well. One of these days I will have time to do all the upgrades, maybe.
eric81 is offline   Reply With Quote
Old 10-23-2010, 06:21 PM   #192
The Marshall
Drives: 2007 Yaris 5-Door, Black
I am the first owner of a 2007 Yaris Hatchback (5 door) that was a daily rental, I bought it at just under 80,000 km, it is now at 113,000. So far I have had to replace
Cam positioning sensor
Alternator (might need ANOTHER one, but that's not Toyota's fault)
Accessories Belt
I'm under $1000 so far, not really happy with the reliability, but it's not horrendous either.
The Marshall is offline   Reply With Quote
Old 10-23-2010, 07:12 PM   #193
Kal-El
Kal-El's Avatar
At 94,500 miles on my '07.
No problems/repairs. Just a changed serpentine belt at about 85K which isn't reliability/Toyota related.
Old 10-24-2010, 08:58 AM   #194
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
Accessories Belt
You bought a rental car and expected good reliability? Really?
Colin Chapman disciple
Old 10-24-2010, 11:24 AM   #195
p123456789
Drives: 07 lb jeep tj
The parts he's replaced have nothing to do with rental abuse. But I agree with you if you take the risk and buy a rental car at a huge discount expect to have to put some money into it sooner or later.
p123456789 is offline   Reply With Quote
Old 10-30-2010, 05:50 PM   #196
az_saguaro
What to Mod Next?
Drives: 2008 3Dr HB, Bayou Blue
At 68,000 miles mine has been in the shop four times total. Twice for a problem that they "can't duplicate". When the car is hot and I turn it off to to do something quick (like get the mail) and then restart. It starts fine but has no power, however, if I let it sit for about 10 seconds at idle, it is fine. But it only occurs occasionally.
Once at 50k miles because the axle seal was leaking. In the shop now at 68k miles because the third gear synchro broke (also looks as if they found a problem with chipping on the 4th gear teeth, which I assume could have happened when the 3rd gear synchro broke).
az_saguaro is offline   Reply With Quote
Old 10-30-2010, 09:30 PM   #197
Lucas13
Drives: 07 Yaris LB
Did your transmission ran completely out of gear oil when the seal was bad?
My gear box had same problem, the left axle seal started leaking (warranty replaced it) and some time after the main shaft started leaking as well so warranty replaced the transmission.
When I noticed the leaks I was always making sure to top off the gear oil at least every two weeks because I did not wanted to cause further damage to the gear box and maybe get stock somewhere...
Lucas13 is offline   Reply With Quote
Old 11-04-2010, 02:51 PM   #198
yarisnj
Drives: 2008 Yaris Sedan
New alternator at 40,000 miles, due to bad bearings, on my 2008 sedan.
yarisnj is offline   Reply With Quote
Toyota Yaris to Sponsor FOX's "Prison Break" YarisBueller General Yaris / Vitz Discussion 0 04-30-2006 08:01 PM
