#73 |
Thank you largeorangefont, I'm looking forward to it.
#74 |
![]() ![]() ![]() Drives: Polar White Hatch Join Date: Nov 2006
largeorangefont,
when I google the transmission ratios I get hit for 3.722:1 and 3.941:1. Perhaps
ChinoCharles Intake supporter. |
#75 |
Break'em off some.
#76 |
l33t3st Asshole
Drives: MY07 Yaris Liftback Join Date: Nov 2006
#77 |
Break'em off some.
Ok here is a quick and dirty version of how the dyno figures out horsepower. A dynojet is the simplest, because there is no load. The dyno takes the known weight of the roller(s) and derives hp based on how long it takes the car to get the roller up to speed. So if you have the car in 2nd for example, the roller is going to spin up faster, relative to a 4th gear pull. It is just like doing 30 on the street in 2nd gear vs 4th gear.
In real terms you *should* have the same horsepower either pull, but the curve will be very different looking. Think how the car pulls from 30 mph in 2nd vs. 4th gear, and how that will translate to a HP curve. Some dynos will measure more horsepower just from switching a lower final drive and some don't. You arent gaing HP, but you are spinning up the roller(s) quicker. You can see how the dyno could then traslate that difference into more HP. I have personally seen this happen, and it is obviously incorrect. Alot of newer dynos are calibrated not to do this, but just be aware that is can happen. The reason you want to use 3rd or 4th gear on a dyno pull is to put more of a load on the car. For tuning, you want to see what happens with the air fuel ratio and timing high in the load range. Tuning in 1st and 2nd does not give you an accurate picture of how the car will run in higher gears with more load. Depending on the dyno operator and the car, sometimes shops do their tests in 3rd gear because speeds are too high in 4th on some cars. For seeing gains of a particular part, as long as you can eliminate every variable possible, you should get an accurate picture. Dynos, their calibrations, and HP numbers can vary greatly so it is not valid to compare numbers from dyno to dyno. Just think of the dyno as a tool to check gains. I would always try to go to the same dyno facility, and make sure that all calibrations are as close as possible each time you dyno for the best result. Hope all this helps. Ashley |
#78 |
Thank you Ashley, everything makes a bit more sense.
Mustang Dynos apply a small amount of resistance and use that load and not the mass of the roller to determine horsepower. Got it. Russel, how do you like that HUD? It has to take some getting used to... |
#79 |
Break'em off some.
You got it. A mustang dyno is much better for tuning because you can simulate driving conditions with more realistic loads on the car, and do steady state tuning, That is more effective and accurate than using a Dynojet and doing WOT tuning.
#80 |
l33t3st Asshole
#81 | |
![]() ![]() ![]() Drives: 07 5spd red Yaris HB 1.5L 16V Join Date: Oct 2006
#82 |
Here's some for you... Search for my How_To if you need more info.
#83 |
Lurker supreme!
Alright... I started doing a bit of poking around and reading online as to the relationship between "backpressure" and torque, and why free-flowing headers and exhaust systems can decrease the amount of low/mid torque. People assume that since a more restrictive muffler/header/whatever has higher low-end torque, then it must be because of increased backpressure. Right? Wrong! Its b/c with a smaller diameter exhaust system, the exhaust gasses move faster. These faster moving gasses produce a slight vacuum behind them, which actually helps to pull the remaining exhaust out of the cylinder. This process is known as "scavenging". Otherwise, these gasses would be left in the cylinder, displacing new, fresh air/fuel, and thereby producing less power. As the engine speeds up (higher RPM), the scavenging effect is less pronounced, and the exhaust system's ability to flow gasses makes more of a difference, which is why the megan header works very well at very high rpm.
For some better information on this, please check out the following two very good quick-reads: Exhaust: The straight scoop on backpressure and Exhaust system backpressure. Any thoughts/comments?
2006 Red Blitzed RS 5-door |
#84 | |
Resident Redneck
Drives: 07 Polar White Yaris Sedan 5M Join Date: Jul 2006
My other rides: 2003 Honda Civic LX Coupe 5M- S/C K24 w/ LSD coming soon! 1999 Honda Civic EX Coupe 5M w/ B18 powaa 1985 Toyota Celica GTS Coupe 5M- track whip http://www.importlounge.com |
| Megan Header Install [pics] | Chris07LB | Performance Modifications | 132 | 09-29-2010 04:41 PM |
| WR Secret Weapon Intake Dyno Tested.. | WRLEO | Performance Modifications | 70 | 05-17-2007 04:00 PM |
| GROUP BUY - Megan Racing 4-1 Header... | riceboy | Items for Sale by private party | 489 | 01-10-2007 07:45 PM |
| VA/MD Owners - Megan Racing Header | ProMotionTuning | Performance Modifications | 4 | 11-30-2006 03:54 PM |
| HEADER & INTAKE R&D. | WRLEO | Performance Modifications | 80 | 11-23-2006 04:51 PM |
