#19 |
![]() Drives: Toyota Yaris 2007 Join Date: Oct 2010
How can I access the engine drain block plug? Under the vehicle or just under the hood? What does it look like? Thanks!
#20 |
From underneath, backside of block, in the middle, above oil pan gasket surface ...it's the only thing that looks anything like a drain port.
#21 |
Thanks a lot! That work out great, however I dont think it was worth the time and effort to drain coolant of the engine drain block, it only spitted out 1/4 cup. That drain block was a tight space. I got a half bucket of coolant of the radiator drain cock, which I will just only do next time.
#22 | |
#23 |
^ no, that sounds about right. You're only draining the remnant from the back of the block because of the rearward tilt of the motor.
#24 |
Really? Wow. If so, sounds like the most worthless drain plug location ever designed.
#25 |
Well, otherwise how are you going to get that last little bit out?
#26 |
1/4 of a cup?
#27 |
![]() ![]() Drives: 01 Toyota Echo Join Date: Oct 2010
just got the repair manual, I'm going to look up the process for draining. hopefully there are bleeders.
| Water Pump issue, after taking in for Recall | GeneralDon7 | General Yaris / Vitz Discussion | 34 | 05-27-2012 08:04 PM |
| Yaris Fuel Pump | HTM Yaris | General Yaris / Vitz Discussion | 12 | 03-22-2012 03:34 AM |
| Water Pump leaks and then stops | CB900F2 | DIY / Maintenance / Service | 30 | 05-09-2011 09:14 AM |
| Hmm my water pump failed again!!!! Could it be the pulley?!?! | YarisSedan | Performance Modifications | 64 | 10-05-2009 09:32 PM |
