#181 |
![]() ![]() ![]() ![]() Drives: 2008 Yaris LB Join Date: Jul 2010
#182 |
I'm just not a fan of any dual-drilled road wheels.
#183 |
So the holes bother, not the design of the wheel.
#184 |
Yaris Lunatic!
Drives: Yaris 1.33L (1NR-FE) 3dr 6MT Join Date: Jun 2009
Hello guys, I need a little help here, because I did not come with an answer while searching.
Reference wheel fitment is this one (offered by TTE, so it is a perfect fit for the Yaris): Picture Specs for the above pictured wheel are: 16x7" and ET45. So, having in mind that tire size will definitely be 195/50/R16, which is the lowest offset that the wheel should have? For example, the Work CR-Kai is 16x7" with ET44, which would fit perfectly, but the O.Z. Ultraleggera has ET37. Would ET37 be OK with the specified tire size? The car is currently not lowered, but it might be lowered (no more than 1.2") in the future. Thanks in advance! |
#185 | |
O.Z. Ultraleggera - 195/50/R16 - ET37
. CLA 250, 4MATIC |
#186 | |
Yaris Lunatic!
![]() With ET37 wheels and 10mm spacers you actually got an effective ET27 (if I am not mistaken) and you had no problem with that? Sounds weird! |
#187 | |
I did have rubbing issues with 10mm spacers. without them no more rubbing. I'm sorry I should have been more specific! ![]() NO spacers = NO rubbing D.
. CLA 250, 4MATIC |
#188 | |
Yaris Lunatic!
I also hope that the hatchback (which is what I have) has the same space under the fenders as the sedan! Thanks for helping!
#189 |
16x7, ET37, 195/50/16 will be a good fit. ET37 is the lowest offset I would trecommend with 195's.
#190 |
Yaris Lunatic!
Thanks kimona! This will help me end up somewhere...
#191 | |
2 cts.
. CLA 250, 4MATIC |
#192 |
Drives: Vitz 2008 Join Date: Sep 2010
Hello Guys,
i need to change stock tires size 165/70/14 BS of my Japanese vitz with 185/60/15 I already got japan vitz OEM 15 rims... Can anyone tell me..which is ideal replacement size for 15" based on my stock tires 165/70/14.. will it cause any problems with suspension shocks, speedo ratings etc? thanks! |
#193 |
![]() ![]() Drives: new vitz Join Date: Apr 2010
Hi everybody, i wanted to have the opinion of each oF u. I wanted to know which best tire can fit my car properly. i've just install New Rims 14'' and am having a 175/70R14.
i want the to have a bit thin, not that much but a bit..........will 185/60 go.? Last edited by tk-421; 11-13-2010 at 06:42 PM. |
#194 |
Not sure what you mean by a "bit thin" but these sizes generally work very well:
Tyre Size = Diameter (inches) 175/65/14 = 23.0 185/65/14 = 23.5 195/65/14 = 24.0 195/60/14 = 23.2 205/60/14 = 23.7 215/60/14 = 24.2 Last edited by kimona; 11-14-2010 at 10:57 AM. |
#195 |
But what are these numbers
23.0 23.5 24.0.....etc??? |
#196 |
Drives: 2007 yaris sedan Join Date: Nov 2010
Hi guys ... lots of info here. I need to know if the following snow tires will fit my 2007 sedan a la yarismo.
195/65/15 Its not on the list in above posts ...but thought I should double check. Thanks ! n |
#197 |
#198 |
| Tamago's guide to ultimate yaris handling | Tamago | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 99 | Yesterday 01:51 PM |
| News : 2007 Toyota Yaris - the little Euro's official arrival | VitzBoy | General Yaris / Vitz Discussion | 9 | 06-06-2017 01:51 AM |
| 2007 Yaris Pricing Info ! | YarisBueller | New YARIS Purchase Forum | 104 | 06-24-2009 05:54 PM |
