Old 11-15-2010, 12:04 AM   #19
Originally Posted by Murtaza_murti View Post
Okay, but how should it be drilled out?
I personally wouldn't attempt it. Theoretically airbags are designed to withstand heat and vibration, but I think I would try to locate an airbag that fits the steering wheel first.
Old 11-15-2010, 09:30 PM   #20
Murtaza_murti
Drives: Toyota Belta
The Steering wheel I am getting already has a airbag, I need to change the cover's, here are a couple of picture's to show you what I am talking about:
[ATTACH]Steering wheel II.jpg[/ATTACH]
Murtaza_murti is offline   Reply With Quote
Old 11-15-2010, 09:30 PM   #21
Murtaza_murti
Note the difference between the pattern's of the cover's.
Old 11-15-2010, 09:39 PM   #22
So, are you thinking of trying to use the audio controls with your original cover (by trimming it to fit)?
Old 11-15-2010, 09:51 PM   #23
Murtaza_murti
Yes, beacause I can't seem to find the Steering wheel which has the Belta's trim's pattern on it.
Old 11-15-2010, 10:06 PM   #24
That might just work, and you should be able to trim it without having to drill out the rivets, since the radio controls are separate pieces that mount to the steering wheel frame, rather than the airbag. This is what the underside looks like sans airbag.
Old 11-15-2010, 10:29 PM   #25
Murtaza_murti
I am confused. What do you suggest?
Old 11-15-2010, 10:58 PM   #26
I am saying that you may be able to cut the cover so that it fits with the controls, without taking the cover off of the airbag.
Old 11-15-2010, 11:10 PM   #27
Murtaza_murti
I get it now, will update you soon. Thanks alot for the help
Old 06-01-2012, 12:31 AM   #28
yours_falsely
yours_falsely's Avatar
Drives: 2008 Yaris sedan
It's been a year and a half but i'm assuming that nobody's made any headway here?
yours_falsely is offline   Reply With Quote
Old 06-01-2012, 07:05 AM   #29
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Maybe the airbag went off mid-cut?
Old 10-27-2014, 10:55 AM   #30
Murtaza_murti
Stay tuned
Old 01-05-2015, 02:06 PM   #31
Murtaza_murti
Edited. Refer to the post below.
Old 01-05-2015, 02:13 PM   #32
Kar98
Drives: 2011 Scion tC
Very carefully?
Old 01-05-2015, 03:45 PM   #33
Murtaza_murti
That's strange, the pictures aren't showing up.
Old 01-05-2015, 04:26 PM   #34
Kar98
Needs picture file extension in the address, i.e. it needs to end in .jpeg, not .html.
Old 01-06-2015, 04:03 PM   #35
Murtaza_murti
Finally! After waiting forever, I finally got a hold of the required parts and got this done at last.
Required parts:
1. OEM airbag cover (for multi-function controls, also airbag cover for the Yaris hatchback and sedan is different. As both have a different texture on the cover).
2. OEM multi-function button/switch assy (now there are two types, left side controls have track up and down, volume up and down and MODE with the other side empty and the other one has all these features on the left with the Bluetooth/phone connectivity on the right with call end/receive and voice command). I got the one without the Bluetooth functions as my head-unit doesn't have a Bluetooth option.
For pictures of the button/switch assy, refer to post #30 on this page.
3. OEM clockspring which supports multi-function controls connection (I didn't need another clockspring, my audio guy made a harness and installed it with the original clockspring).
Also, there is this neat feature I didn't know existed. If you hold the MODE button for 2-3 seconds the head-unit turns OFF and when you hold it again it turns ON, I found this feature to be highly useful. It keeps you from diverting your attention whilst driving.
Here are some pictures of the parts and finished product, just have these crappy cell phone pictures for now. Will post detailed pictures later.
Required OEM airbag cover
Original airbag cover and airbag assembly removed
Old airbag cover (notice the difference between this one and the new one, you cannot fit the switches in the old one as there is no open space to do so)
The airbag had to be removed from this old airbag cover into the new one. The airbag assembly is bolted on by steel rivets which have to be opened and then closed by a special tool which I didn't have. The guy whom I bought the parts told me he would do it, so I couriered it over to him.
Final product pictures, will post detailed images and a few video clips over the weekend.
Old 01-06-2015, 04:04 PM   #36
Murtaza_murti
Uploaded them via attachment(s). I didn't see it at first, dumb me
US '09 5-Door LB: How do you remove the steering wheel? IsLNdbOi DIY / Maintenance / Service 5 06-30-2010 12:50 AM
