Old 09-05-2010, 07:31 PM   #181
sleey0
Drives: 2008 Yaris LB
Yeah, but the dual-drilled Enkei EV5's are rather unsightly IMHO.
I thought they look pretty nice. Guess to each his own.
sleey0 is offline   Reply With Quote
Old 09-05-2010, 08:34 PM   #182
kimona
kimona's Avatar
Drives: 2014 White VITZ
I'm just not a fan of any dual-drilled road wheels.
Old 09-06-2010, 11:18 AM   #183
sleey0
So the holes bother, not the design of the wheel.
Old 09-22-2010, 02:06 PM   #184
nickstamat
Yaris Lunatic!
Drives: Yaris 1.33L (1NR-FE) 3dr 6MT
Hello guys, I need a little help here, because I did not come with an answer while searching.
Reference wheel fitment is this one (offered by TTE, so it is a perfect fit for the Yaris): Picture
Specs for the above pictured wheel are: 16x7" and ET45.
So, having in mind that tire size will definitely be 195/50/R16, which is the lowest offset that the wheel should have?
For example, the Work CR-Kai is 16x7" with ET44, which would fit perfectly, but the O.Z. Ultraleggera has ET37. Would ET37 be OK with the specified tire size?
The car is currently not lowered, but it might be lowered (no more than 1.2") in the future.
Thanks in advance!
nickstamat is offline   Reply With Quote
Old 09-22-2010, 03:46 PM   #185
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
Thanks in advance!
No problems after I took the 10 mm spacers !
O.Z. Ultraleggera - 195/50/R16 - ET37
CLA 250, 4MATIC
Old 09-22-2010, 04:28 PM   #186
nickstamat
Yaris Lunatic!
derickveliz2, you have a very nice sedan
With ET37 wheels and 10mm spacers you actually got an effective ET27 (if I am not mistaken) and you had no problem with that? Sounds weird!
Old 09-22-2010, 04:46 PM   #187
derickveliz2
I did have rubbing issues with 10mm spacers. without them no more rubbing.
I'm sorry I should have been more specific!
NO spacers = NO rubbing
D.
CLA 250, 4MATIC
Old 09-22-2010, 05:02 PM   #188
nickstamat
Yaris Lunatic!
D.
Ok, now I get it!
I also hope that the hatchback (which is what I have) has the same space under the fenders as the sedan!
Thanks for helping!
Old 09-22-2010, 06:13 PM   #189
kimona
kimona's Avatar
16x7, ET37, 195/50/16 will be a good fit. ET37 is the lowest offset I would trecommend with 195's.
Old 09-23-2010, 09:29 AM   #190
nickstamat
Yaris Lunatic!
Thanks kimona! This will help me end up somewhere...
Old 09-23-2010, 12:36 PM   #191
derickveliz2
kimona is right on the dime! also if you consider lowering your car, the front wheels get very close to the fenders. If you are planing to lower your car by a lot, be aware of the limits with ET37
2 cts.
CLA 250, 4MATIC
Old 10-04-2010, 02:53 PM   #192
madz
Drives: Vitz 2008
Hello Guys,
i need to change stock tires size 165/70/14 BS of my Japanese vitz with 185/60/15
I already got japan vitz OEM 15 rims...
Can anyone tell me..which is ideal replacement size for 15" based on my stock tires 165/70/14..
will it cause any problems with suspension shocks, speedo ratings etc?
thanks!
madz is offline   Reply With Quote
Old 11-13-2010, 11:33 AM   #193
husaynkhan
Drives: new vitz
Hi everybody, i wanted to have the opinion of each oF u. I wanted to know which best tire can fit my car properly. i've just install New Rims 14'' and am having a 175/70R14.
i want the to have a bit thin, not that much but a bit..........will 185/60 go.?
husaynkhan is offline   Reply With Quote
Old 11-13-2010, 01:53 PM   #194
kimona
kimona's Avatar
Not sure what you mean by a "bit thin" but these sizes generally work very well:
Tyre Size = Diameter (inches)
175/65/14 = 23.0
185/65/14 = 23.5
195/65/14 = 24.0
195/60/14 = 23.2
205/60/14 = 23.7
215/60/14 = 24.2
Old 11-14-2010, 05:43 AM   #195
husaynkhan
Drives: new vitz
But what are these numbers
23.0
23.5
24.0.....etc???
Old 11-17-2010, 06:05 PM   #196
nimdeos
Drives: 2007 yaris sedan
Hi guys ... lots of info here. I need to know if the following snow tires will fit my 2007 sedan a la yarismo.
195/65/15
Its not on the list in above posts ...but thought I should double check.
Thanks !
n
nimdeos is offline   Reply With Quote
Old 11-17-2010, 07:21 PM   #197
kimona
kimona's Avatar
195/65/15
Thanks !
n
They're pretty darn tall... but they will fit.
Old 11-17-2010, 08:38 PM   #198
Klink10
Klink10's Avatar
23.0
23.5
24.0.....etc???
Those are the diameter figures for the wheel and tire package they are next to.
ie: 185/65/14 = 23.5 would mean a 185/65 tire mounted on a 14" rim would be pretty darn close to 23.5 inches in total diameter.
Tamago's guide to ultimate yaris handling Tamago Wheels, Tires and Suspension Forum sponsored by The Tire Rack 98 02-18-2024 06:45 AM
