Old 11-18-2010, 06:34 AM   #199
Midnight Drifter
Going Retro
Drives: '09 Tacoma | '90 Tercel
Size.............Offset Range.....Backspace Range.......Weight
14" x 6"........6 to 32mm........93.2 to 119.2mm .......13.6lbs
Based on that data, what would be the most preferred configuration for my wheels?
Midnight Drifter is offline   Reply With Quote
Old 11-20-2010, 10:06 AM   #200
kimona
kimona's Avatar
Drives: 2014 White VITZ
Depends on the size tyre you want to run, if you are dropped, and whether you want to make camber adjustments.
If you simply want to bolt some wheels on your car, then 14x6, ET32 would work with 175-185mm tyres.
Old 11-23-2010, 07:28 AM   #201
Midnight Drifter
Going Retro
Kinda trying to go wide here... if 205 can fit then 205 would be my preference. If not wider (somehow) Not looking to change camber, while grip is important daily drivability-even tire wear is twice so. Can I push 215? The more rubber, the better.
I think the wheels I'm looking at are lighter than stock steelies, but couldn't tell you for sure lol.
Old 11-23-2010, 12:30 PM   #202
kimona
kimona's Avatar
14x6, ET40-45, 205/60/14
Old 11-23-2010, 03:18 PM   #203
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
i know some people are pushing 225mm tires on a 6" rim... but the side wall looks like its at a 45 degree angle off the rim.. also thats stock suspension.. my race rims are 15x7 with a 40ET. i run 225/50/15 khumo v700.. if i turn the steering wheel all the way left or right, the tires rub on the chassis
Old 11-23-2010, 07:06 PM   #204
Midnight Drifter
Going Retro
Stupid question here, what's ET? ._.
Old 11-23-2010, 08:34 PM   #205
kimona
kimona's Avatar
Offset.
Old 11-27-2010, 01:35 AM   #206
marlondog
Shut your fricken suck!!!
marlondog's Avatar
Drives: 07' liftback
What about a 15x7 +27 offset with a 195/55/15 tire.I'm already lowered about 1.7". Is it possible? How much negative camber and fender pulling and rolling are we talking about?
marlondog is offline   Reply With Quote
Old 12-20-2010, 08:58 PM   #207
YarisPR
YarisPR's Avatar
Drives: Yaris Sedan
This is what I'm aiming for
I Drive a 129whp Yaris ;)
YarisPR is offline   Reply With Quote
Old 02-13-2011, 02:13 PM   #208
henry33
Drives: yaris1.33
is it ok to put 6.5J R15 ET (offset 35) on the yaris hatchback ? I do not know if the offset is good since originally there was Et40
thank you
henry33 is offline   Reply With Quote
Old 02-13-2011, 04:11 PM   #209
kimona
kimona's Avatar
^^ Which size tyres will you run?
Old 02-13-2011, 06:21 PM   #210
henry33
Drives: yaris1.33
I will be using 185/60 r15 and originally there was ET45
Old 02-13-2011, 07:33 PM   #211
kimona
kimona's Avatar
^^You'll be fine with that set-up.
Old 02-14-2011, 04:09 AM   #212
henry33
Drives: yaris1.33
ok so I will buy those wheels most probably ;)
thank you
Old 02-14-2011, 08:28 AM   #213
PumpkinSteve
PumpkinSteve's Avatar
Drives: Yaris SR 1.8
I have 16 x 6.5 ET45 and I'm wondering if I can fit 205/50/R16 if my car is lowered by 30-35mm? I have the 1.8 Yaris which already has the steering lock reduced as standard to stop the 17" wheels rubbing, so it might be okay with this model?
PumpkinSteve is offline   Reply With Quote
Old 02-28-2011, 06:45 PM   #214
Yari5Love
Drives: 08 Polar White LB
Quick question thinking about buying some wheels but wasn't sure if they would fit my 08'Liftback the wheels are 4x100 bolt pattern&13x7 with a 15 offset anyone know if they'll fit without making any adjustments to the car? my car isnt lowered or anything just stock. please no flaming just a question I need answered. thanks
Yari5Love is offline   Reply With Quote
Old 02-28-2011, 06:58 PM   #215
kimona
kimona's Avatar
Quick answer: No, they won't fit.
Old 03-01-2011, 12:17 AM   #216
piranha0522
Drives: '06 Yaris
hmm..would this fit ok?
So I found a nice set of rims in my area.
They are 16" 4 bolt with tires 205, 45, 16. These would fit fine right?
I have an '06 5dr liftback.
What does everyone mean when they say offset? I still haven't figured that out.
Thanks!
piranha0522 is offline   Reply With Quote
Tamago's guide to ultimate yaris handling Tamago Wheels, Tires and Suspension Forum sponsored by The Tire Rack 98 02-18-2024 06:45 AM
