Yea..thats mine
Drives: 2009 Yaris Sedan 5 speed Join Date: Sep 2010
LEDs???
I am trying to wire up some LEDs in the front floor board under the dash. I jave no problem running the positive wire to a fuse, but I am not sure where to run the ground. Any suggestions on where to connect the wires...and make it look nice. I want the lights to come on when the key is on..for now...
"I'm sorry, were you driving there?" |
![]() ![]() ![]() ![]() Drives: 2008 yaris, stripped, red Join Date: Jan 2009
any bolt or screw or nut that's into sheetmetal on the frame of the car. as in, the big metal tube thats under the dash or any metal piece bolted/welded to it. you can run a wire to the seat frame. you can tap into any ground already there (radio or switches or whatever) bolts holding the steering column...
easiest and not recommended but what happens in car installer shops....put a screw through the floor pan. i dont not suggest this as you now have unprotected metal and it will rust. just find a bolt or nut to unscrew and stick an end thingy on the wire, put it on the nut/bolt and tighten. |
Yea..thats mine
Okay thats what I was thinking...So to set the lights to come on with the ingnition, I need to just tap into the accessory fuse right?
Yea..thats mine
Got them going...will post pics tomorrow hopefully!!!
| LEDs to replace interior lights: Which ones? | IsLNdbOi | Cosmetic Modifications (Exterior/Interior) | 57 | 04-28-2010 02:44 PM |
| What can I do with a bunch of these LEDs? | eTiMaGo | In Car Entertainment + Electronics (audio / video / alarm) | 14 | 05-13-2009 05:28 PM |
| Changing LED's In Projector Head Lights | whooppee777 | Cosmetic Modifications (Exterior/Interior) | 16 | 03-01-2009 03:07 PM |
| Gauge Cluster LED's | Kaotic Lazagna | Cosmetic Modifications (Exterior/Interior) | 11 | 01-08-2009 01:59 AM |
| GROUP BUY - JDM (RS) Vitz LED Tail Lamp ... | riceboy | Items for Sale by private party | 453 | 07-14-2007 09:30 AM |
