Old 01-31-2007, 10:41 PM   #19
Originally Posted by spkrman View Post
well I'd "like" to see the 1nz built up... it has potential, and will maintain the handling of the car without major mods... 200+ to the wheels with a turbo, more with engine management/pistons, + very cheap to replace.
But yea, 300+ to the wheels reliably would be fun.
180-200WHP should be possible with a bolt on turbo and ECU tweaking, but that would really be pushing the limits of the stock internals...
Even with new rods and pistons, lowered compression ratio and more boost, I would see it hard to get more than 250WHP without the engine becoming an uncontrollably peaky little thing. There unfortunately is no replacement for displacement.
But we'll see, there's just so many unknowns at the moment. I'm sure this engine has been modded to the extreme and then some in Japan, but how can we access that sort of information?
Oh and back on topic of the transmission swap... Looking through those technical manuals, it appears the Yaris' computer management system is somewhat modular, so it should IN THEORY be possible to remove the AT control unit without affecting the rest of the systems, but I doubt it's such a plug-and-play system in reality.
You should look through page CH-17 of the chassis.pdf and BE-9 of the Body Electrical.pdf files (available in the DIY section), and see if you can make more sense of this The ECM module is the one that controls the AT transmission, but it looks like it also controls the combination meter, spark plugs, and so on...
Old 01-31-2007, 10:49 PM   #20
spkrman
Drives: 1
tis a good Q... I'd like to know myself what has been/can be done with the 1nz.
175+ whp can be done reliably on stock internals... right now all we can really look at is what the XB/XA guys have been doing.
Old 02-01-2007, 12:27 AM   #21
Walter
Walter's Avatar
Drives: Polar White LB
Etimago= Looks like its all controlled simultaneously. I dont know if the ECU could possibly be re-mapped (isolating the auto controls) by someone who knows what theyre doing. Not too sure if the programming would stick though
I want to see it too, and if a turbo kit was around 2500 it would seem more realistic for the amount of horsepower... however, dropping 4500 for 175 or 200 hp?? I dont know, it just might be cheaper to do a full swap with new ECU, tranny, and built motor...
Walter is offline   Reply With Quote
Old 02-01-2007, 04:19 AM   #22
ChinoCharles
Drives: LB
Good luck getting 200 WHP to the ground in a Yaris. Wow!
Old 02-01-2007, 05:35 AM   #23
spkrman
Drives: 1
if a turbo "kit" is 2500+, im sure it could be sourced for much less
lok at the XB stuff, yaris should be very similar.
I think with labor + parts... the turbo will be cheaper for the same hp... the swap will have more potential, but will be very expensive if you dont do the labor.
Old 02-03-2007, 02:41 PM   #24
03Z33
03Z33's Avatar
Drives: TCR10
Late model Trueno/Levin 6-spd is a direct bolt-in. Ray at Kaaz has done this swap already (local in Garden Grove) and you can pick up the trans (with factory LSD!) for well under $400 since everyone that brings in the AE101 or AE111 silver/blacktop engines doesn't use the trans when they fit them in the AE86, etc..
I wouldn't hesitate to try this if I wasn't planning a complete engine swap in the near future. If you're doing the work yourself, I would plan no more than $1300 budget for the complete swap with all the misc. parts.
Old 02-03-2007, 02:42 PM   #25
ChinoCharles
Drives: LB
INTERESTING.
Old 02-03-2007, 04:25 PM   #26
Walter
Walter's Avatar
Im definately doing this swap... right after I buy your coil-overs!
Old 02-03-2007, 04:31 PM   #27
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
Wow. That sounds very promising If it indeed works.
Old 02-03-2007, 05:46 PM   #28
Nutzoids
Nutzoids's Avatar
Drives: 07 Yaris Liftback
WHERE DO I SIGN?
(There really should be a smily guy who is blowing a load)
Nutzoids is offline   Reply With Quote
Old 02-04-2007, 05:55 AM   #29
spkrman
Drives: 1
INTERESTING.
x2
Old 02-04-2007, 06:09 AM   #30
spkrman
Drives: 1
please keep up posted
Old 02-05-2007, 06:10 PM   #31
Walter
Walter's Avatar
Will do. Im currently in contact with a couple of shops now, and Im going to start collecting parts (hopefully) very soon! Its my next mod right after coil-overs and wheels (probably around next week sometime)...
Ill probably start a new thread as I learn more and start acquiring all of these parts.
Old 02-05-2007, 07:52 PM   #32
spkrman
Drives: 1
make it a DIY
I might follow in your footsteps :)
one thing I like about this... you get to put the clutch pedal wherever you like it... I have sz 14 feet, and they are wide + big legs, so its very uncomfortable with most clutches, now if I could bump it over even an inch or 2
+ a 6spd with LSD...
if you can do this without a big headache, I can see it becoming a very, very common swap.
Old 02-06-2007, 08:52 AM   #33
spkrman
Drives: 1
just to add a little something extra...
going to the 6 spd may also improve mileage? Depends on the gearing Iknow, but shouldnt it provide highway cruising at a lower rpm?
if I could get from 33-35 to 43-45, this swap would pay for itself :)
Old 02-06-2007, 01:50 PM   #34
Walter
Walter's Avatar
A guy did this swap in an Echo, here is quoted text from his research:
"This thread is a spec sheet for the conversion I'll be doing this end of the month ... C150N which is our tranny to C160N which is the 6spd off a '96 to '97 AE111 Black Top 20valved Levin Corolla...
heres your specs:
GEAR C150N C160N
1st---------------------3.545---------------------3.166
2nd---------------------1.904---------------------2.050
3rd---------------------1.310---------------------1.481
4th---------------------0.969---------------------1.166
5th---------------------0.815---------------------0.916
6th-------------------------------------------------0.725
reverse----------------3.250--------------------3.250
Final Drive------------3.526---------------------4.529"
He also said that he cruises at 3850 rpm in 6th gear at 80 mph.
Old 02-07-2007, 03:10 AM   #35
03Z33
03Z33's Avatar
Drives: TCR10
That's actually pretty short gearing, I don't think you'll see a drop in revs at hwy cruising. Don't forget that the AE111 Blacktop makes 165HP at 8000RPM stock. It has more rev's to play with, but this should still be a good match for stock 1NZFE since even though we don't rev as high, we can benefit from the tighter ratios.
Old 02-07-2007, 05:22 AM   #36
Walter
Walter's Avatar
Still tight ratios, but not so tight that any future turbo applications would suffer... plenty of spool time. Handles the power. Seems like a awesome compilation of all things good with this tranny.
I only found one place to buy so far, at $700! I was reading a little on what the Echo guy did and he did need a little bit of fab work...
Oh well, Ill see how much I have left over after I get all the goodies I want to buy with my refund. Youre Cuscos are definately first on my list, so hopefully (for me, not you I know youve been trying to sell them for a while) you still have them when I get my refund.
I know I will probably collect these parts for the 6 speed conversion over time as they become available so Im not worried about it. Already talked to Ray at Kaaz so Im going to hit him up as soon as I gather all I need.
Manual Yaris performance info? SimmZ General Yaris / Vitz Discussion 22 10-27-2009 10:27 AM
New car shopping - long post littlecarlove General Yaris / Vitz Discussion 19 11-01-2006 11:58 PM
Manual vs. Auto littlecarlove General Yaris / Vitz Discussion 25 10-25-2006 09:45 PM
Handbrake question (Manual vs. Auto) Chaad32 General Yaris / Vitz Discussion 31 07-30-2006 08:03 AM
