Old 11-28-2010, 03:38 PM   #55
Focus_Sh1ft
Focus_Sh1ft's Avatar
Drives: 08 Yaris Turbo; 06 tC Turbo
Slow drive by..
http://www.youtube.com/watch?v=ZG5K3LgsJGw
Re gapped to .030
FocusShift: Good to hear about the boost situation. All I hear is the flutter from the turbo. Can't really hear the BOV. You should post a video of yours......
Hm, on closer inspection that BOV sound you have is nothing like mine. That's why I didn't really pick up on it at first. I'll try to get a video this week... Tbh I don't know how to capture the sound on an automatic though
Focus_Sh1ft is offline   Reply With Quote
Old 12-05-2010, 01:38 PM   #56
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
Just installed the AEM Tru Boost controller. Putting down about 7.88 lbs of boost. Loving the power. Can't wait to get it retuned. Just waiting for my HKS SSQV 3 BOV to get here.
http://www.youtube.com/watch?v=wHxZFGqow0c
Old 12-05-2010, 03:02 PM   #57
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
sounds good, but why spend money on the SSQV?
Originally Posted by xnamerxx
you nailed it sir.
Old 12-05-2010, 03:23 PM   #58
PETERPOOP
PETERPOOP's Avatar
I found a pretty good deal on the HKS bov and I wanted to try it out. I don't know the quality of the ZAGE bov, and supposedly the HKS bov helps out with performance.
However, unlike most people, I'm not really a fan of the high pitched noise the HKS bov makes.
Old 12-05-2010, 03:42 PM   #59
Tamago
Tamago's Avatar
Drives: ZZW30
there's no way a BOV can improve performance unless the BOV you're currently using is malfunctioning. but a good deal is a good deal, go for it! what will you have to do to modify to make it work?
you nailed it sir.
Old 12-05-2010, 04:09 PM   #60
Focus_Sh1ft
^ We both believe the Zage BOV isn't working correctly and is still allowing compressor surge to happen.
Hey Peter, where did you mount your meth tank?
Old 12-05-2010, 05:08 PM   #61
Tamago
Tamago's Avatar
Drives: ZZW30
so you don't think the bypass valve is opening fully on throttle-lift?
isn't the whole idea of a recirculating valve to help prevent compressor surge?
you nailed it sir.
Old 12-05-2010, 05:21 PM   #62
rob323
Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car
Unplug the line from the bov and hook it up to a boost gauge to make sure you are getting vacuum when you lift off.
rob323 is offline   Reply With Quote
Old 12-05-2010, 05:29 PM   #63
Tamago
Tamago's Avatar
Drives: ZZW30
you should have vacuum at idle, no need to hook up a boost gauge, just unhook it and stick your finger over it while the engine is idling. you should feel if you have vacuum. is the vacuum line hooked up to the correct side of the throttle body?
you nailed it sir.
Old 12-05-2010, 05:31 PM   #64
rob323
If the vacuum line is hooked up to the wrong side of the throttle body, you will still have vacuum at idle though.
Old 12-05-2010, 06:36 PM   #65
Tamago
Tamago's Avatar
Drives: ZZW30
true, but not as much ;)
you nailed it sir.
Old 12-05-2010, 08:07 PM   #66
PETERPOOP
PETERPOOP's Avatar
Tamago and rob323: Ok. Here is a picture of the Zage BOV. I was told it was a re-circulating BOV, but i'm pretty sure it's atmospheric.
I'm kinda confused about what you guys are saying about the vacuum line coming off the throttle body. I don't see any vacuum lines on the throttle body; i went to the intake manifold. This is how I have it hooked up...
So that's how I have it hooked up. Am I doing something wrong?
Focus_Shift: Mounted the AEM meth tank inside the car. It's towards the back infront of where the spare tire goes. The backseat isn't there, so it's mounted on a board that was put there to prevent things from sliding forward, where the back seat used to be.
Old 12-06-2010, 05:44 AM   #67
chexmix
Drives: scion xb
damn nice man.. cant wait to see your car in full action
chexmix is offline   Reply With Quote
Old 12-06-2010, 10:11 PM   #68
pimp my yaris
C'est la vie
pimp my yaris's Avatar
Drives: 2009 2 door hatchback
Looks like its hooked up right to me. My BOV vented very easily and I adjusted the spring tension to make it tighter. I have some compressor surge with normal driving. U may notice a problem with dying out if it vents easily. If you recirculate BOV gasses you wont have any problems though.
pimp my yaris is offline   Reply With Quote
Old 12-08-2010, 01:13 AM   #69
PETERPOOP
PETERPOOP's Avatar
hks ssqv 3 blow off valve installed. hoping to tune it in the near future.
http://www.youtube.com/watch?v=zIQUd6l7r5U
Old 12-08-2010, 03:39 AM   #70
TEHxFALLEN V1.2
TEHxFALLEN V1.2's Avatar
Drives: '08 Lexus IS-F
Sick shit bro, where you get? and did you pay retail?
Sponsored by: Micro Image
http://microimageonline.com
Old 12-08-2010, 03:41 AM   #71
PETERPOOP
PETERPOOP's Avatar
Thanks. $150 bucks from a ebay powerseller. Needed to buy the adapter flange too.
Old 12-08-2010, 10:46 AM   #72
cdydjded
Drives: Yaris LB Turbo
Just to let you know, if you paid $150 for it & it was new, its a fake. Its a counterfeit piece. Iv been a distributor of HKS, $150 is below wholesale. Im not flaming you or trying to insult you, Im just informing you of the fact. I have one of those on my car, so far, so good, so dont worry about it failing or anything. Here is info about it directly from HKS:
http://www.hksusa.com/info/?id=3646
cdydjded is offline   Reply With Quote
Zage Turbo Kit Install - Toyota Yaris Focus_Sh1ft Forced Induction Forum 160 02-06-2022 09:14 PM
Scion XB 1NZ-FE Turbo build xbgod Forced Induction Forum 417 07-24-2011 10:16 PM
XBG's Total Build and Update Thread xbgod Performance Modifications 10 11-19-2010 12:19 AM
Whats needed to turbo charge the yaris? Arkhangel Forced Induction Forum 44 03-02-2009 11:08 PM
