Old 12-05-2010, 03:10 AM   #1
JerseyJeff84
Drives: 2010 Yaris Sedan
Anyone know how much installed a remote controlled starter would be?
I'm in no rush to do it, but I'm just curious how much a remote starter installation would cost? With Winter only being a few weeks away here in New Jersey, it's something to consider. My girlfriend's Dad has a remote starter on his pickup truck and loves it.
JerseyJeff84 is offline   Reply With Quote
Old 12-05-2010, 07:23 AM   #2
nemelek
DWEED
nemelek's Avatar
Don't know the answer to that question. Where I live there is a "puffer" law. You can't let a car idle unattended.
Old 12-05-2010, 08:38 AM   #3
The Yaris is the easiest car I have ever installed one on, and I've self installed them on everything that I've owned over the past 15 or so years. For about $100 you can get a good remote starter and the transponder key bypass module (necessary for all 2009+ Yaris, and any from prior years that have the engine immobilizer). I don't know what places charge to install them, but the labor to install it should be less than many other cars, as all connections that need to be made are done at the key switch or just below it, and it is incredibly easy to gain access to those areas on the Yaris.
Here's a guide that I put together on wiring one:
http://www.yarisworld.com/forums/sho...mote+start+diy
Old 12-09-2010, 05:39 PM   #4
3dr5speedblk
StickShift
3dr5speedblk's Avatar
Drives: 2010 Yaris HB
I checked at BEST BUY $$
I checked at best buy it was a Viper auto start, the unit was 199.00
Includes basic install?? But for the bypass and wiring it they soak you an extra 150 bucks!!
"Live like there's no tomorrow"
3dr5speedblk is offline   Reply With Quote
Old 12-09-2010, 08:13 PM   #5
SaToX
Drives: 3 door hatch
Been doing this for about three years now at a car audio shop, and for the yaris without the immobilizer it would be $199 installed with lifetime warranty. With the immobilizer it would be $279 installed. No hidden fees or any other B/S,,, just the tax :( I typically deal with Viper or AstroStart (another brand of Directed Electronics)
SaToX is offline   Reply With Quote
Old 12-10-2010, 04:28 PM   #6
3dr5speedblk
StickShift
Have you tried the Smartstart??
What has better range !!viper or Astrostart ?
I park about a football field and a half away from work!!
What viper model do you like? What about SMARTSTART??
Thanks for the info!!
Old 12-10-2010, 07:13 PM   #7
It typically depends on the model as to the range. I installed an UltraStart 1280XR, and the range is far better than any of the DEI remote starters I used on past vehicles. I can start my Yaris from deep inside Home Depot with it.
Old 12-10-2010, 07:46 PM   #8
TickleTimeTim
Free Mustache Rides
TickleTimeTim's Avatar
Drives: 2007 Yaris HB
real sorry for stupid question, but i gotta know...what is an immobilizer? i want to find a place to put electric locks in then do the remote start, so i need to know these kinds of things. ha
Club SHIFT
Old 12-10-2010, 09:13 PM   #9
The "Engine Immobilizer" is an OEM theft protection system that consists of a key that contains an RFID transponder and a device to read that transponder (which is part of the ignition switch assembly on so equipped Yaris). The ECM has the transponder keys' IDs registered and will only allow the engine to start upon reading those IDs. If you try to bypass the ignition switch to start the car, the starter will crank, but the engine will not start.
If your Yaris' ignition switch is all metal (inner and outer circles) then you don't have the immobilizer. If the inner circle is metal and the outer is black plastic, then you do.
Old 12-10-2010, 11:09 PM   #10
TickleTimeTim
Free Mustache Rides
thank you kind sir
Club SHIFT
Old 12-16-2010, 09:17 AM   #11
Midnight Drifter
Going Retro
Drives: '09 Tacoma | '90 Tercel
NJ has a similar law, but nobody actually follows it.
Midnight Drifter is offline   Reply With Quote
Old 12-16-2010, 12:27 PM   #12
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
damn these are a lot more affordable than I thought I am so interested now. Keep eyes out for online deals as will I
Remote Starter - Tail Light Problem Chrsto4 General Yaris / Vitz Discussion 4 11-01-2009 12:36 AM
Remote Starter Mistry In Car Entertainment + Electronics (audio / video / alarm) 1 09-14-2009 02:32 AM
Remote Starter..... djgab101 Cosmetic Modifications (Exterior/Interior) 8 06-26-2009 11:36 AM
remote starter, instaled but cant get tach sig? karl53913 DIY / Maintenance / Service 8 11-26-2008 11:40 AM
Remote Car Starter KittenRD Fuel Economy Forum 6 11-08-2008 12:53 PM
