Old 12-19-2010, 01:45 AM   #91
Bump for this thread as mine started to do the squeak (I guess mine is a late bloomer since I'm over 60k miles and 4 years, lol).
Old 12-19-2010, 09:45 PM   #92
YarisPR
YarisPR's Avatar
Drives: Yaris Sedan
Originally Posted by bkndacn View Post
^ from my experience I've learned that 90% of what dealers say is complete BS!
+1
Toyota guy after I tooked the yaris in for the squeaky sound: "the squeaky sound is normal" ...
This make me think about how much dedication the Toyota dealerships put on selecting their mechanics, I've had some really heated conversations with the service department because of things like theses
I Drive a 129whp Yaris ;)
YarisPR is offline   Reply With Quote
Old 12-20-2010, 12:09 AM   #93
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
I dare the next person in to their dealer to ask the Service advisor if they've ever actually worked on one of these cars! HAHAHA
Old 12-20-2010, 12:31 AM   #94
Originally Posted by YarisPR View Post
+1
I took my sedan back to the same dealership I bought it from to kill some time, some time ago, and one of the salesmen there asked me if my car was a Scion. wtf? lmao. FAIL!
Old 08-04-2011, 09:11 AM   #95
vvvvvvvvvvvvv
Drives: 2010 Toyota Yaris CE, 5-speed
Thumbs up It works!
Had noticed that squeak while lining up at a drive-thru. Lubed the mentioned part (earlier in this thread) with white grease, and the noise is gone! Thanks for that thread guys!
vvvvvvvvvvvvv is offline   Reply With Quote
Old 10-01-2011, 12:53 PM   #96
TickleTimeTim
Free Mustache Rides
TickleTimeTim's Avatar
Drives: 2007 Yaris HB
finally did this, thank god. just used valvoline multi purpose grease.
Club SHIFT
Old 10-31-2011, 01:30 AM   #97
dwrf6
Drives: 2007 Yaris hatchback
Same thing started on mine, '07 3dr, thanks for the fix.
dwrf6 is offline   Reply With Quote
Old 03-12-2012, 11:35 PM   #98
lmbk88
Drives: 07 White Hatchback
Finally decided to get the squeak checked out. My first mistake was going to the dealer first instead of checking this forum. They determined the noise was coming from the clutch pivot and clutch fork. They also want to charge me $1380 to drop the transmission to "fix" it in addition to some bearing that's inside the transmission. :P I think the mechanic at the dealer lubed it though, because the squeak is gone and it's shifting really nice now. Who knew such an easy fix existed? I've been living with the squeak I think since the first year and I bought in April 2006! It was intermittent at first and lately just became too often to ignore. I think I will wait and see how it goes.
lmbk88 is offline   Reply With Quote
Old 04-17-2012, 09:46 PM   #99
andulong
andulong's Avatar
Drives: 2008 Hatch Red
First hot day here in SO CAL since getting the Yaris and yes I got the squeak. Used this awesome forum and a few drops of Tri Flow and SILENCE!
Thanks so much!
andulong is offline   Reply With Quote
Old 04-20-2012, 02:56 AM   #100
vincentg
vincentg's Avatar
Drives: Toyota Yaris 2007
Thank you!! :D
JUST DRIVE
vincentg is offline   Reply With Quote
Old 04-26-2012, 07:54 AM   #101
watersoilair
Drives: 08-2DR-MT-LB-Red
Folks, I took mine to the dealership and they replaced the ENTIRE shifter bushing set. It was ceased. You can try lubricating, but the squeak will come back...the mechanic couldn't believe the state it was in...
watersoilair is offline   Reply With Quote
Old 04-26-2012, 11:35 AM   #102
nasdaddy
Drives: t
OK so I signed up to see the photo of where to lubricate but I know absolutely ZERO about cars, can you point me to where under the hood this is located? You can reference obvious things like battery, oil dipstick, etc. but back/front, left/right would be helpful. Thanks!
nasdaddy is offline   Reply With Quote
Old 04-26-2012, 01:21 PM   #103
Jerkratt
Jerkratt's Avatar
Do you have a pic of what it looked like? Cause i have less then 8 thousand miles before my 100 thousand mile warranty is up. I would like to get this fixed
"It hurts more when its wet"
Old 04-30-2012, 10:05 AM   #104
OH yaris
Drives: 07 hatchback + 06 EVO9
While standing in front of the engine bay, it is straight down on the right. You should see it below the air box/intake. I suggest having someone shift through the gears while you are staring down, you will see the moving parts. I had my wife shifting while i sprayed the lubricant; turned out just fine (and quiet). Hope this helps, good luck.
OH yaris is offline   Reply With Quote
Old 05-28-2012, 01:53 PM   #105
En4sir
En4sir's Avatar
Drives: '09 Yaris 3dr HB 5sp
Fixed mine too! After listening to it for 2 years I finally had enough.
"Never argue with an idiot. They drag you down to their level, then beat you with experience."
En4sir is offline   Reply With Quote
Old 06-06-2012, 03:32 AM   #106
mckc
Drives: YARIS D4D
Hi all I'm new here, does any body know if the same thing is on yaris MMT transmission? as TOYOTA said it is the same transmission , only robot rules it.
Sorry for my poor english.
mckc is offline   Reply With Quote
Old 06-27-2012, 09:13 PM   #107
gammaray
gammaray's Avatar
Drives: 09 3D Liftback
My 09 started this today. Called dealer first. 7 days out of warranty and he said they would have to charge me for checking it out. Did a search and found this. Thanks much! Worked great and shifts much smoother as well.
gammaray is offline   Reply With Quote
Old 07-02-2012, 06:53 AM   #108
YarYarBinks
YarYarBinks's Avatar
Drives: 07 Toyota Yaris LB
Send a message via AIM to YarYarBinks
Originally Posted by toyota View Post
hey can you use WD-40?
I used wd-40 over a year ago now and I still don't have a squeak anymore.
YarYarBinks is offline   Reply With Quote
Urgent! How to use auto transmission? hans_fh General Yaris / Vitz Discussion 55 04-16-2010 02:45 PM
2009 Yaris "S" - no 5MT Hatchback? Latka New YARIS Purchase Forum 21 11-07-2008 05:16 PM
New transmission at 8.5K miles! d2dailly DIY / Maintenance / Service 17 09-22-2007 12:41 PM
Want opinions automatic vs. manual transmission anik New YARIS Purchase Forum 84 07-10-2007 05:25 PM
Synthetic oil for transmission mrrock DIY / Maintenance / Service 7 04-26-2007 04:51 PM
