Old 12-17-2010, 09:27 PM   #163
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
Got ride of the too lean error code but now i got this....P2195 Does it mean my o2 sensor has gone bad? Need some input on this one
Old 12-17-2010, 11:30 PM   #164
Focus_Sh1ft
Focus_Sh1ft's Avatar
Do you have a scangauge?
Is the car in closed loop during light acceleration?
Old 12-18-2010, 02:17 AM   #165
Yoda
Yoda's Avatar
Nope I don't have one. How do I tell when it's in close loop
Old 12-18-2010, 09:28 PM   #166
Focus_Sh1ft
I would definitely recommend getting a code reader that has some data logging abilities. In a situation like this, you need all the info you can get to diagnose the problem.
Is your wideband maintaining stoich for the most part?
Old 12-18-2010, 09:44 PM   #167
Yoda
Yoda's Avatar
I think I have a vacuum leak somewhere in my hose. As for my wideband it idles at 15-15.6. Then randomly hits 16. Driving it ranges from the high 13s to high 14s under light cruise.
Old 12-18-2010, 09:54 PM   #168
Focus_Sh1ft
Hm, that's definitely possible. When I was running closed loop I wouldn't see more than +- .5 AFR off stoich, so you have a pretty big fluctuation there. Still - that would mean you're running richer than normal, yet you have a code that says "O2 stuck lean."
Old 12-18-2010, 11:39 PM   #169
that's lean, not rich.
Old 12-19-2010, 10:22 AM   #170
Yoda
Yoda's Avatar
I thought you wanted to run 14.7 under cruise I hit 13 sometimes. So I think that's alittle rich when there is no boost. What's your cruise A/F?
Old 12-19-2010, 01:17 PM   #171
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
my cruise AFR is 14.6-15.1
Old 12-19-2010, 01:32 PM   #172
Focus_Sh1ft
I have my cruise AFR tuned for 15-15.5 currently.
I'm going to suggest tuning in open loop, especially with your O2 going crazy as is. It's working well for pimp and I, and it's so easy.
Otherwise, you can continue troubleshooting the O2. I'd take the negative off the battery for a couple hours to reset the code since you don't have a code reader.
Old 12-19-2010, 08:56 PM   #173
Yoda
Yoda's Avatar
Found the leak in the vacuum lines. Idle afr@ 14.2-14.6.
Old 12-20-2010, 12:03 AM   #174
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
well, don't leave us hangin' like that, what was it? Operator error
Old 12-20-2010, 01:13 AM   #175
^ there ya go, that's what you want
Old 12-20-2010, 08:54 PM   #176
Yoda
Yoda's Avatar
Wrong size vacuum hose.
Old 12-21-2010, 08:28 PM   #177
Yoda
Yoda's Avatar
Got my injectors on and did a little fun drive. So my boost gauge showed I went all the way up to 11psi.....! WTF lol. And also there still must be a boost leak somewhere cause I was running lean at 5psi. Now I gotta find that leak sigh.
Old 12-21-2010, 10:21 PM   #178
Yoda
Yoda's Avatar
I think the leak might be coming from the compressor inlet. I noticed the coupler not flushed and snug on there. I think that may be why it's still running lean when I get on it. All that unmetered air being compressed.
Old 12-23-2010, 05:27 PM   #179
pimp my yaris
C'est la vie
pimp my yaris's Avatar
Drives: 2009 2 door hatchback
The wastegate actuator on that turbo does not even start to open until 10 psi. So 11 psi sounds about right. I allready went through most of these problems with my car. I had to add a additional spring straped to the W/G actuator and strut tower under the hood to open the wastegate sooner. It looks ghetto but it works. It now opens at 5 psi and maxed out at 8 psi at 6K rpm. I have some pics of spring on my thread. I also had to disconnect my o2 sensor and richen fuel across the entire rpm and load range with my piggy back to get it runing good.
pimp my yaris is offline   Reply With Quote
Old 12-23-2010, 07:01 PM   #180
Yoda
Yoda's Avatar
Well I got it all sortted out. Had a big leak by the inlet. Have it set at 7psi and to tell you the truth I thought it would be faster..... Maybe I need to really tune it up to get the most power out of it. What I was hoping for was neck snapping tq. Or that feeling you get as if some1 is pushing you into your seat. All in all its still worth it. Something I built myself and is different. Also order a new Bov. Greddy type RS ftw!!!
Turbo Project Yaris TS 1.8L CASTREX Yaris TS Talk 40 08-21-2009 11:24 AM
HKS turbo timer type 1 Tamago Performance Modifications 3 07-21-2009 12:59 PM
Turbo Kit - trade for stock parts! crankyelbow Items for Sale by private party 62 02-03-2009 01:30 PM
delayed turbo project... joey1320 Forced Induction Forum 8 09-27-2007 12:18 AM
Vitz Rs turbo vs U.S. Yaris add turbo? weaponrcamry Performance Modifications 18 08-09-2006 09:45 PM
