Old 12-20-2010, 12:50 AM   #1
nisyota
Suspension Torque Specs pls
Im about to install the Tokico front and rear strut/shock from microimage. Just wondering what the torque specs are or where i can go them from?
Thanks...
nisyota is offline   Reply With Quote
Old 12-20-2010, 07:51 AM   #2
Front strut bottom mounting bolts: 121 ft lb
Front strut brake hose mounting bolt: 22 ft lb
Front strut top spring compression nut: 25 ft lb
Front strut top nut: 41 ft lb
Front strut stabilizer bar bolts: 55 ft lb
Rear shock top nut: 18 ft lb
Rear shock bottom bolt: 36 ft lb
Lug nuts: 76 ft lb
Old 12-20-2010, 11:40 AM   #3
nisyota
thank you so much!!!!!
Old 12-20-2010, 12:08 PM   #4
annn
ヤリスワールド
annn's Avatar
Drives: 2008 HB
Remember to support the drive axels well.
Btw are you hats/ the washers that hold the front struts on at the top , have a gap in them ?
annn is offline   Reply With Quote
Old 12-20-2010, 08:29 PM   #5
nisyota
i dunno... havent started. lol
Old 12-20-2010, 09:08 PM   #6
annn
ヤリスワールド
annn's Avatar
Drives: 2008 HB
Perfect... Before you start please check and see if the hats are raised ?? Thanks
I just did a eibach spring and tokico hts upgrade , so of ya need any info their I'd tons of info on this site !
Old 12-20-2010, 10:15 PM   #7
Shinare
Bronze bombshell yaris
Shinare's Avatar
Drives: 09 Yaris HB 3door
I've been meaning to do this for everyone ever since the big argument in the other thread about this. My car's suspension is bone stock, noting REPEAT nothing has ever been done to it. Its this way from the factory:
PS> car is empty in this pic
Old 12-21-2010, 05:34 AM   #8
nisyota
i won't forget... you guys know what the torque spec is on the serpentine belt??? thanks again!
Old 12-21-2010, 08:04 AM   #9
The belt deflection spec is 7 to 8.5 mm for a new belt and 11 to 13, once the belt has been run.
Bolt torque is 14 ft lb for the top bolt and 40 ft lb for the bottom.
NSW Proposed Suspension Restrictions Bella Australia 0 09-22-2010 02:51 AM
2011 Nissan Juke SPECS incase anyone is interested.. marcus Off-topic / Other Cars / Everything else Discussions 3 09-01-2010 10:39 AM
Yaris TS 1.8L History and Specs CASTREX Yaris TS Talk 52 10-27-2009 06:06 PM
Yaris Performance Specs neohalo Performance Modifications 22 06-24-2007 09:46 PM
Torque Settings, front suspension Nimble Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 02-21-2007 02:00 PM
