Old 12-05-2010, 03:53 AM   #1
mtlycru06
Drives: Black '07 Yaris
Little Problem... BIG rip off!!
Is there a specific type of tire iron i need to use on my 07 yaris? they want to charge me $20 per bolt to change my tires!!!! WTF?? so yeah... what do i need to change the tires on my car??? SOMEONE HELP ME!!
mtlycru06 is offline   Reply With Quote
Old 12-05-2010, 06:00 AM   #2
nemelek
DWEED
nemelek's Avatar
If it is a stock set up you should have what you need in the trunk. Otherwise you would be in big trouble if you had a flat.
Old 12-05-2010, 07:42 AM   #3
Are you sure that they are saying per bolt, or is it per rim and the $20 is the unmount/remount/balance fee?
Old 12-05-2010, 09:08 AM   #4
Klink10
Klink10's Avatar
What CT said. Are you buying tires? If so, that should be included.
Old 12-05-2010, 10:32 AM   #5
DARK AGE 53
Drives: 2009 Yaris Onyx
you've lost me here, so you don't have a jack or tire iron....check under the drivers seat....... If your in the Lansing area let me know.
DARK AGE 53 is offline   Reply With Quote
Old 12-05-2010, 08:56 PM   #6
auxmike
auxmike's Avatar
Car comes with tire iron AND jack! Read your owners manual please!
Old 12-21-2010, 09:02 AM   #7
the_boss
the_boss's Avatar
Drives: 07 YARIS HATCH 5 DOOR
Send a message via MSN to the_boss
the jack is under the driver's seat and the rest of the needed junk is in the trunk in a little black bag next to the spare tire...ehh I guess it's there..well I hope it's there in mine!
the_boss is offline   Reply With Quote
Old 12-21-2010, 10:09 AM   #8
I can't tell if the OP wants to rotate the wheels, or actually changes tires on wheels.
Old 12-21-2010, 11:02 AM   #9
SpaceShot
SpaceShot's Avatar
Drives: 2008 Yaris 5 speed HB
If you bought the car used and the jack and iron are MIA, any 2-Ton trolley jack and a cross type tire iron with a 21mm socket (from a local auto parts store) will be sufficient for changing and rotating your wheels. (given that you have stock wheels and lugnuts)
Even though it is heavier than the scissors jack from Toyota, I prefer the stability of the trolley jack when changing wheels at home, and the cross type wrench allows me to put more torque on the lugs to get them off.
If you want to spend less, goto a salvage yard for a Toyota scissors jack and lug wrench from most any of the economy models. (Yaris, Corolla, Tercel, Scion XB and XA)
SpaceShot is offline   Reply With Quote
Tags
help!, tire iron, tires
Toyota C160 Reverse Gear Problem Parmas DIY / Maintenance / Service 2 12-01-2010 01:30 AM
'54 T2 Yaris 1.0 VVTi automatic clutch / gearbox / starting problem Lettuce UK 0 09-30-2010 06:21 AM
HELP!! HID problem 07yaris_fe General Yaris / Vitz Discussion 2 11-20-2006 06:00 AM
So how do you like the BIG SMILE on the 07 Sedan???? Ziv General Yaris / Vitz Discussion 3 02-03-2006 11:12 AM
