Old 04-30-2006, 01:01 PM   #1
Idjiit
5 Stars, Bitches
Drives: Prius, Silver Yaris Liftback
DIY - Sparco Race Seat Install
Sorry I didn't do a full step-by-step on this one, but I was short on time. The procedure is fairly straight forward, but let me know if you've got any questions. For details on removing the stock seats and related info, go here: http://www.yarisworld.com/forums/showthread.php?t=312
The Sparco brackets had to be raised a bit to get clearance over the slider bolts - this isn't absolutely necessary, but if you don't do it the seat will be about a half inch, maybe an inch off center (to the left of the steering column). I can afford the space, so I went ahead and did it "right".
This was done by removing the stock seat from the stock slider rails, and using the rails/seat base as the base for the Sparco. I used flat steel stock to create some cross-bracing. Steel L-stock was used to attach the receiving side of the seatbelt.
There's a couple caveats with this solution:
A) It's heavy. As noted earlier the stock setup is 37lbs - the Sparco setup is 34lbs. Not a big savings. This is a combination of things - the stock seat base is heavy, and the metal cross braces I used are quite heavy since I used the heaviest gauge steel I could find.
B) It's not very clean looking. Keep in mind that the seat in relation to the base is offset to the right about 3 inches, so with the narrow Sparco base it's inevitable that you're going to see all the hardware. A fixed base setup would look much cleaner.
C) Ideally 2 screws would be used for each side of the cross braces to increase strength, but this would most likely require welding, which is outside my skillset.
Underside, showing cross-braces:
Closeup of part of seatbelt sensor. Not sure if this is just detected whether the seatbelt is attached, or if it's also measuring weight on the steel (measuring difference in resistance in "empty" vs. "seated"? I'm not sure - I know the passenger side detects weight, I'm not sure about the driver's side):
The plug that attaches to the car itself:
Side view showing how far the slider mechanism protrudes. I could have had this further back by using a different set of screw on the slider rails, but it would have meant that I had more rail at the back protruding into the passenger area, which I need for the storage setup I have planned:
Belt L-bracket before painting - note that the seat at this point is moved forward on the rails. Normally the back of the L-bracket would be flush with the back of the seat base:
Detail of L-bracket, which is mounted underneath cross-braces. This corresponds with extra height on the left side, do to the slider-release mechanism, although it's a bit thicker than it should be, I may add washers to the other side later, but you certainly can't feel the difference:
Installed - note that the belt has been looped through the seat so it's taught against my belly (I'm 6', 140lbs - if you're bigger you may not need to do this):
Close Up of the exposed slider bracket. Sorry, no OEM look here...
From the Outside:
All told with this setup, I can go as low as 3 inches below stock. I currently have it at 2 1/2 inches, but I think I'll either tilt the front up slightly or bring the whole thing up 1/2 an inch. The unfortunate thing is that you're really limited by the angle of adjustment on the steering wheel. If you had it down 3 inches you'd really have to reach up to get to the steering wheel, which is a bit awkward.
Idjiit is offline   Reply With Quote
Old 04-30-2006, 07:51 PM   #2
riceboy
Drives: icebox
Looks good, too bad it's not cleaner, but like you said it'd be difficult with how things are setup... I'd love to see someone put these on: http://trdparts.jp/english/parts_seat.html
riceboy is offline   Reply With Quote
Old 05-04-2006, 12:31 AM   #3
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
Those look good as well, I wonder how much they weigh.
Colin Chapman disciple
Old 05-25-2006, 12:36 AM   #4
SophieSleeps
Podiatrist
SophieSleeps's Avatar
Drives: Turbo IS300
I dunno if I would just bolt those flat steel pieces in.
In an accident I don't think it'd hold up all that great.
How about welding in some supports?
Running the flat steel across the seat seems like over time it would warp. One of my friends modified his jeep seats in a similar fashion and he needs to take them out and bend them back every once in a while.
SophieSleeps is offline   Reply With Quote
Old 05-25-2006, 10:09 AM   #5
Idjiit
5 Stars, Bitches
Yeah, it's not ideal. I used extremely heavy gauge steel though, so I doubt it will bend. The big bummer is that it's quite heavy. This is a temporary solution until I can get a proper Sparco base/sliders.
A better roll-your-own solution would be using steel square stock. I didn't go that route since I wanted to get maximum height adjustibility, but in retrospect even using 3/4" stock would still give me the range I actually use.
Old 09-06-2006, 10:36 AM   #6
ChinoCharles
Drives: LB
Anyone want to take a crack at raising the amount of play in the steering wheel? One of the things I HATE about this car...
Old 09-06-2006, 11:04 AM   #7
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
Your thinking is going to make work for me again. Hummmm..
Old 09-06-2006, 11:35 AM   #8
Katana
Katana's Avatar
Drives: Yaris LB 1.3lt 06
Ιt looks great!
Old 02-09-2007, 11:29 PM   #9
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
100% agreed, adjustment is needed!!!
Old 02-09-2007, 11:38 PM   #10
spkrman
Drives: 1
x500...
i'd like for the wheel to be able to come out farther, oh well.
Old 02-10-2007, 03:31 PM   #11
C2AUTOSPL
Drives: 240sx, 00 Celica
Originally Posted by spkrman View Post
x500...
Get and aftermarket steering wheel. Hub + QR Spacer + Nardi Sport Rally 350mm will extend the steering wheel atleast 3in.
SUPPORT YARISWORLD'S VERY FIRST SPONSOR!!
C2 AUTOMOTIVE SPECIAL
24711 Redlands Blvd., Ste. I
Loma Linda, CA 92354
T: 909-796-8189
E-mail: info@c2auto.com
AIM: wide180sx
C2AUTOSPL is offline   Reply With Quote
Old 02-13-2007, 02:11 PM   #12
Katana
Katana's Avatar
The european version is fine.
Old 02-13-2007, 07:41 PM   #13
Black Yaris
der Zeck
Black Yaris's Avatar
Wonder how hard it would be to get a European Colmn with tilt and telescope?
Old 08-22-2007, 12:44 PM   #14
360cubes
Drives: 2000
Send a message via MSN to 360cubes
Man. Sparco makes some nice seats. It's a shame my big rear end wouldn't fit in there!
360cubes is offline   Reply With Quote
Old 08-22-2007, 12:53 PM   #15
Black Yaris
der Zeck
can someone get ahold of these?
72101-NP100 & 72102-NP100 Approx. 15mm lowering
Old 08-14-2017, 09:44 PM   #16
DarkShadowFox
404 error
Sent from my LG-H918 using Tapatalk
Old 08-14-2017, 10:15 PM   #17
SirDigby
Drives: 2007 yaris 3 door
^^^that was 10 years ago. he's probably dead...
Back Seat Removal... Idjiit DIY / Maintenance / Service 87 02-08-2015 01:07 PM
