![]() ![]() ![]() ![]() ![]() Drives: Polar White - 5 Door '09 LB Join Date: Aug 2006
Part Number(s) for '09 5-door LB engine air filter?
I need to change the engine air filter for my '09 5-door LB. Anyone have the part number for the OEM Toyota filter or the part number for a 3rd party filter I can get from AutoZone or Checker's Auto?
Thanks. |
I got an OEM Filter right in front of me and the number is: 17801-21050.
If you are interested in a K&N filter (I'm using one) the number is 33-2360. |
Thanks!
Anyone have part numbers for 3rd party engine air filters that are available from AutoZone or Checker's? I don't want to use K&N since I'm in a dusty region. Also, is there a DIY on how to change the engine air filter? |
#4 | |
![]() ![]() Drives: 2007 Yaris HB Join Date: Dec 2009
Have you tried going to you favorite parts store's web site and looking up what you need? The Checkers/O'Reilly's web site says they carry a Wix 49104 and a Microgard 10190. Autozone carries the STP 10190. A DIY would insult your intelligence. Just loosen the two metal clips that hold the air box tight, lift up the top a little and pull out the old filter. Put the new filter in oriented the same way as the old one. It is irregularly shaped and has a groove in it, so it only fits one way. Push the box back together, put the clips back on, double check to make sure it's on straight and tight all the way around and you're done. |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2008 Yaris Liftback (Sprocket) Join Date: Oct 2008
Go to a Toyota dealership, they are less than $15...
And it is a simple replacement, remove the clips on the airbox, take out the old filter, put in the new one, and close. The filter has a small edge on one corner so it will only go in one way. Takes maybe a minute... Cheers! M2
Drives: 07 yaris sedan Join Date: Dec 2010
just ask them for an air filter... its not there gonna be like "a what? an air filter? what's that... do you have a part number?
| OEM Engine Air Filter Parts Number? | 2007yariz | DIY / Maintenance / Service | 2 | 12-05-2010 10:19 AM |
| Liftback Air Conditioning (Cabin) Filter info | Snappy | DIY / Maintenance / Service | 24 | 10-01-2010 06:36 PM |
| Anyone have Yaris air and oil filter numbers? | Yaris_Fan | DIY / Maintenance / Service | 54 | 02-11-2009 01:14 AM |
| Which Engine Air Filter to choose? | YANGSTER | Performance Modifications | 16 | 09-29-2007 10:48 AM |
