Old 01-13-2011, 10:19 AM   #235
The best mixture is 14.7 stoich AFR
stoich yes, at WOT no, better down around 12. Dyno pulls are done at WOT.
Old 01-13-2011, 12:27 PM   #236
Parmas
Parmas's Avatar
Drives: Vitz RS Turbo
I forgot to mention 12 AFR for boost and lower AFR for high boost in case of boost spikes.
Parmas is offline   Reply With Quote
Old 01-13-2011, 04:35 PM   #237
Nexus1155
Bathroom + Laptop = <3
Drives: Audi
Sorry you are wrong here, richer mixture isn't equal to greater numbers infact it's the opposite way.
Ehhhh, Sweet spot is around 11.* for turbos and theres a bunch of reasoning behind that. Of course you can lean it out and make power, but aiming for stoich, really? you will make more power from having a proper afr and more ignition advance.... Safer too.
Old 01-13-2011, 04:42 PM   #238
scioncrew
scioncrew's Avatar
Drives: SCION tC
Send a message via AIM to scioncrew
YAA LEAN IS MEAN!! LOL LOVE IT!
05 Scion tC allmotor 350+ hp 9.34@144mph
05 Scion tC sfwd 880hp 9.96@147mph
05 Scion xB 280hp 12.97@104mph
07 Toyota Yaris 357hp 12.80@107mph
scioncrew is offline   Reply With Quote
Old 01-13-2011, 04:46 PM   #239
scioncrew
scioncrew's Avatar
Drives: SCION tC
love to see what that motor looks like now.
Old 01-13-2011, 05:10 PM   #240
Scubaru Steve
Awesome!
Drives: 12 Yaris/07 yaris
+1
Old 01-13-2011, 05:48 PM   #241
Focus_Sh1ft
Focus_Sh1ft's Avatar
Nice numbers - scary lean AFR though.
Must be the high octane fuel and methanol that's keeping your motor in one piece.
Old 01-13-2011, 07:10 PM   #242
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
Congrats on some real nice numbers. Looks like it went very lean above 4k?
What was your boost on that pull?
How come it stops making power at 4200 rpm?
youre looking at the torque curve garm.
Ptuning.com
Blown_xa is offline   Reply With Quote
Old 01-13-2011, 07:20 PM   #243
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
Good numbers man. If you talk to your tuner again soon, ask him what correction he entered. I see it says sae correction method on the sheet. If its the latest method, it accounts for atmospheric conditions and a 15percent mechanical friction loss. Regardless, numbers are far from conservative as sombody say opposite. 300hp plus from a 1.5l is anything but conservative. So cheers to that.
Ptuning.com
Old 01-13-2011, 09:12 PM   #244
H3LlIoN
Drives: '09 Yarrrr hatch
Sweet numbers. Curious...what are you hoping to run at the track? What were your E.T.'s on the old build?
Toyota
Moving Forward
...even when you don't want it to.
Special thanks to Cali Yaris, 1NZYaris1 and lilredrocket
H3LlIoN is offline   Reply With Quote
Old 01-13-2011, 11:59 PM   #245
scioncrew
scioncrew's Avatar
Drives: SCION tC
man thats a realy good looking dyno gragh. hopping you will take it to the drag strip. good job on your build
Old 01-14-2011, 01:06 AM   #246
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
Check your fuel pump/lines/tune your running way way to lean I'm surprised you didn't melt a plug.
Old 01-14-2011, 03:54 PM   #247
xbgod
Drives: "Burning It Down GTX2860RS XB"
Haven't considered E85. And to the other guy on my fuel pump, lines and so fourth, are you serious? I'm not even going to respond to that. All is working well and tune is great. I made good numbers and now I'm movin on. It's time to finish pimping it to look sexy and wash and wax it. The only thing I'm doing on the side is getting involved with someone else on a real cam set for these motors. This will be in the works for a little while but you can bet when I'm done with R/D with that it will be bullet proof. Don't ask me any questions on it cause it's top secret right now. But you can rest assured I will have a real head cam set for next year. It's been alot of fun and I set out to make power and did so. So if your a hater out there then beat my numbers, good luck.
XBG
xbgod is offline   Reply With Quote
Old 01-14-2011, 04:26 PM   #248
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
Waiting for the vid now so i can see it in action.
Old 01-14-2011, 04:59 PM   #249
^ I think it would be good for the tuning community to know (and I would think you'd be curious too):
1. Why it was so lean.
2. Why the power curve gives up early.
Besides that, the low end power must feel very sweet. I don't have it down there any more.
Looking forward to seeing the video.
Old 01-14-2011, 05:05 PM   #250
xnamerxx
0-60 in slow
xnamerxx's Avatar
Your running 15:1 afr at 5700 rpm's what about that screams yeah this motor is getting enough fuel. I have no idea what pump/pressure/fuel lines your running. Being that the afr only looks marginally good at 3-3.5k my guess would be that the fuel pump can't keep up. Just because it didn't blow up on the first run doesn't mean it won't. Id rather not see your motor that costs a pretty penny because your letting it run lean.
Unless your fuel system can handle another 30% increase in flow I wouldn't even have e85 on radar.
Old 01-14-2011, 06:28 PM   #251
xnamerxx
0-60 in slow
xnamerxx's Avatar
Im pretty sure the power is giving up so early because the turbo is to small for the amount of power hes making. You can see it in the torque curve how it starts to die at 5k rpm's. Dont know the specs on his cam or the rpm range of the intake he's running but Id have to hazard a guess and say both are rated for something like 3-7.3k rpms but the turbo doesn't have the cfm to keep up.
If you look at the compressor map for the disco potato it gives up on at about 35 lb per minute with 2.2 bar. Rule of thumb is 10 hp per every lb per minute so easy math says 350 hp give or take 20 hp.
Old 01-14-2011, 09:53 PM   #252
Nexus1155
Drives: Audi
Tial / Garrett GTX-2860 RS Turbo w/ SS Housing and Billet Wheel
Walboro 255l , Aeromotive regulator , Perrin fuel rail ,
Aerospace Components custom fuel block for NX kit
680cc Precision injectors
for xnamerxx ^^^
Does your standalone tell you the duty cycle the injectors are running at. Looking at that graph seems like you have something more to work with, like a handful of the people here say.
Want to build costom turbo kit. Need advice from boosted guys! pimp my yaris Forced Induction Forum 639 09-28-2013 11:26 AM
FS: 2005 Scion xA RS2.0 Turbo uberegg Cars for Sale by private party 40 04-03-2010 11:45 AM
Scion xd turbo PARIS Yaris TS Talk 22 02-26-2010 08:08 AM
Check out the new Scion iQ concept. In the States in 2011/2012 LA Yaris California 9 10-23-2009 08:11 PM
