Old 01-17-2011, 08:07 PM   #271
xbgod
Drives: "Burning It Down GTX2860RS XB"
No ghost, just out having a little fun and had to fix an exhaust leak.
I see I missed alot in past few days, holy-crap.
Remember I don't use VVTI so that has some play in what your reading. Also the XB starts to fall on it face at around 5000-5200 RPM. Paul at Dezod can even tell you this. It's just the way it is. As far as being lean My car likes it there. It dosen't detonate and pulls like a beast. More than likely because of my 107 octane and M1 meth.
All is well so I hope this helps, if not sorry..........I'm running'em down and enjoying the car.
You guys can keep running your own senarios and speculation, it happens especially on forums.
Thanks to all that have followed me.
XBG
xbgod is offline   Reply With Quote
Old 01-17-2011, 08:38 PM   #272
H3LlIoN
Drives: '09 Yarrrr hatch
I'm gonna chime in...I don't think any of the heavy 1nz hitters are running VVT-I, AFAIK, mostly because of A) Some standalones don't offer control modules yet (I can vouch for that) and B) from earlier speculation in this same thread by Aras and others, at a certain point it becomes a hindrance as opposed to a power builder. (Which doesn't make sense to me, but whatever...I don't have a 350hp 1nz to play with and speak from experience.)
Also, I'm currently picking my nose and drinking a miller light. I may or may not have already consumed a number of long island iced teas.
Toyota
Moving Forward
...even when you don't want it to.
Special thanks to Cali Yaris, 1NZYaris1 and lilredrocket
H3LlIoN is offline   Reply With Quote
Old 01-17-2011, 08:40 PM   #273
H3LlIoN
Also, this post got pushed to the side and I was hoping for some speculation from Aras. Thanks
Originally Posted by H3LlIoN View Post
Sweet numbers. Curious...what are you hoping to run at the track? What were your E.T.'s on the old build?
Toyota
Moving Forward
Old 01-17-2011, 08:42 PM   #274
H3LlIoN
Originally Posted by cdydjded View Post
Well there you go, 1 reason (the biggest) for the difference in HP is that he is NOT using the VVTI. So in essence you cant compare a NA dyno that uses VVTI to his....
And in regards to this, I highly doubt that Garm is comparing an NA dyno to Aras'....I think he's more comparing his non-vvt-i turbo set up.
Toyota
Moving Forward
Old 01-17-2011, 08:42 PM   #275
All I did was ask two questions. (1. Why does it stop making power at 5200, and why was it tuned that lean). I was called a hater and now hostile. I haven't said a critical thing about the build or the tune. Lame.
I asked why, it was just a question. Art's didn't (280whp). Mine doesn't (357 whp). So, that question remains unanswered. "That's just the way it is" is not a useful answer.
The second question really belongs with the tuner, as he seems to be the only one who can answer it. "It likes it there" is great to hear, but again is not a useful answer IMO.
xbgod, you got great numbers. (I already said that). If you're not curious about the why of these things, that's fine, it's your project of course!
Old 01-17-2011, 08:43 PM   #276
H3LlIoN
Hater.
Toyota
Moving Forward
Old 01-17-2011, 08:58 PM   #277
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
Explain to me how this matters, hes not running a stock cam iirc and not only that he doesn't have a stock intake and why dont his torque numbers drop sharply like they would if he fell out of the stock cams torque band. Not only that doesnt Garm use stock cams with vvti turned off.
I wont say im a expert at tuning but what im seeing on his dyno sheet is very obvious to whats going on. Im not saying maxing the turbo out is bad just saying he did that and his dyno proves it.
As for running lean its not detonation you need to worry about its going to be scuffing pistons and cracking rings and ringlands and pre-ignition.
Old 01-17-2011, 09:00 PM   #278
xbgod
Garm, your no hater. I still love you...........In a non-gay way!
My tunnner "Rolo" is coming over to the shop on my side of the bay for a tweak on my ride for street driving. Setting it up as the way I drive and not just a heated pull on the dyno.
XBG
Old 01-17-2011, 09:06 PM   #279
H3LlIoN
The actual correct terminology is "no homo."
Toyota
Moving Forward
Old 01-17-2011, 09:17 PM   #280
H3LlIoN
You cannot compare Garms build to xB build. They are all different. The only thing they have in common is the the are turbocharged.
I beg to differ. While they have inherent differences, they are running the same engine, the same compressor (turbo), and similar fuel systems. Obviously we cannot compare the flow characteristics of the head work and tuning maps, but given the ultimate goal of both machinists/tuners involved, I think that these two builds are more similar than you are giving them credit for.
^that post is for Carlos. For everybody else that doesn't understand what is going on, I'm not saying these two builds are in any way identical.
Also, Cotton needs new shorts, and I still would like some discussion on ETs, as I am a 1/4 mile nut. Aras, did you run the old build? Are you gonna run this one? Any idea what you think she'll run?
And I'm out of beer. Anyone close to VA?
Toyota
Moving Forward
Old 01-17-2011, 09:52 PM   #281
H3LlIoN
Here are some key differences:
1 The port job on the head
2 Weapon-R sheet metal intake
3 Edlebrock Victor-X 70mm TB
4 Garrett GTX-2860 RS Turbo w/ SS Housing and Billet Wheel
5 LHT Performance custom Exhaust manifold/ down pipe and all intercooling pipe
6 680cc Precision injectors
All the above items make HIS build incomparable to Garms or Arts......
I actually took the time to respond to each of these points individually and weigh a valid argument for why the builds are similar enough to be comparable, but then I re-read your response, and realized that you are far too defensive and obtuse at this time to actually give any serious thought to a word that I would have said. I initially though that someone with (what I thought was) your level of understanding of what goes in to engine design would understand my initial comment, hence why I singled you out so that others wouldn't read in to what I had posted. I guess I had given you too much credit, although I doubt that's it. In my experience with you, you seem decently knowledgeable. Perhaps you just aren't willing at this time to hear any other points of view. Some other time, I guess.
Also, I'm still out of beer. How close are you to VA? Wanna grab a beer and talk shop? My treat...
Toyota
Moving Forward
Old 01-17-2011, 10:09 PM   #282
H3LlIoN
No, no, no. You got it all wrong.
You're supposed to say "What? What did you call me"
and then I'm supposed to post "Obtuse. Is it deliberate?"
And then you're up again with "Son, you're forgetting yourself."
and we go back and forth like that for a while, and I end up getting a bunch of time in solitary.
Toyota
Moving Forward
Old 01-17-2011, 10:13 PM   #283
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
Ehh whats going on here. Been awhile since i seen this type dribble since Tamago days. Lets not attack each other over a dyno sheet its not that serious.
Old 01-17-2011, 10:14 PM   #284
H3LlIoN
I'm not attacking anyone.
Toyota
Moving Forward
Old 01-17-2011, 10:36 PM   #285
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
So can we see that video? :)
Old 01-18-2011, 09:14 AM   #286
Parmas
Parmas's Avatar
Drives: Vitz RS Turbo
I really don't understand this post and I hope that XBgod can respond clearly here
What do you mean by fall on its face?
The way it is? I really don't know what do you mean?
Your car likes it there? I never heard of an XB talking maybe you really are an XBgod
I hope you will still enjoy your car really, but no one said running lean will selfdestruct immidately but in time it happens and I hope you want cry on this forum if it happens since we warned you
XBG
Parmas is offline   Reply With Quote
Old 01-18-2011, 01:03 PM   #287
xnamerxx
0-60 in slow
xnamerxx's Avatar
xnamerxx: Explain to me how this matters, hes not running a stock cam iirc and not only that he doesn't have a stock intake and why dont his torque numbers drop sharply like they would if he fell out of the stock cams torque band. Not only that doesnt Garm use stock cams with vvti turned off.
You cannot compare Garms build to xB build to Art's build. They are all different. The only thing they have in common is the the are turbocharged.
What is obviously going on?
How do pistons get "scuffed"
BTW detonation & pre ignition is the same thing....
Its simple air consumption is related to the amount of power you can make. If the limiting factor is his turbo which can only flow x amount of air no matter how much you rev the thing it will only consume as much air as the turbo is capable of putting out. Thats why his power band stays so flat. If you look at people who max the turbo out on their evo or sti or gti they all do the same thing.
When you run lean your combustion temperatures get hotter then optimal. Heat causes metal to expand. Since a piston and cylinder only have so much clearance if the metal expands to much it will reduce clearances and press against the walls of the cylinder which causes the pistons to scuff in the bore. Also running hotter will cause the rings to expand more then designed for and if the rings touch end to end they will crack and probably break the ring land in the piston causing a failure.
As for detonation and pre-ignition being the same thing no. If you believe that I suggest you google the subject. You get detonation from a many things but it always happens after the spark and pre-ignition before the spark.
Since you clearly don't understand/believe the information being given maybe you should try to prove why your right rather then argue why I'm wrong.
Old 01-18-2011, 05:54 PM   #288
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
This is some funny shizat. haha! It's mathmatically impossible for torque curve to not cross at 5250. Only cars where is doesnt drop off much is an s2k or Formula 1 car, and that has more to do with volumetric efficiency at high rpm... which the 1nzfe will never see. The only thing we can do is maybe crazy cams and a efficient turbo set up to get good top end. Nobody is ever gonna destroke a 1nzfe.
I think people got a bit bent of shape here. Its basic knowledge on what afr should be, I highly doubt the tuner is oblivious to that.
Ptuning.com
Blown_xa is offline   Reply With Quote
Want to build costom turbo kit. Need advice from boosted guys! pimp my yaris Forced Induction Forum 639 09-28-2013 11:26 AM
FS: 2005 Scion xA RS2.0 Turbo uberegg Cars for Sale by private party 40 04-03-2010 11:45 AM
Scion xd turbo PARIS Yaris TS Talk 22 02-26-2010 08:08 AM
Check out the new Scion iQ concept. In the States in 2011/2012 LA Yaris California 9 10-23-2009 08:11 PM
