Old 01-25-2011, 01:39 PM   #1
jaimico
Drives: yaris advance
Spark plugs
Hello people, what would be the best set of spark plugs to install on a 2008 yaris, besides the OEM?
jaimico is offline   Reply With Quote
Old 01-25-2011, 01:48 PM   #2
bronsin
bronsin's Avatar
Here we go...
Old 01-25-2011, 03:06 PM   #3
severous01
how abour some equivalents from NGK from autozone....why pay 30 bux a plug at the dealer when you can get the SAME EXACT PLUG from autozone or orileys for about 6 bux each...
Old 01-25-2011, 03:14 PM   #4
bronsin
bronsin's Avatar
Stick with OEM. Dont they say they are good for 100K?
Old 01-25-2011, 06:05 PM   #5
bankrobber
Drives: 2007 Yaris Hatchback
I went with denso iridium spark plugs. It idles much better with the A/C on. It dosen't feel like it is going to stall anymore. I got them at Discount Auto Parts for 7.99 if I remember right. NGK also makes a similar quality plug. I would not buy anything that is not iridum though. Replacing the spark plugs on the Yaris is so much easier than on my Dodge Ram. You will need a 6" extension to reach the plugs.
bankrobber is offline   Reply With Quote
Old 01-26-2011, 04:28 PM   #6
RedRide
RedRide's Avatar
Either Denso or NGK iridium plugs are fine
Actually, Toyota uses NGK on ocasion
In fact, my Celica came with NGK iridium plugs.
Old 01-26-2011, 04:37 PM   #7
giecoyeinram
Drives: yaris 2010
heyyy...try splitfire....g
giecoyeinram is offline   Reply With Quote
Old 01-26-2011, 09:01 PM   #8
bronsin
bronsin's Avatar
Whatever happened to those?
Old 01-26-2011, 10:21 PM   #9
severous01
ooooh oooh.....E3 plugs are good....for a lawn mower...(does a yaris count as a mower?)
or you can always put PULSAR on the yaris. they're 25 a pair though...and 30 for the iridium
Old 01-27-2011, 09:27 AM   #10
jaimico
Ok it seams that DENSO or NGK, thank you for the advise, since my idle with the a/c is not as smooth as it used too be, I´m goit to replacement them, and it is time too.
Old 01-27-2011, 11:12 AM   #11
severous01
NGK only...that or denso, or Delco, which is usually made by either denso or ngk...depending on style and make.
i wouldnt put champion in my lawnmower, and i wouldnt use autolite in my enemies' lawnmower.
spark plugs phenoyz DIY / Maintenance / Service 48 01-18-2023 03:26 PM
Spark plugs for yaris RS 2zrfe engine candy_red Yaris TS Talk 3 11-16-2009 02:20 PM
article on spark plugs and the fit kngrsll Performance Modifications 4 08-02-2009 12:50 AM
did autolite spark plugs screw up coil or coils ?? la_scanner DIY / Maintenance / Service 20 04-09-2009 03:07 PM
Upgraded Spark Plugs For Boost whooppee777 Forced Induction Forum 9 02-14-2009 02:53 PM
