Old 02-02-2011, 06:09 PM   #19
OTB
OTB's Avatar
Drives: 2zz MR-2 Spyder
Camber and tire wear....
Just a follow up on tire wear comments....
If you're treating the car the way you should (burning through the twisties as often as possible) a few - degrees up front and -1.5 in the rear won't wear the tires out unevenly. If all you do is drive in a straight line, don't bother with a performance alignment, and you should probably consider a vehicle that's more fun in a straight line.
OTB is offline   Reply With Quote
Old 02-05-2011, 11:41 AM   #20
Viperoni
Drives: 2005 Toyota Echo
the reason that camber spacers were never made is because:
under compression, camber on a trailing arm axle turns into toe-in.. so. if i were to develop camber shims for the stock-height yaris, and they're installed on a lowered yaris, a good portion of my camber would now turn into toe-in (the car is already toe-in from the factory). so, now your tires truly ARE gonna get shredded..
likewise, if i designed the camber spacers for a lowered yaris, and someone with a stock-height yaris installed them on their car, a lot of that camber would now be toe-out.. which is not a safe thing for the average car/average driver (toe out makes you spin out)..
this is why we (Penguin Garage) never developed camber spacers. as far as the kiwi who knocked off our design, i cannot answer as to why he never made any...
I understand.
The question is, how much toe in actually happens?
Doing some more research on the topic, I came across this article: http://www.worldautosteel.org/upload...eam_Design.pdf through a wikipedia link, and it turns out that *that* twist beam design gets camber gain through compression (1.5* at 1inch), along with very mild toe in (0.15* at 1inch).
It also gets very mild toe-out during extension .25* at 1 inch and starts going positive camber as well; 1.5* at 1inch.
See pages 168-169.
Their suspension design is different than ours though.
So the question really is; what does our suspension do as is?
Old 02-05-2011, 08:56 PM   #21
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
get off your ass and take some measurements for me ;) i don't own a yaris lol
Originally Posted by xnamerxx
you nailed it sir.
Old 02-07-2011, 12:13 AM   #22
Viperoni
Neither do I! :P
Old 02-07-2011, 07:24 AM   #23
Tamago
Tamago's Avatar
Drives: ZZW30
you can buy onetongarage cambered spacers for your echo... if he's still in business that is..
you nailed it sir.
question on Rear Hub Spacers mastaofdisasta Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 02-02-2010 10:54 AM
Adjusting rear camber?? PHXDEMON Wheels, Tires and Suspension Forum sponsored by The Tire Rack 63 10-23-2009 01:11 PM
New Product: Penguin Garage Rear Camber Shims! Penguin Garage Penguin Garage 11 10-22-2009 11:20 PM
Penguin Garage Rear Hub Spacers!! Penguin Garage Sponsors Classifieds Area 92 09-02-2009 07:16 PM
Handling changes from rear hub spacers and minor concern. YarisSedan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 07-10-2009 09:07 PM
