Drives: 07 Yaris 4-Door Join Date: Jul 2007
HELP: changing water pump
I am in the process of changing my water pump, but I cannot get the engine mount off. I've removed all 5 of the bolts, but where it connects to the engine half of the mount, it will not come seperated. There is a bolt hole where you can screw in one of the bolts to seperate the two, but I tried that, and the threads inside of it are now gone, so I can't use that. Is there any way that I can get this water pump off without removing the engine mount? I have the water pump loose, but I cannot seem to orient it in a way to remove it. Please help, I need to finish this very soon; I need the car tomorrow morning.
The engine mount should come off fairly easily. You do need to support the engine when removing it.
I used a big three ft. prybar to push the engine sideways without ever messing with the engine mounts. It's fast and save a LOT of time...
^ +1
I never had to remove the mount or have to pry anything to remove mine.
Edit to add that I removed the pump pulley first and the angled the bracket holding the AC line. Having the NST pulley helped alot. |
| Water Pump issue, after taking in for Recall | GeneralDon7 | General Yaris / Vitz Discussion | 34 | 05-27-2012 08:04 PM |
| Yaris Fuel Pump | HTM Yaris | General Yaris / Vitz Discussion | 12 | 03-22-2012 03:34 AM |
| Water Pump leaks and then stops | CB900F2 | DIY / Maintenance / Service | 30 | 05-09-2011 09:14 AM |
| Hmm my water pump failed again!!!! Could it be the pulley?!?! | YarisSedan | Performance Modifications | 64 | 10-05-2009 09:32 PM |
